Old Thu, Oct-16-2014, 06:16:11 PM   #41
amanonfire
Reputation: 0 amanonfire is on a distinguished road
Default Re: How to mount a Spal Electric fan to the stock shroud
Originally Posted by TheGenius46M View Post
Even with the straight blades?
Yep! Even with the top down I cannot hear the fan.
Jump to top amanonfire is offline   Reply With Quote
Old Thu, Oct-16-2014, 08:07:39 PM   #42
TheGenius46M
TheGenius46M's Avatar
Originally Posted by F1Dryvr View Post
I recently did this with the "2049". Getting the aux fan removed is a B****, but wiring the aux controller to the fan is simple, just two wires. The fan easilly clears the water pump where the old clutch fan goes, but i did offset it for better clearance. As said the computer will then control your spal fan progressivly with temperature, and if you are inclined for coding the computer it can be adjusted. There are a few threads on this if you want to micromanage it. Im in FL and have used it all summer and had no issues w/ my temps even in traffic. The fan runs if your AC is on also if im not mistaken. Lastly its not at all noticable from inside the car while the fan is running. Outside you can tell its on but again the noise from this larger fan is a non issue.
Hope that helps.
Thanks, but I am trying to run the AUX fan with the SPAL as a secondary source once the car gets too hot
2003 E46 M3 TiAg/Cinnamon 6MT
MCS | Recaro | OMP | Hyperco | Besian | AKG | UUC | Rogue | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Status Gruppe |
Old Thu, Oct-16-2014, 10:09:38 PM   #43
amanonfire
Why?
The aux fan only runs if the car gets too hot. If you delete the aux fan and run the spal fan off the aux fan controller, the spal fan will only run if the car is too hot.
Removal of the aux fan also allows more air to the rad, which helps at speed.
Old Thu, Oct-16-2014, 10:23:36 PM   #44
TheGenius46M
Originally Posted by amanonfire View Post
Why?
Most people run them together for additional cooling. I deleted my clutch fan a year ago, with a cooling system overhaul, and with just the AUX fan, my car never overheats at the track in 100 degree weather, nor in stop and go traffic with the AC on.
I want the AUX fan to function normally, but once the engine reaches 180 degrees, I want the SPAL to kick in as a secondary source for additional cooling.
Old Fri, Oct-17-2014, 05:15:59 AM   #45
snikwad
EOMFD
snikwad's Avatar
Reputation: 0 snikwad will become famous soon enough
Jamaica
That's what I want. A friend of mine suggested this...
http://m.summitracing.com/parts/hda-3654/media/images
I think in gonna give it a shot
01 IR on Blk Vert with lots of stuff!
Jump to top snikwad is online now   Reply With Quote
Old Fri, Oct-17-2014, 10:02:30 PM   #46
DodgeStratus
DodgeStratus's Avatar
Reputation: 0 DodgeStratus is on a distinguished road
Despite the extremely poor reviews? Seems risky.
Jump to top DodgeStratus is offline   Reply With Quote
Old Fri, Oct-17-2014, 10:11:38 PM   #47
snikwad
EOMFD
snikwad's Avatar
Jamaica
Default How to mount a Spal Electric fan to the stock shroud
Lol. What's risky about it?
The 2nd review said it was a bad batch.
The guy that told me about them use to run them on hot rods with 2 fans.
Old Fri, Oct-17-2014, 10:15:37 PM   #48
infinkc
Rgetsired User
Reputation: 0 infinkc is on a distinguished road
yea i looked at that one also, but the reviews sucked, so i stuck with a preset temp one.
Mishimoto uses this one with their kit, you need the probe unless you tap the coolant line.
Jump to top infinkc is online now   Reply With Quote
Old Fri, Oct-17-2014, 10:18:18 PM   #49
snikwad
EOMFD
snikwad's Avatar
Jamaica
Amazon.com: Derale 16759 Adjustable Fan Controller: [email]Automotive
Am I understanding that right. A water jacket sensor. Where and how does that thing mount? Where and how does it read temp?
Which prayer one do you run? I don't really need the adjustability.
Old Sat, Oct-18-2014, 05:07:18 AM   #50
snikwad
EOMFD
snikwad's Avatar
Jamaica
Is this the non adjustable one you're running?
http://www.etrailer.com/Radiator-Fan...le/D16738.html
Discussing How to mount a Spal Electric fan to the stock shroud in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
