Old Mon, Jun-15-2015, 04:28:36 PM   #11
DirtyEtzio
DirtyEtzio's Avatar
Reputation: 0 DirtyEtzio is on a distinguished road
Default Re: Running hot in higher temp climates
3/4 of the gauge is not overheating. However, you need 50/50 mix, maybe even 80 coolant/ 20 water. You may also be needing a new radiator depending on your mileage.. assuming you've checked the fan clutch?
This is simply not true. Water absorbs more heat per unit than antifreeze. If you live in a climate where freezing is not an issue, you can easily run a 80/20 water to antifreeze ratio and realize some extra benefit in cooling over 50/50. In fact, if you live in a temperate climate where freezing is never an issue, you could safely run 100% water, from a cooling perspective. Though having some antifreeze in the mix is important for lubrication and corrosion prevention.
By way of explanation, the specific heat capacity of water is 1 BTU/lb/degree F. That means it takes 1 BTU of heat energy to raise the temperature of one pound of water one degree F. For comparison, the specific heat capacity of ethylene glycol is 0.58 BTU/lb/degree F. The specific heat of a 50/50 mixture of water and ethylene glycol is 0.815 BTU/lb/degree F at 80 degrees F.
  • Ground Control coilovers and Hotchkis front sway bar
  • RE El Diablo
  • Cobra Suzuka GT's, Kirk roll bar, harnesses.
Jump to top DirtyEtzio is offline   Reply With Quote
Old Mon, Jun-15-2015, 04:38:36 PM   #12
mpower22
CPV O-Ring Guy
mpower22's Avatar
That's exactly why your vehicle is running hot, you should never be running 80% water in there, you are bringing the boiling point of the mixture waaaaay down. 50/50 ratio is the only one recommended by BMW, end of discussion.
///M3 - Dream Car: Acquired
15-Year Member
2003 M3Laguna Seca Blue/6MT/Black Leather Cloth Interior/Full [CSL] Exhaust/evolve-R
Old Mon, Jun-15-2015, 04:47:52 PM   #13
DirtyEtzio
DirtyEtzio's Avatar
Nope. Going from a 50/50 mix to an 80/20 mix drops the boiling temperature by a whopping 5*C.
Meanwhile, the 80/20 mix makes the system more efficient at absorbing heat from the engine.
Source: http://www.engineeringtoolbox.com/et...col-d_146.html
  • RE El Diablo
Old Mon, Jun-15-2015, 04:53:36 PM   #14
icecream
Registered Apples
icecream's Avatar
Nope, this is just not true. , add in the fact that it is a sealed system under high pressure and the boiling temp is even higher. And finally, water is a better coolant than "coolant" as the poster above pointed out and would keep the motor cooler.
Old Mon, Jun-15-2015, 05:17:19 PM   #15
sev
Reputation: 0 sev is on a distinguished road
Originally Posted by Arson8 View Post
Hi All,
I was in Palm Desert last weekend, and the weather was around 105 degrees. With the a/c on, my car started to creep up to the 3/4 mark on the coolant temp gauge, and once I turned it off it slowly started coming down. Is this something that I should be concerned about, or is this normal? Below is a list of what has been done within the last 10k miles.
-Coolant flush with BMW coolant and distilled water (80/20 mix)
-BMW Thermostat
-BMW water pump
Thanks fellas!
i had the same problem, your fan clutch has gotten lazy and it's time to replace it.
Jump to top sev is offline   Reply With Quote
Old Mon, Jun-15-2015, 08:00:04 PM   #16
jcreme
Mechanical? Engineer?
jcreme's Avatar
Reputation: 0 jcreme has disabled reputation
Also might have air in the system. I had similar symptoms and I found air in the system. I burped it out through the bleeder (just not when it's hot mmK?).
For future reference, putting on HVAC to 92 and fan on high is much quicker to cool it down to normal temp than shutting down the engine. A shut down engine isn't circulating coolant at all. It's kind of the difference between taking off your shirt when you are hot n sweaty vs climbing under some blankets and laying very still until you feel cooler.
If keeps climbing after that, shut it down. Unless you have access to a water hose, then a cold stream on the radiator will bring it down really quickly.
^^these things compliments the school of hard knocks^^
Original Owner 2003.5 IR 6MT
Jump to top jcreme is offline   Reply With Quote
Old Mon, Jun-15-2015, 08:46:16 PM   #17
Zabalzae
Zabalzae's Avatar
Reputation: 0 Zabalzae is on a distinguished road
I have about 30 coolant to 70 water with a bottle of water wetter and no issues. I live in tx and it gets hot as hell.
Jump to top Zabalzae is offline   Reply With Quote
Old Mon, Jun-15-2015, 09:26:40 PM   #18
Arson8
Reputation: 0 Arson8 is on a distinguished road
I would also like to mention that it was getting hot while at freeway speed. Y'all still think it's the fan clutch? Sounds more like a radiator blockage to me.
Jump to top Arson8 is offline   Reply With Quote
Old Mon, Jun-15-2015, 09:33:09 PM   #19
Zabalzae
Zabalzae's Avatar
Radiator
Old Tue, Jun-16-2015, 11:02:57 PM   #20
At 80/20 you probably don't have enough corrosion inhibitors though. Idk if I'd run that long term
coolant, temperature
Discussing Running hot in higher temp climates in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
