Old Sat, Sep-06-2014, 02:51:32 AM   #31
playskool1
NorCal's S54 VANOS/Valve Adjust./Rod Bearing guy
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
Default Re: How to mount a Spal Electric fan to the stock shroud
infinkc - I just received my SPAL fan - 30101516 and it did not include the metal mounting bracket or mounting tabs.
Do I only need to order 1 bracket - 30130011? What about the 2 mounting tabs you used at the bottom? I'm not sure which part number you have pictured (30130010? 30130017? or 30130032?) I excluded the other 3 pictured on the box because those are obviously a lot longer. LMK thanks!
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [228k total miles][original motor]
[115k supercharged miles][17k E85 miles][5k turbocharged miles][1.7k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
Jump to top playskool1 is offline   Reply With Quote
Old Thu, Sep-18-2014, 05:08:25 AM   #32
admranger
Registered troublemaker
And Mishimoto comes out with this: ECS Mishimoto Electric Fan Delete Kit
Interesting! After running really hot at the track this weekend (again) and having a top shelf cooling system, I'm wondering if this would help at all?
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Thu, Sep-18-2014, 06:28:57 PM   #33
aspa
Reputation: 0 aspa is on a distinguished road
I love the idea of a complete kit. I've been looking at the Spal fan but don't really like the way every DIY seems to figure out a slightly different way to do it.
Jump to top aspa is offline   Reply With Quote
Old Thu, Oct-09-2014, 05:00:22 PM   #34
amanonfire
Reputation: 0 amanonfire is on a distinguished road
Originally Posted by infinkc View Post
I honestly can't tell it's on, I think the aux fan is louder.
Thanks again!
I installed the Spal 30101516 fan this past weekend and can confirm it is quiet! The engine makes more noise than this fan.
Jump to top amanonfire is offline   Reply With Quote
Old Thu, Oct-09-2014, 05:17:46 PM   #35
snikwad
EOMFD
snikwad's Avatar
Reputation: 0 snikwad will become famous soon enough
Jamaica
Originally Posted by amanonfire View Post
Thanks again!
How did you wire it up?
Did u keep the six fan?
Is your car a street legal car?
01 IR on Blk Vert with lots of stuff!
Jump to top snikwad is offline   Reply With Quote
Old Thu, Oct-09-2014, 07:05:24 PM   #36
amanonfire
Used the aux fan controller.
Ditched both aux and mechanical fan.
Daily driver.
Old Thu, Oct-09-2014, 10:10:14 PM   #37
snikwad
EOMFD
snikwad's Avatar
Jamaica
Thanks
Old Thu, Oct-16-2014, 05:58:21 AM   #38
TheGenius46M
TheGenius46M's Avatar
Thanks again!
Even with the straight blades?
So I considering the SPAL 30102049 version which has curved blades and is a little bigger for more cooling. I know it won't fit the stock shroud, but since the CFM is higher, 2070 compared to 1610, can I wire it the same way as the OP?
It seems like he wired it so the AUX fan functions normally, but once temps reach 180 degrees, it kicks in as an additional cooling source. This is EXACTLY what I am looking for, so if anyone can confirm this, I'll be ordering. Thanks!
2003 E46 M3 TiAg/Cinnamon 6MT
MCS | Recaro | OMP | Hyperco | Besian | AKG | UUC | Rogue | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Status Gruppe |
Old Thu, Oct-16-2014, 05:10:00 PM   #39
infinkc
Rgetsired User
Reputation: 0 infinkc is on a distinguished road
Yes you can wire the higher CFM fan the same way that I did, it pulls the power directly from the battery so your not going to blow any other circuit in the car. It uses the temp switch to turn on at 180, the aux fan comes on as normal. You will need a higher amperage fuse with the larger fan.
Also ive been told that the fan from Amazon does not always come with the brackets, so you may need to order them as well.
Jump to top infinkc is offline   Reply With Quote
Old Thu, Oct-16-2014, 05:33:37 PM   #40
F1Dryvr
Reputation: 0 F1Dryvr is on a distinguished road
I recently did this with the "2049". Getting the aux fan removed is a B****, but wiring the aux controller to the fan is simple, just two wires. The fan easilly clears the water pump where the old clutch fan goes, but i did offset it for better clearance. As said the computer will then control your spal fan progressivly with temperature, and if you are inclined for coding the computer it can be adjusted. There are a few threads on this if you want to micromanage it. Im in FL and have used it all summer and had no issues w/ my temps even in traffic. The fan runs if your AC is on also if im not mistaken. Lastly its not at all noticable from inside the car while the fan is running. Outside you can tell its on but again the noise from this larger fan is a non issue.
Hope that helps.
Jump to top F1Dryvr is online now   Reply With Quote
Discussing How to mount a Spal Electric fan to the stock shroud in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
