Old Wed, May-15-2013, 05:29:16 AM   #11
see.m3.go
see.m3.go's Avatar
Reputation: 0 see.m3.go is on a distinguished road
Nice write up! Glad to see you got everything up and running
2003 TiAg/Imola SMG to 6MT: AST 4100, Vorshlag Camber Plates, Status Gruppe Headers, Status Gruppe Muffler, Recaro SPG, VAC Floor Mounts, TiAg Kirk Roll bar, G-force 6pt Harnesses, Evolve Tune, TMS Power Pullies, AKG DTM Shifter, Macht Schnell Stage 1 Intake, Hardwired V1, MH Stud Conversion, APEX ARC-8, AKG 75D Subframe Bushings, 95A Diff Bushings, BMW Motorsport 4.10 diff
My Journal
Jump to top see.m3.go is offline   Reply With Quote
Old Wed, May-15-2013, 05:46:22 AM   #12
///MATTY C
///MATTY C's Avatar
Reputation: 0 ///MATTY C is on a distinguished road
Quick question. When I have my car reflashed with the 6 mt software, would I lose my Dinan software? I have upgraded throttle bodies and am just curious if this would cause an issue if it were lost per say? Anyone know?
Jump to top ///MATTY C is offline   Reply With Quote
Old Wed, May-15-2013, 05:48:16 AM   #13
Abad46
Abad46's Avatar
Reputation: 0 Abad46 is on a distinguished road
GREAT write up!
to you!!
Jump to top Abad46 is offline   Reply With Quote
Old Wed, May-15-2013, 05:50:47 AM   #14
Abad46
Abad46's Avatar
It can be done without losing your Dinan software.
Old Wed, May-15-2013, 06:11:41 AM   #15
king-rb
dammmmmmmmit!
king-rb's Avatar
Germany
Awesome write up! I will be reading this 3 or 4 more times before I tackle my swap
Old Wed, May-15-2013, 07:15:41 AM   #16
///MATTY C
///MATTY C's Avatar
By the way....great write up again. Thank you very much!!!!
Old Wed, May-15-2013, 12:06:14 PM   #17
MP675
Reputation: 0 MP675 is on a distinguished road
Confirmed
If you ever get a chance down the line to sort of "summarize" the parameters you needed to change for each module to get this to work, I'd be happy to add it to the coding section in the OP! I know that anyone capable of doing the coding has probably already spent hundreds of hours reading and could figure it out, but its always nice to not have to search when you actually need something to refer to! For now, I think I'll make it more of an FAQ section. All I remember is "nicht_aktiv" for the SMG LCD display when coding the cluster
Thanks again guys, I hope this helps someone!
Jump to top MP675 is offline   Reply With Quote
Old Wed, May-15-2013, 12:16:42 PM   #18
beomoua
beomoua's Avatar
Reputation: 0 beomoua is on a distinguished road
Glad you got done. Good 4 you.
Jump to top beomoua is offline   Reply With Quote
Old Wed, May-15-2013, 12:24:11 PM   #19
4BIDDEN
Reputation: 0 4BIDDEN is on a distinguished road
South Africa
Hi,nice write up.I have done the conversion but instead off coding the dme can i replace it with a 6mt ///M3 dme and ews?
Jump to top 4BIDDEN is offline   Reply With Quote
Old Wed, May-15-2013, 12:29:34 PM   #20
MP675
Thanks again for all of your help
I'm not entirely sure, but I do know that even after replacing those, you will still need to code your cluster and DSC module. I think having everything reflashed is both the best and most economical way of doing things. I'll let an expert answer this one more clearly!
