Old Sat, Dec-20-2014, 05:26:52 PM   #1
m3dragon
CSL M3 / Raptor / 12C
m3dragon's Avatar
Reputation: 0 m3dragon is on a distinguished road
Default Comprehensive CSL Intake Thread
Types of Airboxes:
OEM
  • Pros: Perfect fitment, likely most durable
  • Cons: Very expensive (~$6000), very difficult to find, hardware (filter, clamps, shutoff valve, etc.) likely sold separately.
Karbonius
  • Pros: Cheapest ($1800-2000), OE replica, uses all OE hardware and ducting
  • Cons: All hardware (filter, clamps, shutoff valve, etc.) has to be sourced separately. Some minor fitment issues.
Evolve
  • Pros: Includes alpha-n tune and all necessary hardware, designed to draw cold air without special ductwork, customer service. Available in both matte and gloss. Never heard of any fitment issues
  • Cons: Must use Evolve tune (unless you want to throw away money), does not use OE filter, cannot use CSL flap or ducting.
Those are the big 3. There are a couple others out there. Geoff Steele is popular in the UK, but I'm not really familiar with the specifics of their airbox. VAC is supposed to be awful
Wiring (for CSL DME Conversion)
You have two options: Either buy an OE CSL harness (pn: 12517833336) or modify the stock harness. You can buy an OE CSL harness for $600 - $1000 depending on the supplier; it requires minor modification to work properly with a manual car
If not using the CSL engine harness, CSL Wiring Harness Conversion:
MAP Sensor
  • Requirements:
    • 12527507526 x 1 (Connector)
    • 12527502932 x 3 (Gold Contacts for MAP connector)
    • 12527510674 x 3 (Contacts for DME Connector)
    • 12527503411 x 3 (Rubber Grommet for contacts)
    • 22-20 AWG Wiring in assorted colors
    • Optional: 12527506431 x 1 (Connector boot – possibly wrong part)
  • Pinout:
    • MAP Pin 1 -> X60003 Pin 7
    • MAP Pin 2 -> X60003 Pin 17
    • MAP Pin 3 -> X60003 Pin 18
Alternator signal (March 2004+ Cars)
  • Requirements:
    • 12527510674 x 2 (Cluster and DME pins)
    • 22 AWG wire
  • Pinout: Black Connector of Instrument Cluster Pin 2 -> X60004 Pin 1
  • Coding: Set “GENERATOR_UEBER_CAN” to nicht_aktiv
IAT Sensor
  • IAT pin 1 to MAF harness pin 1 or DME X60003 pin 22 (Power)
  • IAT pin 2 to MAF harness pin 3 or DME X60003 pin 16 (Ground)
Flap Motor
  • Flap pin 1 to DME X60002 pin 8 (Power)
  • Flap pin 2 to DME X60002 pin 9 (Ground)
Flap position sensor
  • FPS pin 1 to MAF harness pin 3 or DME X60003 pin 20 (Ground)
  • FPS pin 2 to MAF harness pin 5 or DME X60003 pin 1 (Signal)
  • FPS pin 3 to MAF harness pin 4 or DME X60003 pin 14 (Power)
Fuel Pump Relay Conversion - US cars only (Try running the car without touching the fuel pump relay first. It's not required for most cars; it has yet TBD what causes it to be required)
  • Requirement: Green BMW Relay (replaces black relay)
  • Pinout:
  • Relocate X60002 Pin 11 -> X60004 Pin 10
  • Relocate Relay Pin 1 to Pin 4
  • Pin 7 is unused
For reference:
X60001 is the top-right connector in this picture. They increase sequentially until X60005 as you go down and left
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
Jump to top m3dragon is offline   Reply With Quote
Old Tue, Dec-23-2014, 05:49:23 PM   #2
casper3t
casper3t's Avatar
Reputation: 0 casper3t is on a distinguished road
Default Re: Comprehensive CSL Intake Thread
I just got word that the Control Unit (Snorkel) P/N 11617833498 is no longer available.
'02 Euro Tuned ///M3 6spd Carbon Black cover with a layer of dust and Grey Int.
Jump to top casper3t is offline   Reply With Quote
Old Tue, Dec-23-2014, 06:15:37 PM   #3
Sometimes I feel bad for csl owners. BMW is screwing them over by trying to limit csl parts. Everything is running out! I have three friends that bought map rails and sensors just in case they do the conversion in the future when they're NLA
Old Tue, Dec-30-2014, 07:18:56 PM   #4
NZ_M3
Reputation: 0 NZ_M3 will become famous soon enough
Here's a visual of the main engine harness difference between CSL and an 03 Euro harness.
CSL harness on the left, Euro on the right
CSL Harness
Euro Harness
CSL intake flap motor and IAT wiring plug
Euro non intake flap motor wiring
CSL Map sensor wiring
Euro no map sensor wiring (notice the grommet is already there for it however)
CSL intake flap potentiometer plug
Euro MAF plug
Wiring housing internal differences and plugs (CSL first, then Euro)
CSL Intake flap motor wiring hole (just drilled out and plastic grommet (part number of grommet appears to be ending with 1407960)
Happy to provide more photos of this harness if requested.
Jump to top NZ_M3 is online now   Reply With Quote
Old Wed, Dec-31-2014, 02:50:35 AM   #5
Thanks for that. I was wondering where from that box they ran the flap and IAT wires. Looks like they literally just drilled a hole in the box and added a tube.
Old Mon, Jan-05-2015, 01:04:01 PM   #6
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
I hate to be the dumb guy who sticks his head out, but...
Let me preface this with, I wrench and do everything on my cars. With that being said, I am an absolute dummy whenever it comes to electronics. Is there any possibility of getting (literally) a step-by-step DIY install? I am talking, take this exact wire and solder to this wire, etc. This connector gets attached to this wire, route this wire through here, etc. Maybe I am just asking too much, not sure. I just don't want to mess anything up!
Mr. Wolfe
Old Mon, Jan-05-2015, 11:56:47 PM   #7
GedOz
GedOz's Avatar
Reputation: 0 GedOz is on a distinguished road
Mr. Wolfe
+1
Cheers
George
Jump to top GedOz is offline   Reply With Quote
Old Tue, Jan-06-2015, 02:29:45 AM   #8
m3dragon
m3dragon's Avatar
I will get some pics tomorrow to show you the pins as close as I can.
Old Tue, Jan-06-2015, 04:17:34 AM   #9
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Thanks Adam. I hope I am not being too much of a pain. My airbox should be in this week and I already have the snorkel.
Mr. Wolfe
Old Tue, Jan-06-2015, 04:30:43 AM   #10
m3dragon
m3dragon's Avatar
Not being a pain at all. Issue is it is hard to explain how this all tire together. I learned by meeting with someone and we figured it out using the BMW install software. If you are going alone it is harder.
I will get the pics posted tomorrow.
Discussing Comprehensive CSL Intake Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
