Old Mon, Jul-06-2009, 07:04:45 PM   #41
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
Originally Posted by jyrbba View Post
Got a very similar problem as the post above. The car works for a while, but after ~2-3hrs of intense driving SMG(gear) and engine lights lid up. I've checked the error memory for both engine and smg and they always come up with the same errors (BMW INPA).
177 - Mil external info
Mil requirement by SMG
Error present
Static Error
56 - Switching on time of hydralic unit
Implausible value
sporadic error
That doesn't really mean s**t to me. I already swapped the relay, and almost thought it fixed when, worked well for almost 3 hours of hard city circuit But then BOOM lights up and dropping out of gears to N/0.
Sounds just too weird to be the pump, since it works great until it actually starts working bad I've checked the smg fluid, and it was like ~70% to the max line, and the car had been sitting for few days. Is this normal? Cause imo the problem seems to happen when the car heats up properly.
Here is the exact error codes if anyone is interested:
56 Switching-on time of hydraulic unit
Error Frequency : 1
Error Occured 1. times at:
Current kilometres 90950.00 km
environmental temperature 14.00 grad C
Voltage supply Ubatt 13.00 V
Hydraulic pump state 1.00 0/1
actual hydraulic temperature 76.00 grad C
hydraulic pressure of raw data 79,63 bar
clutch state 1.0 closed
gearbox state 0.00 shifted
engine speed by CAN 2108.00 1/min
sensor voltage supply B 5.01 V
And engine...
177 Mil external info
Error frequency: 1
logistic counter: 40
Engine speed 960.00 rpm
relative filling 12.00 %
cooling water temp 85.00 degrees C
Lambda adaptation offset 1.82 ms
aufgetreten vor (rel. BZ) 0.10 h
MIL-requirement by SMG
Error Present
Static Error
Ideas anyone?
We just had a car come in and it had the same faults, the pump was not holding pressure.
I took off the pressure accumulator replaced the o-ring and reinstalled everything and pressurized the system to see if it would, but no luck... unit still would not hold pressure. Disassembled the hydraulic unit to see if I can find some sort of failed check valve, but nothing to be seen.
I still haven't had time to upload all those pics and make a post.
Jump to top Tonester is offline   Reply With Quote
Old Mon, Jul-06-2009, 08:45:14 PM   #42
NC03M3
'05 M3 SMG
Reputation: 0 NC03M3 is on a distinguished road
Referring to below:
No noise from the pump when unlocking the car. Transmission will not engage any gear.
If you've already replaced the relay and there's still no noise from the pump, the hydraulic unit has likely failed.
I just noticed that there is no hydraulic noise when unlocking the door - however, the car drives. I have noticed only in the last week that the gearbox kind of slurs the shifts even in S5 instead of the ballistic thud-thud.
Any ideas? I will be going in to the dealer this week for an Inspection I.
My car is an '05 with 23,000 miles.
Cheers!
PFitz
Jump to top NC03M3 is offline   Reply With Quote
Old Mon, Jul-06-2009, 09:18:03 PM   #43
m3 hal
that is odd, is the car completely cold when this happens? I could see it not happening if it was recently shut off and still holding some pressure but a car that has sat overnight should make the buzzing noise I think...
Jump to top m3 hal is online now   Reply With Quote
Old Mon, Jul-06-2009, 10:24:02 PM   #44
yaja23
M Addict
yaja23's Avatar
You have already replaced the relay?
Referring to below:
PFitz
Old Tue, Jul-07-2009, 09:02:02 PM   #45
M3hitman
Reputation: 0 M3hitman is on a distinguished road
United Kingdom
I have had a nightmare with the so called garage I took my E46 M3 to.
I had a series of lights going on SMG....intermitant cut outs and eventually complete engine cut out on the highway home in June 09, and ended up getting transported to a garage registered with the Office of Fair Trading, meaning it has to abide by rules to give good honest service to customer.
Well its taken 3 weeks for them to tell me its a clutch problem...SMG! I then asked what it will cost and it then took another 1 week to tell me a 3000 quote/estimate. I didnt even get a low-down on the actual problem. Little does this guy know that I am well read in the M3 and I asked relevant Q's which I got rubbish answers to....I was told the gear box needed removing!!!!
Am I the only one but do these mechanics think they are clever!!!
I eventually asked him for the part number.....infact I found out the only part that requires replacing it the pressure accumilator PN.21532229716...which costs 400 brand new...So why quote for the whole SMG pump 2000..
The way to get to the pump....from the front of the car..no gearbox removal!!!so why charge me more?
As you can tell I am furious with these guys... Can anyone help add to my predicament....They have had my car for over 1 month now!!!
Jump to top M3hitman is offline   Reply With Quote
Old Tue, Jul-07-2009, 09:13:05 PM   #46
m3 hal
sounds like they aren't very familiar with SMG and/or they are trying to rip you off, can you take the car to another shop?
Old Wed, Jul-08-2009, 10:55:55 AM   #47
M3hitman
United Kingdom
Hi Hal,
I think they dont want to admit they know nothing....worse still they want to add to my costing for their fumbling around with my car. I tried to take the car to someone else but they quoted me $$$ for the investigation work etc....
I am begining to think it would be better to go direct to the dealer...even though it costs more...
Old Wed, Jul-08-2009, 04:46:32 PM   #48
jyrbba
Reputation: 0 jyrbba is on a distinguished road
I took off the pressure accumulator replaced the o-ring and reinstalled everything and pressurized the system to see if it would no pressure.. no luck. Disassembled the hydraulic unit to see if I can find some sort of failed check valve, but nothing to be seen.
Ok, good to know incase the the connecting line + fluid replacement doesn't solve my problems. But I'm pretty convinced that it's the fluid.
Jump to top jyrbba is offline   Reply With Quote
Old Wed, Jul-08-2009, 11:06:49 PM   #49
bmw_for_life
Reputation: 0 bmw_for_life is on a distinguished road
what do you mean by 'new box'?because i am having the same problems
Jump to top bmw_for_life is offline   Reply With Quote
Old Thu, Jul-09-2009, 12:08:57 PM   #50
M3hitman
United Kingdom
Thumbs down
Get a load of this..
I need a new part for my m3. My garage cant/wont compromise and have quoted me for a new SMG pump and accumulator at 1500 plus VAT.
I try and find the part reconditioned and true its a hard part to find...but then I get the part that needs replacing from the dealer...turns out the part number is the pressure accumilator only...cost 350...!
I confirm this with the garage and yes its the accumilator only...So I then try to get the part from a BMW dealer...As soon as they find out I am a member of the so called public...." sorry we dont sell to the public"
Not really a problem as I can get the part from germany direct but there is a recession on...the garages could do with opening their eyes and get the extra custom!!!!
What pees me off is the garage could do all this but it wont/cant/not bothered!!!
Why...???
faq, smg, troubleshooting
Troubleshooting Codes AirDoc E36 M3 (1992-1999) 0 Sat, Nov-17-2007 03:49:53 AM
Troubleshooting a problem ----> HELP ! RoadShreader E36 M3 (1992-1999) 43 Sun, Dec-31-2006 07:05:57 PM
Eclipse Troubleshooting crazy32184 E36 M3 (1992-1999) 7 Thu, Jun-09-2005 07:03:15 AM
HELP PLEASE!!! Troubleshooting my ///M! M3nEwBoOtY E36 M3 (1992-1999) 6 Sun, Apr-03-2005 04:37:52 PM
Discussing SMG troubleshooting FAQ in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
