Old Wed, Jul-23-2014, 03:01:49 AM   #31
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
Default Re: Extending O2 wiring for Section 1 with Cats
:bowdown:
Old Wed, Jul-23-2014, 03:27:12 AM   #32
benzthis
benzthis's Avatar
Reputation: 0 benzthis is on a distinguished road
Default Re: Extending OEM O2 wiring for Section 1 with Cats
I have euro cats on the way so I would like to use this.if you use this terra let me know the deal with the fuel pump relay stuff.
Jump to top benzthis is offline   Reply With Quote
Old Tue, Aug-12-2014, 08:53:23 AM   #33
This angle shows that BMW actually did wire in the US fuel pump relay trigger (black/violet wire). They made it easy for us!
I think I might order this. Gotta love how BMW made the harnesses fairly modular on these cars.
To restate the part numbers:
6MT:
12517831649 -- Upto September 2003
12517835524 -- September 2003 and beyond
SMG:
12517831652 -- Upto September 2003
12517836372 -- September 2003 and beyond
Don't ask me what the difference is before and after 09/2003 -- I have no idea. This part includes DME connectors X60001 and X60002, and the pin outs are the same for all years at those connectors
Old Tue, Aug-12-2014, 05:04:26 PM   #34
bmwJohhnyD
bmwJohhnyD's Avatar
United Nations
^ what is the fuel pump relay issue you guys are referencing?
and where would you mount this harness? near the ecu?
Old Tue, Aug-12-2014, 05:15:15 PM   #35
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
Where are you sourcing the harness? Tischer is quoting $215. Is that cheap? We could order those clips too, they are only $0.70ea
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Tue, Aug-12-2014, 06:33:20 PM   #36
That part number includes this whole thing:
That includes DME connectors X60001 and X60002, as well as a few miscellaneous connectors that sit in the Ebox, and that large plastic cradle is what DME sits in. X60001 is the connector that actually powers the DME. X60002 is mostly for the O2 sensors, but there are a couple miscellaneous things there as well.
The fuel pump relay concern I had was because US and Euro cars have the fuel pump relay trigger on different DME connectors. US cars have it on X60002 (which this part number includes); Euro cars have it on X60004 (which is the connector that goes to the rest of the vehicle harness).
The way it works on US cars is that fuel pump relay trigger goes from X60002 to a small connector in the Ebox itself. The connector in the ebox goes to the rest of the harness. Euro cars have no need for that wire since their fuel pump relay is wired differently. BMW was nice enough to leave the wire installed for us anyway, at least when ordered as a replacement part.
I'm ordering it from husker parts -- ends up being $215 shipped. No idea how long it'll take to come here. Honestly, that price is better than usual for BMW's harnesses. I do have plans for the original harness anyway
Old Tue, Aug-12-2014, 06:41:49 PM   #37
bmwJohhnyD
bmwJohhnyD's Avatar
United Nations
good info... hurry up and get it and install it and put pics up so i can imitate what you have done.
good luck charlie!
Old Tue, Aug-12-2014, 07:01:29 PM   #38
good luck charlie!
I will. It's easy enough though. If you were able to reroute the O2 sensors, you'll be able to pull this harness.
Old Tue, Aug-12-2014, 07:13:21 PM   #39
Strike that, dealer just emailed me saying the harness was discontinued.
Also possible that US dealers are simply blocked from placing the order. Maybe I should try ECS
Old Wed, Aug-13-2014, 02:19:42 PM   #40
bmwJohhnyD
bmwJohhnyD's Avatar
United Nations
hmmm.. wonder why? cause car is old now? almost 10 years from the 2006 model.
Discussing Extending O2 wiring for Section 1 with Cats in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
