Old Mon, Jul-21-2014, 05:35:13 AM   #11
dunkman23
dunkman23's Avatar
Reputation: 0 dunkman23 is on a distinguished road
Default Re: How to mount a Spal Electric fan to the stock shroud
Originally Posted by infinkc View Post
It's fairly simple so I didn't post all the details. It's just a standard relay.
12 from the battery jump post to terminal 30
Terminal 87 to the fan +
Terminal 85 to one side of the thermostat switch
Terminal 86 to 12v ignition( I used the red wire with white stripe)
Picture from FastM
Since the fan wire was on top, it fits perfectly through the shroud as there is a square cutout.
You can always come seee and I can help ya.
sounds good. Ill contact ya if i have troubles in the future with this.
do you notice the car running cooler with the electric fan?
2002 BMW ///M3 6mt TiAg /Imola - APEX ARC-8/PSS - BILSTEIN PSS10
1993 BMW ///E34 Touring - OBD1 S52 - 5sp MT, 3.23 LSD
Jump to top dunkman23 is offline   Reply With Quote
Old Mon, Jul-21-2014, 07:21:09 AM   #12
E46_M3_ZCP
Dinan S1
E46_M3_ZCP's Avatar
Reputation: 0 E46_M3_ZCP is on a distinguished road
http://www.turnermotorsport.com/p-34...an-delete.aspx
Jump to top E46_M3_ZCP is offline   Reply With Quote
Old Mon, Jul-21-2014, 08:33:12 AM   #13
(///M)ZOO
Reputation: 0 (///M)ZOO is on a distinguished road
China
Did you still keep the stock AUX fan with this setup?
2006 ZCP Interlagos Blue: | VCSL bumper | VCSL Diffusor | Dice Ipod | Depo Smoke Corners | Led side blinker | Led front | Angle Eyes | Keyhole Delete | Grill and Gill Blackout | Carbon Fiber E-brake | RE Clutch Stop | SE Filter | Back up Led | Ground Control Street/School coilover | RE sports rear control arm | Powerflex RTAB | RE 12/10 Spacers | TMS Caliper Bushing | TMS Subframe kit | Single sided VCSL Bootlid | OEM 18 Square | Stoptech SS line |
Jump to top (///M)ZOO is offline   Reply With Quote
Old Mon, Jul-21-2014, 05:01:39 PM   #14
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
Originally Posted by E46_M3_ZCP View Post
haha, this is why I love Turner!
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Mon, Jul-21-2014, 08:01:33 PM   #15
m2pc
m2pc's Avatar
Reputation: 0 m2pc is on a distinguished road
IMHO I wouldn't use a T-Tap on such a high current connection; the SPAL fan draws 10's of Amps (maybe up to 50 or so) during startup so the possibility of arcing is quite high.
I'd try to source some BMW connectors and tap into a power block somewhere (or wire directly to the "B+" terminal in the engine bay, through an appropriate fuse or circuit breaker) or if you must splice into the OEM harnesses, at least use a method like this:
Military Splice:
http://www.gm-trucks.com/forums/topi...splice-how-to/
I'd add solder to that and some heatshrink tubing or electrical tape for safe measure.
2003 E46 M3 | 74K Miles | Silver Gray Metallic | StopTech Drilled Rotors | PBR Deluxe Pads | Optima Yellow Top Battery w/Custom Bracket
Jump to top m2pc is offline   Reply With Quote
Old Mon, Jul-21-2014, 09:22:55 PM   #16
infinkc
Rgetsired User
Reputation: 0 infinkc is on a distinguished road
Yes still have the aux front fan as the climates are hotter where im at than most places during the summer. If you do delete the aux fan you can use the aux fan controller instead of the separate fan switch/relay.
Military Splice:
I did not use a T-tap, as mentioned it was only a reference picture i took from an AE install writeup to show what color wire was used. But its only powering the relay so it is not high current at all, so a T-tap would suffice fine. The high current power was tapped at the positive jumper location using a ring terminal on the backside post.
Its actually a BMW OEM part, not something turner makes. part 11511310640
Jump to top infinkc is offline   Reply With Quote
Old Mon, Jul-21-2014, 09:39:59 PM   #17
amanonfire
Reputation: 0 amanonfire is on a distinguished road
If following the exact wiring, yes.
Ever noticed the AUX fan keeps running even after you turn the car off? Cause the wiring for the SPAL fan is connected to the accessory on/off it will not run when the vehicle is turned off.
Jump to top amanonfire is offline   Reply With Quote
Old Fri, Aug-15-2014, 03:24:13 AM   #18
avusbluem3
avusbluem3's Avatar
Reputation: 0 avusbluem3 has disabled reputation
Picture from FastM showing the wire used.
I just bought the same fan and harness. Looking at the instructions for the harness, the other terminal of the thermostat switch goes to 12v ignition and terminal 86 of the relay is ground. You have it where the other terminal of the thermostat is ground and terminal 86 of the relay goes to 12v ignition. What is the reason for changing the wiring? Does the fan stop when the ignition is off?
Thanks.
95 E36 M3 Avusblue/Dove Gray :Sold
02 E46 M3 Steel Grey/Black Nappa/SMG II
Jump to top avusbluem3 is offline   Reply With Quote
Old Fri, Aug-15-2014, 04:23:23 AM   #19
infinkc
Rgetsired User
Thanks.
I changed the wiring around because I don't like running 12v lines longer than they have to be. Say the 12v wire got pinched somewhere it would short out and fry the wire unless you fused it. Having the negative wire is just safer, if it some how gets shorted, the worst thing is the fan will run constant. Also if you were to run the 12v instead, you need more wire as you need to run the 12v to the switch, then the wire back up to the relay. Having a negative trigger, you just need to ground the other side of the switch to a nearby ground.
Old Fri, Aug-15-2014, 04:27:54 AM   #20
Tchleung
Reputation: 0 Tchleung is on a distinguished road
Thanks for the write up!
It looks like you could have ran the larger deeper higher flowing capacity fan even!
Curious, with the way the fan is mounted on the shroud, how far is the actual fan from the radiator? 1"?
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
462whp/311wtq @ 9.5psi(SuperFlow)
4.10 / Headers / ESS VT2-550+
Jump to top Tchleung is offline   Reply With Quote
Discussing How to mount a Spal Electric fan to the stock shroud in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
