Old Fri, Aug-15-2014, 03:05:58 PM   #21
infinkc
Rgetsired User
Reputation: 0 infinkc is on a distinguished road
Default Re: How to mount a Spal Electric fan to the stock shroud
Originally Posted by Tchleung View Post
Thanks for the write up!
It looks like you could have ran the larger deeper higher flowing capacity fan even!
Curious, with the way the fan is mounted on the shroud, how far is the actual fan from the radiator? 1"?
The larger deeper fan is 3-7/16" depth, which is close to 1" more than this fan. You would not be able to use it with the stock shroud unless you cut the thread off the waterpump where the stock fan clutch bolted onto.
There is roughly 1/4" clearance from the fan to the radiator, so not much more room that direction.
The Spal 30101516 which i used was the highest flowing fan i could find that would work using the stock shroud.
Jump to top infinkc is offline   Reply With Quote
Old Thu, Aug-28-2014, 09:43:37 PM   #22
amanonfire
Reputation: 0 amanonfire is on a distinguished road
For those who have the 1516 spal fan, how loud it is compared to the stock mechanical fan? I am debating the curved 2049 fan. I like that the shroud is maintained with this fan, although I'll sacrifice the shroud for less noise.
Jump to top amanonfire is offline   Reply With Quote
Old Fri, Aug-29-2014, 12:33:12 AM   #23
tmaxx445
Likes to Eat AMGs
tmaxx445's Avatar
Reputation: 0 tmaxx445 is on a distinguished road
Looks like a clean install to the shroud. Any reason you did not use the stock fan controller from the AUX fan to power and regulate the Spal fan?
tmaxx445
2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium / Cold Weather / Bi Xenons / Adjustable Bolsters / Lumbar / MKIV Navigation / Harmon Kardon Hifi / Sirius / Aux In / Bluetooth / Rain Sensor / Home Link / BMW Assist / Alarm / Hard Wired Radar Detector / LED Interior Lights / Carbon Interior Trim / Alcantara Pillars / ZHP Shift Knob / Short Shifter / Custom Tune / StreamLine Intake / IAT Relocation / Dynamic Air Scoops / Fan Delete / SS Headers / AR20 Resonator / Electric Exhaust Bypass Valve / Koni Yellow Adjustables / Eibach Pro Kit Springs / PowerFlex & AKG Poly Bushings / M Track Mode / RedLine Fluids / PFC Z-Rated Street Pads / Staggered OEM CSLs / 275 & 245 595 Evos / 12mm Front Spacer / 10mm Rear Spacer / Orion V2 Angel Eyes / Carbon CSL Splitters / Matched Reflectors / SunTek Carbon 38% Tint
Jump to top tmaxx445 is offline   Reply With Quote
Old Fri, Aug-29-2014, 02:19:45 AM   #24
avusbluem3
avusbluem3's Avatar
Reputation: 0 avusbluem3 has disabled reputation
tmaxx445
I did this mod as well thanks to the OP.
From my understanding you can't keep the aux fan if you are using it to control the spal fan, at least no one has figured it out yet. Pretty sure OP wanted to keep the aux fan like I did.
95 E36 M3 Avusblue/Dove Gray :Sold
02 E46 M3 Steel Grey/Black Nappa/SMG II
Jump to top avusbluem3 is online now   Reply With Quote
Old Fri, Aug-29-2014, 03:29:09 AM   #25
infinkc
Rgetsired User
I was thinking of using the aux fan controller, it should be able to run both fans fine, the 1516 fan doesn't draw too much current. I decided it wasn't worth the time to take the front bumper off and tap into the wires, so I just decided to run the seperate thermostat.
Old Sun, Aug-31-2014, 06:36:37 PM   #26
amanonfire
Anyone? Waiting for a response to pull the trigger and order.
Old Mon, Sep-01-2014, 06:25:56 AM   #27
Andy2108
Andy2108's Avatar
Reputation: 0 Andy2108 is on a distinguished road
Not sure I like how that ended up being installed. It's nice to keep the oem shroud and all... but I dont think it helps cool the car. Actually I think this setup is worse than one with a bigger fan, mounted directly to the radiator, without a shroud.
Jump to top Andy2108 is offline   Reply With Quote
Old Mon, Sep-01-2014, 07:16:32 AM   #28
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Why do you think its worse with the shroud?
Old Mon, Sep-01-2014, 03:22:24 PM   #29
infinkc
Rgetsired User
I honestly can't tell it's on, I think the aux fan is louder.
Old Tue, Sep-02-2014, 04:03:51 PM   #30
amanonfire
Thank you!
Discussing How to mount a Spal Electric fan to the stock shroud in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
