Old Fri, May-05-2017, 02:49:36 AM   #491
hcbeck2689
Reputation: 0 hcbeck2689 is on a distinguished road
Default Re: e46 M3 Tire Sizing Thread
Originally Posted by swimNdrive View Post
My question is what will be the best tire sizes for these rims to fit to the car?
The best size, for performance, would be around .5" of stretch on the width and around stock radius. Tire rack measures the tire width of every single tire that they sell, a very useful piece of info.
You might want to do a test fitment of the wheels to see how they fit compared to what you have. That should tell you how the offset is and if they will indeed fit the correct sized tires.
Jump to top hcbeck2689 is offline   Reply With Quote
Old Fri, May-05-2017, 11:26:41 AM   #492
This is a great thread! Very useful information.
Recently my son and I bought a new to us 03.5 E46 M3. We love it. We checked the VIN decoder, this car came with 19" rims from the factory. However, the tire sizes came with the car are bigger than stock, front 245/35/19, rear 275/30/19. After putting on a new set of tires with the same sizes, the car drives and handles fine, and looks great. The car has the stock size suspensions.
The other day, my son bought a set of used Dinan Champion rims. He loves the rims. The markings inside of the rim says: 19X9J48 for the front, 19X10JCH35 on the rear. Does this mean on the front offset E48 and on the rear offset E35? I could not find any information on these rims. My question is what will be the best tire sizes for these rims to fit to the car?
The rims came with a set of Yokohama Advan Nedva Ad08R mounted, 265/35/R19 on the front and 295/30R19 on the rear. The tires still have good live to them, but they are too big to put on our car. I do not want to modify the car to fit the tires, it does not make sense to me to do that. Is it possible to use spacers to make the tires and the rims to fit the car? If so what will be the right sizes? Thank you for your advises
Dinan speced those wheels around the concept of running 265/30/19s up front and 275/30/19s in the rear.
You will almost certainly rub in the rear with the tires on there now. No spacer setup will address that-- the offsets start out good. The tires are just too big.
Old Tue, May-16-2017, 07:50:55 PM   #493
lavatoad
Reputation: 0 lavatoad is on a distinguished road
I've been searching for a clear answer if running 255/40r18 on 18x9.5 et35 up front with stock suspension will rub. Best i could find is "maybe, depending on tire".
Does anyone have experience with this setup on stock struts/springs/camber? Is extra camber (pin mod) or a spacer required?
Sent from my SM-G935P using Tapatalk
2002 BMW M3 - 6MT
1995 BMW M3 - 5MT (Sold)
Jump to top lavatoad is online now   Reply With Quote
Old Mon, Aug-21-2017, 02:53:54 PM   #494
Road Racer 1995
Reputation: 0 Road Racer 1995 is on a distinguished road
Originally Posted by ///Marini View Post
Contact Patch:
Now we need to clear up a huge misconception. Here goes:
A 225/45/18 and a 285/35/18 at the same tire pressure (PSI) have the SAME contact patch! You read that correctly. Given two tires at the same pressure, the contact patch is the same. The benefit to wider tires is that you can run them at a lower pressure without overworking them. So… once you've done all your crazy tire upsizing, if you run the same pressure you were running before, you haven't gained any grip! Crazy, right?
http://performancesimulations.com/fa...on-tires-1.htm
[/QUOTE]
Who believed this back in 2009? Very strange to say this! In fact, just flat out wrong. A 225 and a 285 width tire will never have the same Contact Patch (length or width). You can increase or decrease tire pressure of either size, the CP will never be similar to each other. I work in tire R&D. This is basic info. To say a 225 & a 285 will have the same CP is really wrong. And, of course you will gain more grip with wider tires. Talk to some SCCA Solo runners. Why would they go wider with no benefit?
Jump to top Road Racer 1995 is offline   Reply With Quote
Old Mon, Aug-21-2017, 03:13:59 PM   #495
Road Racer 1995
I decided to upgrade my tires. A nail in my rear tire made the decision for me - they wouldn't plug because of the inside camber wear to too great. I was running A/S tires. Wanted to bump up to summer performance tires. So, I went with the UHP ADVAN Neova AD08R. Sizes were limited so I had to choose the 235/35R19 & 265/30R19 combo. I had the stock sizes before. This size set-up is mentioned quite often in here. But I can't find any mention of the negative items ppl get by using them like I am having now. 1) Speedo reads faster 2) the TDMS light stays on. TDMS=Tire Diameter Monitor System.
Since this gen car doesn't have air press sensors. It just monitors the rolling diameter. So, I have these two problems. Keeping the tires, can these issues be corrected? Stock Dia. = 26.1" = 82" circ. New Dia. = 25.4" = 79.8" 2.7% smaller in diameter or circumference. I thought anything under 3% was a minimal effect. That turned out to be wrong! (Of course there is an item #3 = higher RPM in top gear. And that can't be changed, I know.)
Old Mon, Nov-27-2017, 01:34:04 AM   #496
ggrslc
Reputation: 0 ggrslc is on a distinguished road
You can run 235/35 F & 265/30 R on 19” rims all day long with no problems. If the TPMS light comes back on after a proper reset, you have another problem.
Jump to top ggrslc is offline   Reply With Quote
Old Mon, Dec-18-2017, 01:29:38 PM   #497
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Just ordered bbs lms 19x9 et 27 front and 19x10 et 25 rear.
Im running with koni sport with eibach sport springs.
Im planning on getting the michelin pilot sport 4 or super sport for a daily car
Just want to ask if what do you guys think the best combination of tires 245/35 front 275/30 or 35 rear or 255/30 front 285/30 rear? Hopefully it wont rub. I bought a set of ecs rear camber arms so i can adjust the camber because now it doesnt look bent but i only get like .3-.7 negative camber
Jump to top scoopy128 is offline   Reply With Quote
Old Fri, Jan-12-2018, 06:27:14 PM   #498
Gerryriccio
Reputation: 0 Gerryriccio is on a distinguished road
great thread, thank you for everyone doing a lot of research. Ive been wondering something im running Ohlins road and track suspension with cylindrical front springs with 3.5 negative camber, Apex ARC-8 18x9.5 ET22 wheels and 265/35/18 Hankook RS-3 tires. Ive had to add a 5mm spacer in the front to prevent rubbing on the spring perch. Ive recently purchased the same wheels but with ET35 to run a true slick race tire. ive mounted the wheel and it looks very close to the spring perch w/o the spacer. Any thoughts on this?
Jump to top Gerryriccio is offline   Reply With Quote
Old Fri, Jan-12-2018, 06:59:10 PM   #499
I moved my top spring perch up (have to keep enough spring travel) and got a shorter spring, run on a higher perch location, to get the perch above the tire.
Old Sun, Jan-21-2018, 06:23:20 PM   #500
mainstreamer00
mainstreamer00's Avatar
Reputation: 0 mainstreamer00 is on a distinguished road
I'm in the process of spec-ing new tires for my ZCP wheels.
With regards to the rear, many of my preferred choices (street-category UTG200) are difficult to find in the recommended 265/30/19 - aspect ratio being the rare point.
I'm probably going to run a R 265/35/19, which is marginally taller.. Anyone have any experience here? I know it's been quite well documented on the forums, and deemed no problem. Does anyone have any photos or confirmation?
Jump to top mainstreamer00 is offline   Reply With Quote
e46, sizing, thread, tire
Discussing e46 M3 Tire Sizing Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
