Old Mon, May-10-2010, 02:05:05 PM   #11
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
aaannnddddd he's back, great info Ian! Thanks.
Old Mon, May-10-2010, 08:58:05 PM   #12
Mr. Shadow
Mr. Shadow's Avatar
Reputation: 0 Mr. Shadow is on a distinguished road
I'd run a 285 in the rear, but PS2's don't come in 285/35 according to tirerack.
Jump to top Mr. Shadow is offline   Reply With Quote
Old Mon, May-10-2010, 10:33:01 PM   #13
t3stman
t3stman's Avatar
Reputation: 0 t3stman is on a distinguished road
Thanks for the info! This should be a sticky
2005 ///M3Alpine White with Imola Red Nappa Leather, 19", NAV, ZCP Competition Pck, and SMG
Cosmetic Mods: OEM CSL Bootlid, OEM CSL Diffusor, OEM Euro Fire Extinguisher, Premium Clear Bra, EAS Aurora Angel Eyes 6000k, EAS CF Titanium seat outer trims, EAS CF Titanium upper trim, EAS CF Titanium SMG Dome, Ice-Link, Painted Matching Bumper Reflectors, Painted Hood Grill, 40% Huper Optik Tint, and Ultimate pedals.
Performance Mods: VFE Stg2, SS stepped headers, cats, x-pipes, and NOW KW v3
91 Pump - 478.86 HPs
MS-109 - 511.56 HPs
Future Mods: Eibach or GC swaybars, BBK, and Hard wired V1
Jump to top t3stman is offline   Reply With Quote
Old Mon, May-10-2010, 11:29:21 PM   #14
SilberFuchs
Visca el Barca!
SilberFuchs's Avatar
Reputation: 0 SilberFuchs is on a distinguished road
Argh, that article does have me bothered. The problem I'm having is that the data in there doesn't jibe with what I've seen in reality.
-lateral Gs don't drop with wider tires without a decrease in tire pressure
-drag racers run super low pressures on the rear
-you can easily and noticeably shift the balance of a car by tweaking tire pressures.
.... but I am considering rewording that section now. I certainly don't want to mislead people and post something that isn't true....
Edit: This is where that test gets really werid. They actually get less deflection and lower tire pressure than high. Something must be amiss...
Ian, I am certainly no expert on tires and pressures, but I'm not quite sure your statement about different tire widths at the same tire pressure leading to the same grip is quite correct (UNLESS a higher tire pressure is required for a wider tire bearing the same load to get the same full thread contact patch). My understanding (albeit limited) about tire pressures is that it's about optimizing even and full contact patch for a given axle load, thus leading to maximal thread contact patch and even tire wear. For example, since the M3 has a near perfect 50/50 weight ratio, the front and rear tire pressures should be about the same, unless one wants to dial more or less understeer/oversteer by messing with inflation pressure. Also, the tire pressure is dependent on the driving conditions -- in other words, while a certain pressure may be ideal for mostly straight line driving (highway, slow city, etc.), it may be too low for an autocross event or high-speed cornering at the track which require higher pressures due to high lateral weight shifts (thus, the chalk test to get the optimal pressure) so as not to ride on the shoulders of the tires.
2005 TiAg/Blk M3 Coupe (6MT, Xenon, HK sound)
///Mods - performance: OE CSL airbox w/ MAP sensor, OE CSL headers (Swaintech ceramic coated) & cats, Supersprint resonated X-pipe & "Street" muffler, Schrick 280/272 cams & DLC rockers, SAP delete, ECU tune, OE CSL cabin air filter housing, Rogue Octane SSK & transmission mounts, ZHP shifter knob, hollowed CDV (Zeckhausen), Mason/GSP clutch pedal, Volk Racing CE28N 18x8.5F/9.5R wheels with 245/275 tires
///Mods - appearance: OE CSL front bumper & trunklid & diffuser, piano black kidneys & gills, Depo smoked corners, OE short center console with Euro tray, AC Schnitzer aluminum pedals, 35% tint
Jump to top SilberFuchs is offline   Reply With Quote
Old Tue, May-11-2010, 04:09:50 AM   #15
I have eliminated the part of the post about contact patch/tire width. I don't know enough to know which side is correct, and I don't want to propagate false information... so it's deleted.
Old Tue, May-11-2010, 12:30:01 PM   #16
jph28
Back in 'Merica
Reputation: 0 jph28 is on a distinguished road
I am not even close to an expert in this stuff, but I do know that the standard "FrictionForce = mu*NormalForce" (where mu is the coefficient of friction) equation is quite invalid with tires. Specifically, this equation (Amonton's 2nd Law) is not valid for elastic, deformable materials because they generally have nonlinear mu. Plus, there are issues of tire heat management that will generally benefit wider (street) tires.
There is an interesting thread here about this topic (I found this in a Google search just now, I'm not a forum member )
This thread is and will be an excellent resource for the forum for sure, but the low-level details of the physics of transient/dynamic tire traction are probably (hopefully for me, since I don't quite grasp them!) beyond the scope Thanks for posting this, hopefully we'll all learn something and the number of "tire threads" will go down!
One thing I will add about this topic is that a good, high-performance tire (i.e., high coefficient of friction) will out-grip and wider, lower performance tire just about every time in dry conditions. The first consideration in trying to gain traction should be finding a high-quality performance tire, not just getting the widest "budget" tire that will fit under the fenders...
Current - 2018 M2, 2015 328d Wagon, 2018 Tahoe
2004 SilverGrey 6MT Sold
Past - '02 M5 / '04 M3 / '12 VW JSW TDI / '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T
Jump to top jph28 is online now   Reply With Quote
Old Tue, May-11-2010, 06:03:28 PM   #17
eas
eas's Avatar
Reputation: 0 eas is on a distinguished road
Such good information, thanks Obioban!
Customer Service | european auto source (eas)
email: info@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 | fax: 714.908.1796
Blog | Facebook | YouTube | Flickr
Jump to top eas is offline   Reply With Quote
Old Tue, May-11-2010, 06:23:28 PM   #18
Draddy
Draddy's Avatar
Reputation: 0 Draddy is on a distinguished road
great information.
this is why myself and many others i'm sure, visit this site. In reality, this doesn't mean anything for most of us who don't push to the extremes, but it's just really cool to know about, and a great discussion (above with the contact patch situation).
P.S. I have wider tires just because it looks cool.
My Car (sold) -- Old M3
Jump to top Draddy is offline   Reply With Quote
Old Tue, May-11-2010, 06:32:31 PM   #19
M_Threezy
M_Threezy's Avatar
Reputation: 0 M_Threezy is on a distinguished road
Taiwan
Ian,
This is phenomenal. Thank you for the great information!
Jump to top M_Threezy is offline   Reply With Quote
Old Wed, May-12-2010, 06:31:09 PM   #20
DuncanS
Reputation: 0 DuncanS is on a distinguished road
United Kingdom
245/35/19, circumference: 80.9"
and
275/30/19, circumference: 80.1"
285/30/19, circumference: 80.8"
Would a 285/30/19 be a better match to a 245/35/19?
Jump to top DuncanS is offline   Reply With Quote
e46, sizing, thread, tire
Discussing e46 M3 Tire Sizing Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
