Closed Thread
Old Sun, Jan-16-2011, 09:24:09 PM   #1
deilenberger
deilenberger's Avatar
Default DIY References
One of our members, "suaveflooder" (Brian) put together a posting listing many references to DIY sources of info - from both this site and others on the web. There was a request that it become a sticky - but since other people kept adding extranious posts to the thread, that wasn't practical in the original thread. I discussed this with Brian - and he made up a clean version of all the references that will now become a sticky and CLOSED thread. If you have more references to add to the thread, please send a PM to SuaveFlooder, and after looking it over - if it's suitable, he'll send it to me for inclusion in this thread.
Please take note - the moderators and owners of M3Forum take no responsibility for any damages caused by the use of these DIY's. If you decide to use one - it's at your own risk.
That all said - here is the listing (and thanks MUCH to SuaveFlooder!)
BASIC INFO/MAINTAINANCE:
Thinking about buying an M3? Here's a list of DIY resources and links:
http://www.euroaddiction.net/forum/s...ead.php?t=2835
http://www.m3forum.net/m3forum/showthread.php?t=189390
General service (oil change intervals, service I, service II, etc.)
http://m3forum.net/m3forum/showthread.php?t=190111
Valve adjustment
http://www.m3forum.net/m3forum/showt...&highlight=DIY
http://www.m3forum.net/m3forum/showthread.php?t=347929
Spark plug replacement
Differential Fluid change
Belt replacement
http://www.m3forum.net/m3forum/showthread.php?t=348838
Fuel filter change
Coolant flush (post 29)
http://www.m3forum.net/m3forum/showt...ush+diy&page=3
Another coolant flush:
http://blankowski.com/Cars/m3_coolant_change/ - Thanks to Doug (dhodges76)
Power steering flush
http://forum.e46fanatics.com/showthread.php?t=696928
Transmission fluid change (SMG)
http://www.m3forum.net/m3forum/showt...light=SMG+pump
Transmission fluid change (manual)
http://m3.madrussian.net/diy_rp_tranny_fluid.shtml
Cooling System Rebuild (DIY)
http://www.m3forum.net/m3forum/showthread.php?t=354281
Coolant Change DIY
http://www.m3forum.net/m3forum/showt...=coolant+flush
General DIY's - some are illustrated, oil change, coolant flush, fuel filter, plugs, dash-whine, diff fluid, headers, vanos-solenoid (thanks to Tim Astro!]
http://mclub.la/library/e46/diy/
MOTOR:
Finding a vacuum/boost leak
http://www.m3forum.net/m3forum/showthread.php?t=345622
Constant pressure valve replacement
http://www.m3forum.net/m3forum/showt...hlight=cpv+diy
And another CPV replacement DIY (thanks to Heckafunctional)
http://www.m3forum.net/m3forum/showthread.php?t=358941
Coil/Coil pack diagnosis and replacement
Intake manifold removal (SMG)
Vanos Hub and Bolt replacement - detailed DIY by SYT Shadow:
http://www.m3forum.net/m3forum/showthread.php?t=411224
(Thanks to PedalOnTheRight for pointing it out to me..)
Hogger 453 vanos videos
*part one: http://m3forum.net/m3forum/showthread.php?t=356317
*part two: http://www.m3forum.net/m3forum/showthread.php?t=356328
*part three: http://www.m3forum.net/m3forum/showthread.php?t=357268
*part four: http://www.m3forum.net/m3forum/showthread.php?t=357287
*part five: http://www.m3forum.net/m3forum/showthread.php?t=357297
Vanos bolt replacement
Vanos solenoid replacement
Vanos R&R without a timing tool
http://www.m3forum.net/m3forum/showthread.php?t=371045
Everything you ever wanted to know about Vanos.. all in one place!
http://www.m3forum.net/m3forum/showthread.php?t=545367
Fan Clutch Removal
http://www.m3forum.net/m3forum/showt...ght=fan+clutch
Starter replacement
http://www.m3forum.net/m3forum/showthread.php?t=310634
Pulley replacement
http://www.turnermotorsport.com/page...ppk_detail.pdf
http://www.m3forum.net/m3forum/showthread.php?t=347841
High pressure power steering hose replacement
http://www.m3forum.net/m3forum/showthread.php?t=252164
E46 M3 detailed water pump replacement, thermostat replacement, & coolant flush
http://www.m3forum.net/m3forum/showthread.php?t=395314
E46 M3 detailed ignition coil replacement and spark plug replacement
http://www.m3forum.net/m3forum/showthread.php?t=395730
E46 M3 (S54) detailed valve adjustment
http://www.m3forum.net/m3forum/showthread.php?t=450097
DIY Injector Service
http://www.mepeh.com/bmw-s54-injecto...build-kit.html
S54 Injector Replacement
http://www.pelicanparts.com/techarti...eplacement.htm
Thanks to Dan, 01M3Fan for the two above references!
EXHAUST:
Header install
http://m3forum.net/m3forum/showthread.php?t=116770
O2 SIM install
Exhaust camshaft position sensor replacement
http://m3forum.net/m3forum/showthread.php?t=328247
Exhaust/Muffler Removal/Installation (thanks to user NY!)
http://www.m3forum.net/m3forum/showthread.php?t=457478
FUEL/IGNITION:
Fuel pump replacement
http://www.m3forum.net/m3forum/showthread.php?t=283580
SUSPENSION/DRIVETRAIN:
SMG Trouble shooting facts
Emergency brake adjustment
http://www.csfrancis.net/BMW/pbdiy.pdf
Subframe reinforcement (epoxy/foam method)
Subframe reinforcement, epoxy method (pic heavy)
http://m3forum.net/m3forum/showthread.php?t=427369
and Subframe reinforcement - foam method.
http://www.m3forum.net/m3forum/showthread.php?t=421501
Bushing replacement
Bushing removal tool DIY
http://www.m3forum.net/m3forum/showthread.php?t=347682
Differential bolt replacement
Steering Coupler replacement
SMG to 6 speed conversion
SMG paddle installation
http://www.m3forum.net/m3forum/showthread.php?t=172278
Clutch installation (SMG)
http://www.m3forum.net/m3forum/showthread.php?t=305341
Start your car without pushing in clutch DIY
http://m3forum.net/m3forum/showthrea...r+w%2Fo+clutch
Coilover install
http://m3forum.net/m3forum/showthread.php?t=179844
Guibo (flex disc) replacement
http://www.m3forum.net/m3forum/showthread.php?t=301477
Rear Trailing Arm Ball Joints (all 4)
http://www.m3forum.net/m3forum/showthread.php?t=376046
Replace a front wheel bearing
http://redeyegarage.com/blogs/news/9...wheel-bearings
BODY/EXTERIOR:
Exterior Window Trim Replacement - Coupe
http://forum.e46fanatics.com/showthr...ht=window+trim
Xenon headlight assembly removal
Rear quarter window seal/trim replacement (thanks to Jmsimmons1 for passing this along!)
http://www.m3forum.net/m3forum/showthread.php?t=373831
Subframe reinforcement, bushing replacement gear oil change. VERY detailed - lots of pics and videos.
http://www.m3forum.net/m3forum/showthread.php?t=464146
BODY/INTERIOR:
Interior trim removal
http://www.e46fanatics.com/howto/how...hp?howto_id=25
Steering wheel trim removal
http://www.my330i.com/mod23.php[/QUOTE]
Replacement Rain Sensor pads and components (Thanks to Itsablur!)
http://www.m3forum.net/m3forum/showthread.php?t=461209
BRAKES:
Great DIY for brake lines, pads and bleed the system from member "NY":
http://www.m3forum.net/m3forum/showthread.php?t=436047
MISC:
Nothing to see here.. move along, move along..
Updated 03/06/14
Last edited by deilenberger; Fri, Aug-19-2016 at 03:58:32 PM. Reason: Added more.. 03/06/14
Jump to top deilenberger is offline
Closed Thread
Discussing DIY References in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
