Old Tue, Sep-17-2013, 01:42:04 AM   #21
snikwad
EOMFD
snikwad's Avatar
Reputation: 0 snikwad will become famous soon enough
Jamaica
Wow. Talk a our a write up.
01 IR on Blk Vert with lots of stuff!
Jump to top snikwad is offline   Reply With Quote
Old Tue, Sep-17-2013, 01:42:59 AM   #22
Schitzel
Reputation: 0 Schitzel is on a distinguished road
Default Re: Rod Bearings
HOLY SH@T!!!!!
Very, very well done.
2003.5 Jet/Cinn 6MT
Eibach Borla Rouge Beisan Powerflex Valentine SPAL
Jump to top Schitzel is offline   Reply With Quote
Old Tue, Sep-17-2013, 01:52:17 AM   #23
intelone
intelone's Avatar
Reputation: 0 intelone is on a distinguished road
Cambodia
Your old bearing doesn't look bad. You mentioned the car has 130k, but what's the actual milage on the bearing due to the rod bearing recall replacement?
Jump to top intelone is offline   Reply With Quote
Old Tue, Sep-17-2013, 08:52:52 AM   #24
drrwise
Reputation: 0 drrwise is on a distinguished road
Great write up (as always) - thanks.
Did you have more than one blackstone reading? Also how did Cu and Fe look?
I suspect not that many data points out there with a blackstone followed by physical bearing inspection.
03 6mt, topaz, daily driver, 217k
4.10s, 30% AS SSK, Mason Clutch, JL Audio amp/sub, Beisan Vanos, Euro console/aux, VMR 718s, TTFS NA tune
Specialty Tools Available
Cox Epoxy Guns (200mL/400mL), Shim kit, Cam timing tool
Jump to top drrwise is offline   Reply With Quote
Old Tue, Sep-17-2013, 09:10:54 AM   #25
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Awesome DIY! Thank you.
Old Tue, Sep-17-2013, 09:19:35 AM   #26
Moosecakes
Moosecakes's Avatar
Reputation: 0 Moosecakes is on a distinguished road
dude seriously thank you! I'm going to be doing this as soon as time permits and this makes me feel a lot better, it really doesn't seem very hard, just very tedious work and small area!
///M
________________________________________
| Tiag SMG to 6mt Build |
Jump to top Moosecakes is offline   Reply With Quote
Old Tue, Sep-17-2013, 10:25:45 AM   #27
chalaka
Reputation: 0 chalaka is on a distinguished road
Taiwan
Thank you for taking the time to document this
Jump to top chalaka is offline   Reply With Quote
Old Tue, Sep-17-2013, 10:58:17 AM   #28
09raven
2003.5 AW/cinnamom-6mt
09raven's Avatar
Reputation: 0 09raven is on a distinguished road
Just thinking out loud, but would it be any easier to actually pull the motor with a cherry picker and access the oil pan and bearings that way, disconnecting headers, tranny, motor mounts, fan, and associated lines, put it on an engine stand and rotate it so the crank is facing up? Or, would the whole front end have to come apart to get the block out?
Anyways great write up, enjoyed reading through it.
2003.5 AW/Cinnamon 6mt
1969 Camaro SS 427
2009 R1 Raven
2001 Impala
2006 Arctic Cat F7
Jump to top 09raven is offline   Reply With Quote
Old Tue, Sep-17-2013, 11:59:17 AM   #29
Why did you use RTV on the oil pan gasket? Shouldn't be necessary and will make disassembly at 260,000 a bit of a pain...?
Old Tue, Sep-17-2013, 12:06:08 PM   #30
This is something I've been wondering myself. Sure would be nice to be able to do the rod bearings with the engine out of the car
Discussing Rod Bearings in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
