Old Sat, Jul-19-2014, 09:38:11 PM   #1
infinkc
Rgetsired User
Reputation: 0 infinkc is on a distinguished road
Default How to mount a Spal Electric fan to the stock shroud
I searched and could not find exactly how people were attaching a Spal fan to their cars, so i took a few pictures while installing mine.
It cost $130 for the fan and relay, couldn't be happier.
I went with a Spal 30101516 model, its a 1610CFM with a low profile.
***EDIT i have been told that the fan from Amazon does not always come with the brackets, so you may need to order them as well. (You need 2 brackets)
I used a Derale Fan relay harness 16738 180F Temperature switch.
I placed the fan inside the stock shroud with the wire on the top.
You need to get (4) 1/4-20 x1/2" nuts and bolts to mount it to the shroud.
just simply drill the holes and bolt down the fan.
The fan comes with 4 brackets, so you do not need to purchase them separate.
you need to cut the metal strap on the bracket down to the length i have in the picture.
Install the bracket onto the fan and use 2 more nuts/bolts to secure it down. It will sit level in this position. The bracket can go on 2 different ways, install it so the bracket is closer to the stock shroud (lock nuts facing the front of the car)
The fan thermostat you push into the radiator fins. i cut the probe down to about 1 1/2" so it would clear. I installed it next to the inlet. Once the plastic fan shroud is installed it presses on the sensor so it will not pop out.
Here is a picture showing how much clearance the fan has to the water pump.
I mounted the fan relay up near the firewall. the other relay there is for my AE's. I wired the relay slightly different than the instructions that come with it. I ran a 12v ignition to the relay(same wire i used for the AE's), then from the relay ran a wire to the temperature switch. The other side of the temperature switch i grounded.
Jump to top infinkc is offline   Reply With Quote
Old Sat, Jul-19-2014, 09:47:27 PM   #2
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Default Re: How to mount a Spal Electric fan to the stock shroud
Nice one.
Old Sat, Jul-19-2014, 10:05:18 PM   #3
TheGenius46M
TheGenius46M's Avatar
Sweet! Been looking for info how to wire one of these without having to install a bung into the radiator. Does it kick on like stock, just function more efficiently?
2003 E46 M3 TiAg/Cinnamon 6MT
MCS | Recaro | OMP | Hyperco | Besian | AKG | UUC | Rogue | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Status Gruppe |
Old Sat, Jul-19-2014, 10:16:09 PM   #4
infinkc
Rgetsired User
Well the stock one is clutch driven so the speed depends how hot the clutch is. 180 deg seems to be what's recommended by many for the fan to kick on. It will turn off if it drops 10deg also. Driving around today at 90deg out, it worked great. I thought it would be louder, but it's fairly quiet.
The main reason I swapped it out was to take the load off the water pump and also so I don't have to worry if a stock fan blade snaps and takes everything with it.
Old Sun, Jul-20-2014, 03:55:21 AM   #5
ZCPIBM3
Reputation: 0 ZCPIBM3 is on a distinguished road
Thank you!
Subed.
2006 M3 ZCP Interlagos Blue
Jump to top ZCPIBM3 is offline   Reply With Quote
Old Sun, Jul-20-2014, 03:59:32 AM   #6
kokgo20
kokgo20's Avatar
Good job and clean install
I was thinking of doing this for a while, wish u would have posted this yesterday, just paid for the mishimoto fan kit.
Build thread
05/2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - PF RTABs & FCABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom A/F & boost gauge - Active Prima plus + FS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s -
Old Sun, Jul-20-2014, 10:19:35 AM   #7
dunkman23
dunkman23's Avatar
Reputation: 0 dunkman23 is on a distinguished road
Any writeup on the wiring (what wires to tap or splice)
Sent from my SPH-L900 using Tapatalk
2002 BMW ///M3 6mt TiAg /Imola - APEX ARC-8/PSS - BILSTEIN PSS10
1993 BMW ///E34 Touring - OBD1 S52 - 5sp MT, 3.23 LSD
Jump to top dunkman23 is offline   Reply With Quote
Old Sun, Jul-20-2014, 01:26:19 PM   #8
bimmerfan08
bimmerfan08's Avatar
This. Nice job OP. I like DIYs and people who take time to post them. You're helping the community when you do so.
Old Sun, Jul-20-2014, 07:19:14 PM   #9
infinkc
Rgetsired User
It's fairly simple so I didn't post all the details. It's just a standard relay.
12 from the battery jump post to terminal 30
Terminal 87 to the fan +
Terminal 85 to one side of the thermostat switch
Terminal 86 to 12v ignition( I used the red wire with white stripe)
Picture from FastM showing the wire used.
Since the fan wire was on top, it fits perfectly through the shroud as there is a square cutout.
You can always come seee and I can help ya.
Old Mon, Jul-21-2014, 12:07:13 AM   #10
admranger
Registered troublemaker
Does anyone know the CFM of the stock fan?
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Discussing How to mount a Spal Electric fan to the stock shroud in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
