Old Thu, May-30-2013, 06:02:50 AM   #31
Originally Posted by MP675 View Post
When we did it, we used a combination of NCSexpert, INPA, winFKP and winOLS. I'm not sure that ALL of these were needed, and it may have been done as a matter of convenience depending on which module we were working on at a given time. That sticky thread involves a lot of reading, but it does hold the answers to your questions!
I can't see any reason you'd need WinOLS if you're using WinKFP to flash.
Basic process would be to load a manual tune with WinKFP
Remove SMG from vehicle order and recode entire car w/ NCS Expert (previously customized settings will be lost)
Clear all error codes and adaptions from the DME, cluster, and DSC
Old Thu, May-30-2013, 07:42:12 AM   #32
IbrahimM3
Reputation: 0 IbrahimM3 is on a distinguished road
Egypt
Thank you for the help
Jump to top IbrahimM3 is offline   Reply With Quote
Old Thu, May-30-2013, 01:01:42 PM   #33
Abad46
Abad46's Avatar
Reputation: 0 Abad46 is on a distinguished road
100% true. To further clarify, we did not use winkfp.
Jump to top Abad46 is offline   Reply With Quote
Old Thu, May-30-2013, 02:08:20 PM   #34
///M3Fresh
Motorsport
///M3Fresh's Avatar
Reputation: 0 ///M3Fresh is on a distinguished road
Great DIY Swap thread! Needs to be Sticky!
I love my SMG and never had issues thus far but this will be the route I take if she finally fails on me!
CLICK
Jump to top ///M3Fresh is offline   Reply With Quote
Old Thu, May-30-2013, 10:21:53 PM   #35
MP675
Reputation: 0 MP675 is on a distinguished road
Originally Posted by darksideracer View Post
There's a bunch of different ways of coding. I say read up and decided what you want to do. Also follow diys with a grain of salt, most of the time they are not exact and will require some figuring out. But all the answers are online. Just have to look. Winkfp is the fastest I've ever used for programming the dme.
Sent from my SPH-D710 using Tapatalk 2
Exactly. The information is out there, but it's not something you would even want to mess with if you don't understand what you're actually doing. DIY guides should always be taken as guidelines, not as an excuse to do something without thinking.
Thank you for the input, its always appreciated! To my surprise, the process that we used was able to retain previously customized settings.
Thanks for clarifying, I knew I'd mix something up
Jump to top MP675 is offline   Reply With Quote
Old Fri, May-31-2013, 05:06:46 AM   #36
Bashar368
Bashar368's Avatar
Reputation: 0 Bashar368 is on a distinguished road
Can anyone do this in SoCal in the San Fernando valley
2005 IB ZCP - AA 2 HKS - Work Brombachers - 500+ RWHP 91 Octane
Jump to top Bashar368 is offline   Reply With Quote
Old Fri, May-31-2013, 06:11:07 AM   #37
RAZ M3
RAZ M3's Avatar
Reputation: 0 RAZ M3 is on a distinguished road
Awesome write up! This deserves to be a sticky!
6MT - Bilstein PSS9 - CSL Diffuser - CSL Trunk - Varrstoen LM - Rogue El Diablo Muffler
Jump to top RAZ M3 is offline   Reply With Quote
Old Fri, May-31-2013, 10:40:07 PM   #38
MP675
Sure, you can!
Thanks Raz!
Old Sat, Jun-01-2013, 11:04:54 AM   #39
IbrahimM3
Egypt
Dear all,
I will be making my car coding soon and I have searched the threads and what I understood until now is the following. I have to install a manual software in to my DME either by SSS or winkfp , I got the software number from another thread which was 7837779 and then I have to clear all adaptations either by DIS or Ncs expert. I'd really appreciate it if you can confirm the above or tell me if I'm missing something. Thank you in advance.
Old Sat, Jun-01-2013, 12:53:46 PM   #40
cyberlando
cyberlando's Avatar
Originally Posted by IbrahimM3 View Post
Dear all,
Hay you should definetley use Carsoft to clear your adaptations...it's a lot easier if you have the program set up I can help you with the process! The major part of the battle is to make sure all the winkfp files are installed correctly. For me I have an 2002 mt m3 and that's the euro software it seems lke that I flashed to my car.
Engine:
Interior:
Suspension/Handling:
