Old Mon, Jun-15-2015, 06:11:02 AM   #1
Arson8
Reputation: 0 Arson8 is on a distinguished road
Default Running hot in higher temp climates
Hi All,
I was in Palm Desert last weekend, and the weather was around 105 degrees. With the a/c on, my car started to creep up to the 3/4 mark on the coolant temp gauge, and once I turned it off it slowly started coming down. Is this something that I should be concerned about, or is this normal? Below is a list of what has been done within the last 10k miles.
-Coolant flush with BMW coolant and distilled water (80/20 mix)
-BMW Thermostat
-BMW water pump
Thanks fellas!
Jump to top Arson8 is offline   Reply With Quote
Old Mon, Jun-15-2015, 06:13:38 AM   #2
icecream
Registered Apples
icecream's Avatar
Default Re: Running hot in higher temp climates
Originally Posted by Arson8 View Post
Hi All,
-BMW Thermostat
-BMW water pump
Thanks fellas!
sounds stupid but 80 water, 20 coolant right?
Old Mon, Jun-15-2015, 06:15:40 AM   #3
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
Hi All,
-BMW Thermostat
-BMW water pump
Thanks fellas!
I live in 29 Palms, about an hour into the middle of nowhere desert from Palm Springs, and my temp has only reached slightly passed half way. 3/4 seems like a bit much to me...
Jump to top E46_USMC is offline   Reply With Quote
Old Mon, Jun-15-2015, 06:28:24 AM   #4
Arson8
yes 80 water 20 coolant
Old Mon, Jun-15-2015, 07:11:48 AM   #5
HassanEido
HassanEido's Avatar
Lebanon
something is wrong, when i had my electric fan on, higher temp weather made it creep up to 3/4 mark, I promptly installed my clutch fan, and all is good in the world again. Either something is obstructing ur radiator, or ur clutch fan is shot, or ur radiator is blocked from the inside
Old Mon, Jun-15-2015, 07:15:27 AM   #6
James1251
James1251's Avatar
Reputation: 0 James1251 is on a distinguished road
I was always under the assumption that water boils quicker then antifreeze, which is part of the reason you run 50/50
Jump to top James1251 is offline   Reply With Quote
Old Mon, Jun-15-2015, 09:38:57 AM   #7
Roberto Ramasco
Rober Rh
Reputation: 0 Roberto Ramasco is on a distinguished road
Spain
It sounds like the fan clutch is the problem to me. I had the same problem three weeks ago on a track day. The water temperature rise more than 3/4, inclusively to the red point for a moment. The fan clutch was not working well and if you can prove to stop it with the hand (previously with another thing). If it stops easily the problem is the fan clutch.
2002 m3 e46//Beysan Systems Vanos Upgrade//Vacmotorsports oil pump//18´Square//Hsd Monopro Supension//Porsche 996 front and rear calipers//Redish motosport rear subframe plates
Jump to top Roberto Ramasco is offline   Reply With Quote
Old Mon, Jun-15-2015, 09:45:42 AM   #8
HassanEido
HassanEido's Avatar
Lebanon
But don't stop it with ur hand
Old Mon, Jun-15-2015, 10:31:04 AM   #9
Zabalzae
Zabalzae's Avatar
Reputation: 0 Zabalzae is on a distinguished road
Might be a good time to do the whole cooling system a long with radiator
Jump to top Zabalzae is offline   Reply With Quote
Old Mon, Jun-15-2015, 01:56:43 PM   #10
Drewster
Drewster's Avatar
3/4 of the gauge is not overheating. However, you need 50/50 mix, maybe even 80 coolant/ 20 water. You may also be needing a new radiator depending on your mileage.. assuming you've checked the fan clutch?
coolant, temperature
Discussing Running hot in higher temp climates in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
