Old Wed, Feb-26-2014, 03:21:50 AM   #11
bzsbimmer
Reputation: 0 bzsbimmer is on a distinguished road
South Korea
Default Re: Extending O2 wiring for Section 1 with Cats
Yeah I think we got that buuuut... the CSL doesn't come with a cut wire loom so how is theirs run?
Helping the economy one mod at a time
Alpine E90 M3
Jump to top bzsbimmer is offline   Reply With Quote
Old Wed, Feb-26-2014, 04:09:42 AM   #12
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
Originally Posted by trantamthien View Post
Here you can see he cut the loom towards the fuse box area. The wiring leads straight downwards in this area. This allows for more length to run along the side of the transmission tunnel here. Also, even before the sensor wires go into the loop, it's coiled up and tied up on the valve cover.
so you are saying he only uncoiled the wire from the loom on the head and cut the wiring harness cover back to the dme and then ran it straight down without physically extending it?
sorry im dense mate.
Old Wed, Feb-26-2014, 04:28:34 AM   #13
trantamthien
Reputation: 0 trantamthien is on a distinguished road
Correct. The coiled stock wiring is only unraveled to make it longer. There is no splicing or adding extra length wire to the existing cable. This should be enough to allow you to use the existing wiring for almost all applications without modification.
Jump to top trantamthien is offline   Reply With Quote
Old Wed, Feb-26-2014, 11:25:40 AM   #14
wsl
Mongrel Motorsports
wsl's Avatar
Reputation: 0 wsl is on a distinguished road
Originally Posted by m3e46freak View Post
Why do people think they need to cut o2 sensors?
i dont see where he physically extended the sensor wiring?! unless i missed it.
I did not cut any wires, I only extended the OEM O2 wires that are located under the engine cover and enclosed in the factory looms.
The OEM O2 wires use different looms to go from the engine to the area behind the brake booster. They start in the hard plastic corrugated loom, through a soft rubber boot, into a hard plastic cover and finally through a soft rubber corrugated boot.
I only cut the hard plastic corrugated loom back to the soft rubber boot. I tried locating the loom with the hard plastic cover behind the brake booster but this still did not provide enough length for the wires to reach the euro bracket.
also what kind of small bracket did you make? i cant see it in the pictures.. can you picture it so i can make my own?
I removed one of the mounting tabs and the 90 deg bend from the euro mount. I kept the straight part of the 90 deg bend since I purchased the cover and needed to use the two mounting tabs to attach it.
The bracket is just a piece or scrap metal bent to slide over the bracket and reach one of the existing studs on the transmission tunnel. I looked at attaching something to the mount but I didn't want any fasteners to get in the way of securing the O2 wiring. After a coat of primer I used a spare 'nut' to attach it.
Installed:
Jump to top wsl is offline   Reply With Quote
Old Wed, Feb-26-2014, 12:23:52 PM   #15
bmwJohhnyD
bmwJohhnyD's Avatar
United Nations
^ WOW. better than the stock routing. i agree with you 100 percent that the stock mounting position for the o2 sensors seemed the lowest point.
i am sure thousands of euro cars havent ripped the o2 sensors from the exhaust system!! lol... but still i like yours much better!
Old Wed, May-14-2014, 09:13:26 PM   #16
Bumping this up. Does anyone know how the wires are routed exactly on the euro car? The euro and us models (pre 2004) have the same engine harness according to realoem. So it stands to reason that we shouldn't have to cut the loom if the harnesses are the same. Do the euro cars route the precats differently?
Old Wed, May-14-2014, 11:25:23 PM   #17
Mirko
Reputation: 0 Mirko is on a distinguished road
The secondary O2 sensors for EURO cars have longer wires than the US ones.
US
BOSCH/L=1075MM -> 11781406621
BOSCH/L=935MM -> 11781406622
EURO
BOSCH/L=1390MM -> 11787837564
BOSCH/L=1340MM -> 11787837565
The US ones will extend as the OP has shown but it is really close on the 935MM one. I did this on my Z4M. You can buy EURO ones from the dealer but they cost approx $300 CDN each, I asked.
Jump to top Mirko is offline   Reply With Quote
Old Wed, May-14-2014, 11:28:46 PM   #18
djm3
CSL (finished) inside
djm3's Avatar
Reputation: 0 djm3 is on a distinguished road
Default Re: Extending OEM O2 wiring for Section 1 with Cats
Does this help? It's from a CSL.
Jump to top djm3 is offline   Reply With Quote
Old Wed, May-14-2014, 11:39:14 PM   #19
US
EURO
This is only true on the z4m. For the M3, the euro sensors are actually shorter.
Old Thu, May-15-2014, 01:00:07 AM   #20
Attachment 180624
I wish our us spec heat shield had those clips (or at least I'm 99% sure we don't). I tried zip tying them out of the way, and they just melted. Thankfully the O2 wire insulation seems to be able to withstand high temperatures.
Discussing Extending O2 wiring for Section 1 with Cats in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
