Old Thu, May-13-2010, 01:33:08 AM   #31
Originally Posted by GR///M3 View Post
i like this thread ... thanks for starting it Obioban.
for an 18" wheel, it looks like 255 and 285 would be the best size choice since it's closest to OEM ... a little cautious about the rear circumference being .6 inch smaller than OEM, but that's really not a lot. my question about this size set is:
would there be rubbing issues with an OEM suspension ? would they look really awkward when they are mounted on an 8.5" (255) and 10" (285) ? current OEM setup with 225 on 8" and 255 on 9" the fronts look to be a bit stretched (slanted sidewall), while the rears have a nearly vertical side wall
255s fit on 8.5s well enough.
Rubbing will be determined by offsets.
Old Thu, May-13-2010, 01:40:08 AM   #32
Fuerza
strength
Reputation: 0 Fuerza is on a distinguished road
Originally Posted by normcaldwell View Post
Member M3R1 had 255/285 mounted on 8.5 and 9.5 wheels. Maybe the pics in these threads will at least give you some idea about how it looks and handles.
http://www.m3forum.net/m3forum/showthread.php?t=206823
http://www.m3forum.net/m3forum/showthread.php?t=216851
His car was slightly lowered with the Dinan suspension, and he sold the tires not long after he posted the above thread.
I think he was getting a bit of rubbing, but I'm not sure where; probably on the fender, vs inside.
Those look incredible! Was he rubbing on the fronts or rears? or both? A lot of aftermarket wheels come in 10.5 rears and that IMO seems too wide! With these being 9.5 rears I would think that wouldn't be much of an issue, but it seems like 285's are just to wide for our cars.
Jump to top Fuerza is offline   Reply With Quote
Old Thu, May-13-2010, 02:12:09 AM   #33
normcaldwell
Reputation: 0 normcaldwell has a spectacular aura about
He sold the tires a month after installing them.
http://www.m3forum.net/m3forum/showthread.php?t=217797
In the thread, post #29, he indicates a bit of rubbing, and I interpret it to mean the rears.
His wheels were the very same ones I have; Volk TE37 18x8.5 ET35, 18x9.5 ET22.
It appears to me that a very mild drop, with a bit more negative camber (and all that goes along with a proper 4 wheel alignment), and the 255/285 combo would not rub.
By comparison, I'm running stock sizes 225/255 on the same wheels.
I like how the car feels on the street with this setup.
One of the main reasons I have 18" Volks is weight (as in not much weight), along with strength, easy to wipe clean, and I like how they look.
Jump to top normcaldwell is offline   Reply With Quote
Old Thu, May-13-2010, 02:37:32 AM   #34
mosportM3
Reputation: 0 mosportM3 is on a distinguished road
Very Nice thread!
Very informative and puts people at ease when trying to play with tire sizes and rims and what to know.
Jump to top mosportM3 is offline   Reply With Quote
Old Thu, May-13-2010, 07:42:26 AM   #35
Mr. Shadow
Mr. Shadow's Avatar
Reputation: 0 Mr. Shadow is on a distinguished road
He rubbed because the offset on the rears were ET22 which is very aggressive for a 9.5 wheel. You want no more than ET25. I ordered my volks with a 9.5 ET28 so I can run up to a 285 with no rubbing.
Jump to top Mr. Shadow is offline   Reply With Quote
Old Thu, May-13-2010, 12:30:01 PM   #36
DuncanS
Reputation: 0 DuncanS is on a distinguished road
United Kingdom
Originally Posted by drmillerm3 View Post
+1. If what you say about dsc in regards to smaller rear tire diameter is true, why is the optional oem 19" size 245/35F 275/30R, vs 245/35 285/30. considering the 275/30 is near an inch smaller the the 245/35?
So 245/285 is more optimal than 245/275, correct. I need to replace my rears. I have 275/30 right now and they do look a bit shorter than the fronts.
Jump to top DuncanS is offline   Reply With Quote
Old Thu, May-13-2010, 01:16:10 PM   #37
theBeachBoy
Reputation: 0 theBeachBoy is on a distinguished road
255/35/19, circumference: 81.8"
and
285/30/19, circumference: 80.8"
in theory, 295/30/19 gets circumference of 81.6, closer to 81.8 and only .2 off like the stock setup.
but I guess 295 is too wide?
Also, I don't know about car tires, but for trucks, the real height is way different from one brand to another (diameter), I'm quite sure it's also different on car tires?
Jump to top theBeachBoy is offline   Reply With Quote
Old Thu, May-13-2010, 01:47:15 PM   #38
Width tends to vary from one brand to the next. Height tends to be more consistent.
To you two considering 285 and 295 rears (especially 295 guy)-- you better be really careful with your offsets. Otherwise you're going into run into space issues, fast!
Old Fri, May-14-2010, 02:48:15 AM   #39
DuncanS
United Kingdom
I'm running Volk 9.5f and 10.5 rear. Cant remember the offsets, but they are the usual for the 9.5/10.5 setup. 275 looks a bit stretched.
Old Fri, May-14-2010, 03:12:07 AM   #40
TRACK-CZAR
TRACK-CZAR
TRACK-CZAR's Avatar
Reputation: 0 TRACK-CZAR is on a distinguished road
I created the attached spreadsheet with calculations of tire sizes in 18" and 19" diameters.
GONE: 2005 IB ZCP,
NEW: 1997 M3 Sedan, Track Car
Jump to top TRACK-CZAR is offline   Reply With Quote
e46, sizing, thread, tire
Discussing e46 M3 Tire Sizing Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
