Old Sat, Dec-22-2007, 02:23:23 AM   #41
DirtySpoon
Dirtiest M3
DirtySpoon's Avatar
Reputation: 0 DirtySpoon is on a distinguished road
Yayo! been needing this!
Jump to top DirtySpoon is offline   Reply With Quote
Old Sat, Dec-22-2007, 02:34:23 AM   #42
Need4Spd
Need4Spd's Avatar
Reputation: 0 Need4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond repute
I was under the impression that we had the metal impeller water pump and should be okay... but I could be wrong. Any input here, JeST? I swapped out the water pump and thermostat on the e36 preventatively, but was going to skip it on the e46.
e36 generation was plastic, then they went to metal, which also failed prematurely, and then back now to plastic, I've been told. Supposedly they fixed the early design. Just like they supposedly fixed the final stage resistor, but now are on yet a different generation. Hopefully the new water pump design will last.
Past car: '05 M3 'vert, 6MT, custom 18" RAC RG63 Hyperblack monolites, Continental Extreme DW 245/40 and 275/35, Nav, HK, BT, Euro rotors, Custom Performance Rasp Terminator (2nd Gen.), Silverline DICE iPod adapter, EAS Aurora 60 LED Angel Eyes, "-CDV," "free & easy" camber mod (-1.7 degrees), Koni S/A shocks, Rogue Engineering RSMs and transmission mounts, Bimmerworld silicone intake boot, spacesaver spare from LeatherZ, updated OEM RTABS
'11 Jaguar XFR
Jump to top Need4Spd is offline   Reply With Quote
Old Sat, Dec-22-2007, 04:06:42 AM   #43
Originally Posted by Idz21 View Post
Ian, how about using Redline oil instead the BMW oil for the tranny & diff? Pete - what's the dealer's take on this? My car's almost due for Inspeciton I, and I was going to request that they use Redline oil instead (I would provide the oil).
For me personally, I don't feel comfortable experimenting with fluids-- I don't know enough to know what makes it good and I know OE should be safe.
That said, I'm willing to post links and mention that some people use them if someone provides me with links to the proper redline products...
Old Sat, Dec-22-2007, 03:04:13 PM   #44
2manytoys
THE HERD BULL
2manytoys's Avatar
Reputation: 0 2manytoys is on a distinguished road
Wow! Great thread, very helpful.
03 BMW M3 SMG Vert. Silver/Red
02 Viper GTS Yellow Underground Racing Twin Turbo
66 Corvette Vert.
08 GMC Sierra 3500 DMAX Dually
06 Mercedes R500 AMG Sport Pkg.
Jump to top 2manytoys is offline   Reply With Quote
Old Sun, Dec-23-2007, 02:11:05 AM   #45
Silver///M
۞Fahad ۞
Silver///M's Avatar
Reputation: 0 Silver///M is on a distinguished road
Qatar
Don't use any fluid but BMW OEM, I had my diff fluid changed to Mobile1 same weight as BMW fluid based on recommendation of bimmerhaus shop for the past 5k miles or so I have been experiencing excessive noises from the diff which I thought were tire rubbing and it was crunching and clunking all the time when turning.
I have just replaced it with BMW OEM with FM booster, the difference it amazing the noises are totally gone and driving the car seems smoother a bit.
Jump to top Silver///M is offline   Reply With Quote
Old Fri, Dec-28-2007, 05:26:47 PM   #46
blackmist27
Shake and Bake!
blackmist27's Avatar
Reputation: 0 blackmist27 is on a distinguished road
Great Thread!!!!! thanks to all that are contributing!
Instagram: Blackmist27
2011 E82 1M BSM 642 of 740 (Current)
2011 E92 M3 AW Comp (SOLD)
2004 E46 M3 TIAG (SOLD)
2004 E46 M3 LSB (SOLD)
Jump to top blackmist27 is offline   Reply With Quote
Old Mon, Jan-07-2008, 05:09:10 AM   #47
///tonic
aaarr
Reputation: 0 ///tonic is on a distinguished road
I just did a bunch of maintenance to mine at 106k:
- Differential input flange seal
- oil pan gasket
- oil check valve (this was leaking pretty dramatically and causing a burning smell)
- tranny fluid
- diff fluid
- brake fluid flush
- rear lower ball joints
- rear upper ball joints
- front lower control arm bushings
The total bill came to about $2600 (including a few other non-maintenance items), but completely worth it. Just the improvement in tightness from the rear ball joints is incredible. I'd recommend adding them to the schedule. My mechanic also said that check valve (i think jeST called it an expansion plug earlier?) is a very common leak area. For sure, if you're swapping headers, replace it as a preventive measure while it's accessible.
TC Kline S/A . SuperSprint Race . iForged Seneka . Stygar SSK . Dinan Software
Jump to top ///tonic is offline   Reply With Quote
Old Mon, Jan-07-2008, 11:31:14 AM   #48
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
^^ Definitely would be easier if you had the headers already removed but you can access it without having to remove the headers.
1994 Toyota Supra 6speed Red/Black
Big Single + Meth
Jump to top JeST is offline   Reply With Quote
Old Tue, Jan-08-2008, 07:44:30 PM   #49
jrbm3
jrbm3's Avatar
Reputation: 0 jrbm3 is on a distinguished road
Default Coolant change addendum
I post infrequently but I had to share my experience recently with the coolant change on my DD which is an e46 M3 with 38K miles and just went out of warrenty. So now is the time to start the routine maintanance. I used this site http://home.kc.rr.com/blankpages/M3/...hange_DIY.html as my guide but I would say that there are some tricks that I could share to help any other DIY'ers.
1. the site does not say exactly where the coolant plug for the engine block is located. You can barely see it under the car but mostly only feel it. You must take off the front plastic cover under the engine to find it. Find the sway bar and then reach up and over the black part that is round and about the size of a coke can. I think this is part of the oil cooling system. I'll post pics as well. You will feel a 13mm bolt on the engine block. To remove and tighten the bolt I found it best to use a 13mm socket with a 5-6 inch extension but don't attach the torque wrench or socket wrench until you have the socket with the extension in place and attached to the bolt. There is not enough room for your hands and the tools to keep it on the bolt. Also I used tin foil to cover the components from the coolant spray which occurs when you pull the plug. I think that is best to cover these instead of letting them be exposed to the coolant.
2. As you know, there is not a drain plug on the e46 M3 radiator. You must pull lower hose on the radiator to drain the rest of the coolant. The site says to use a flat head screw driver to pry the hose off. It is a PITA but the best way is to start with a very small flat head to start moving the hose off the radiator attachment then pry with a larger flat screw driver to complete the process. Do not twist the hose. You can't twist it because of the plastic guides. Just pry toward the rear tire. It will pop off and make a huge mess, so be ready.
The above DIY was helpful but I thought some more input would help someone else with the more difficult parts of the dyi.
I'll include pics that may help someone find the plug on the engine block.
Hope this helps and as always thanks to everyone who has helped me in the past.
john b.
Jump to top jrbm3 is offline   Reply With Quote
Old Tue, Jan-08-2008, 09:43:14 PM   #50
- oil pan gasket
- tranny fluid
- diff fluid
- brake fluid flush
Anyone else heard of this oil check valve? First time I've ever seen it mentioned (debating adding it to the list )
e46, getbmwparts.com, maintenance, thread, tischer
:: ECS Tuning :: Selection of E46 M3 Maintenance Products and Service Kits ECSTuning M3Forum Sponsor Announcements and Specials 1 Wed, Sep-24-2008 05:21:18 PM
E46 maintenance / DIY support ? jav1 E46 M3 (2001-2006) 19 Tue, Aug-21-2007 04:29:00 AM
FS: 2002 E46 M3 (SMG) - CPO/Extended Maintenance (BMW Individual) NoSoup4U Parts for Sale/Wanted 6 Thu, Jun-29-2006 08:14:08 PM
The Preventative Maintenance Thread Obioban E46 M3 (2001-2006) 1 Tue, Jul-05-2005 10:38:25 PM
E36 M3 vs. E46 328Ci -- Maintenance Costs gdhyde E36 M3 (1992-1999) 13 Sat, Dec-11-2004 06:23:39 PM
Discussing e46 M3 Maintenance Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
