Old Wed, May-15-2013, 12:32:41 PM   #21
Dal
Dal's Avatar
Reputation: 0 Dal is on a distinguished road
probably best SMG -> 6MT thread yet!!!
you have my thanks!
Jump to top Dal is offline   Reply With Quote
Old Wed, May-15-2013, 01:31:58 PM   #22
Rontgen
Rontgen's Avatar
Reputation: 0 Rontgen is on a distinguished road
Well done!
-Darrell
2001 M5
Jet Black / Black
Jump to top Rontgen is offline   Reply With Quote
Old Fri, May-17-2013, 11:13:15 PM   #23
darksideracer
Reputation: 0 darksideracer is on a distinguished road
very good write up
Jump to top darksideracer is offline   Reply With Quote
Old Fri, May-17-2013, 11:47:41 PM   #24
obryan562
obryan562's Avatar
Reputation: 0 obryan562 is on a distinguished road
Cambodia
great DIY! I cant wait to tackle this in the near future.
INSTAGRAM: 1988MPWR
Jump to top obryan562 is offline   Reply With Quote
Old Sat, May-18-2013, 12:09:11 AM   #25
MP675
Reputation: 0 MP675 is on a distinguished road
Good luck with it! Like I said, its really not that bad. I initially tried to do it over a 3 day weekend, but ran into a few snags like I mentioned and eventually got completely stopped when I realized I forgot to order one of the thrust pins and compression springs. Total time for the mechanical aspect of the job was 6 days start to finish (2.5 full days of work, then four days of doing little things in the evening after work to finish it up). If you run into any problems or have any questions, I'd be happy to help!
Jump to top MP675 is offline   Reply With Quote
Old Thu, May-30-2013, 12:58:07 AM   #26
IbrahimM3
Reputation: 0 IbrahimM3 is on a distinguished road
Egypt
It is an excellent thread, it helped me a lot in my conversion I have just done it in the last couple of days. I finished all mechanic work, bell housing modification and making a place for the gear indicator switch in 3 days. I started the car but i have ses,smg and eml on and i lost most of the engine power this happened after a 15 minute drive not immediately when I started the car, at first I had power and eml was off and I could drive the car to 8000 rpm. I have a part missing in the clutch assembly which is the clutch switch which i will order. The car started without connecting any electric lines because I already had a bypass on the neutral safety switch , the car previously with the smg could have been started while in gear. Now I have no shops here in egypt that have autologic hardware but we have GT1 , so my question is it possible to program the DME by SSS or it must be Ncs expert or other, I also have an ediabas connector and can use inpa or ncs expert. I'll get the missing switch but I need help on how to prgram the dme. Please if there is anyone that could help me with the coding I'd really appreciate it or if you can't please advise who I can contact to help with this.
Thank you.
Jump to top IbrahimM3 is offline   Reply With Quote
Old Thu, May-30-2013, 01:07:25 AM   #27
darksideracer
^ You don't even need any switches at all. Unless you want cruise control and that gear indicator. You can use sss if you can get it to program the dme to a manual tune. When I did it I used a combo of sss and winkfp. Didn't even need ncs expert, but I did go back and check all the coding with ncs. Also you will need ncs to activate the gear indicator on the kombi. I don't think you can activate it any other way.
Sent from my SPH-D710 using Tapatalk 2
Old Thu, May-30-2013, 01:08:08 AM   #28
cyberlando
cyberlando's Avatar
Thank you.
Ask a member named terra or polar they are very good at exactly what your attempting to do its in a thread stickies about dme programming
Engine:
Interior:
Suspension/Handling:
Old Thu, May-30-2013, 04:34:58 AM   #29
MP675
When we did it, we used a combination of NCSexpert, INPA, winFKP and winOLS. I'm not sure that ALL of these were needed, and it may have been done as a matter of convenience depending on which module we were working on at a given time. That sticky thread involves a lot of reading, but it does hold the answers to your questions!
Old Thu, May-30-2013, 06:31:39 AM   #30
darksideracer
There's a bunch of different ways of coding. I say read up and decided what you want to do. Also follow diys with a grain of salt, most of the time they are not exact and will require some figuring out. But all the answers are online. Just have to look. Winkfp is the fastest I've ever used for programming the dme.
