Old Sat, Jun-01-2013, 02:17:56 PM   #41
IbrahimM3
Reputation: 0 IbrahimM3 is on a distinguished road
Egypt
Originally Posted by cyberlando View Post
Hay you should definetley use Carsoft to clear your adaptations...it's a lot easier if you have the program set up I can help you with the process! The major part of the battle is to make sure all the winkfp files are installed correctly. For me I have an 2002 mt m3 and that's the euro software it seems lke that I flashed to my car.
Thank you for the info.I don't have carsoft so most probably I'll do it by DIS ,as for software I know a shop that has original SSS with GT1 which I'll probably use in installing the software since I'm new to programming and I'm afraid I'd mess something up when installing the manual transmission software.One last question do I need to remove the smg control unit before update or not and do I need to to program any module after software update to the DME or not. Thanks a lot for the help I really appreciate it.
Jump to top IbrahimM3 is offline   Reply With Quote
Old Sat, Jun-01-2013, 05:37:27 PM   #42
MP675
Reputation: 0 MP675 is on a distinguished road
Don't remove the SMG control unit until after everything is coded and working properly. The other modules you'll need to recode besides for the DME are the IKE (cluster) and DSC module.
Jump to top MP675 is offline   Reply With Quote
Old Sat, Jun-01-2013, 05:38:28 PM   #43
cyberlando
cyberlando's Avatar
That ^
Engine:
Interior:
Suspension/Handling:
Old Sat, Jun-01-2013, 08:15:48 PM   #44
IbrahimM3
Egypt
That ^
Thanks a lot for the help. One last question what to do in the coding of the Ike and dsc just recode with the SSS after I update the DME or I have to change something when I'm recoding. Sorry for all the questions but I'm new to programming.
Old Sat, Jun-01-2013, 09:20:05 PM   #45
cyberlando
cyberlando's Avatar
You can actually code the other modules in winkfp If I'm not mistaken but don't quote me on that.
But in SSS you just try and reflash them manually, hopefully you won't have to find software numbers for each module.
Engine:
Interior:
Old Sun, Jun-02-2013, 02:44:50 AM   #46
darksideracer
Reputation: 0 darksideracer is on a distinguished road
If you have true sss you can go to the e34 coding and use the old style coding to recode each module.
Sent from my SPH-D710 using Tapatalk 2
Jump to top darksideracer is offline   Reply With Quote
Old Sun, Jun-02-2013, 02:46:53 AM   #47
SSS can't do anything that you can't do with NCS Expert and WinKFP.
You can recode individual modules without picking E34... but you need to edit the VO first (which frankly is a pain with SSS)
Old Sun, Jun-02-2013, 03:16:00 AM   #48
cyberlando
cyberlando's Avatar
Terra is the guy you need to be speaking to about this process. Subject matter expert right there!
Engine:
Interior:
Old Sun, Jun-02-2013, 11:04:26 AM   #49
IbrahimM3
Egypt
Dear All,
Thank you all for the help, I really appreciate it. I'm new in programming so I searched for the VO and found that it means Vehicle order but what exactly do I need to do with it. I'm sorry that I'm asking a lot of questions but I'm new at this and I need all the help from you guys. I'm afraid to work with NCS expert as I have never used it and I'm afraid I'd damage the ECU. Could you please advise what has to be done to the VO and how to do it or tell me where I can find info on it. Thank you all
Old Sun, Jun-02-2013, 11:46:21 AM   #50
IbrahimM3
Egypt
My car already has a Euro software not US software , do I still have to change the VO or this was only for changing regions or I have to change the VO because I have changed the car from SMG to Manual.
