Old Sat, Dec-16-2017, 03:25:16 AM   #1
ZuperJameZ
Reputation: 0 ZuperJameZ is on a distinguished road
Default 19” e46 wheels on e93?
I have a set of OEM 19” wheels leftover from my e46 M3. They are 19x8 and 19x9.5. The dealer wasn’t sure if the hubs would fit. Can anyone confirm if they will fit on my e93?
I’m planning to use them for my winter set up. Thanks!
03 M3 IR/IR Cabriolet with SMG
Aluminum trim, 19" OEM rims, upgraded HK with two 8 inch subs and sunken amp, removable hardtop, xenons, and power seats.
Jump to top ZuperJameZ is offline   Reply With Quote
Old Sat, Dec-16-2017, 11:05:24 PM   #2
mercedesc63
mercedesc63's Avatar
Reputation: 0 mercedesc63 is on a distinguished road
Default Re: 19” e46 wheels on e93?
I loled at the dealer not knowing if the hubs would fit... just goes to show how much the BMW dealer actually knows. E60 5 Series /E63 6 Series, E46 3 Series, E9x 3 series all use 72.5 center bore wheels. But the E39 for example has a different bore 74.1. All of these cars however utilize a 5x120 bolt pattern 5 lug setup.
I'm not too sure if the front wheels will even bolt on because the offset is too sunken in. The rears will fit fine, however the wheels overall will look weird on a e9x. Similar to E9x wheels looking weird on a E46.
Jump to top mercedesc63 is offline   Reply With Quote
Old Sun, Dec-17-2017, 03:35:10 AM   #3
ZuperJameZ
Do you think spacers would help the offset of the front wheels?
Old Mon, Dec-18-2017, 04:05:57 AM   #4
mercedesc63
Yes of course if I had to say probably a 20-25mm spacer... but seriously they would look weird and I wouldn't go any higher than a 15mm spacer.
Old Mon, Dec-18-2017, 07:16:57 PM   #5
They'll fit the hubs.
A 10-15mm spacer should be plenty to make a snow setup not look offensively funny.
Old Tue, Dec-19-2017, 01:47:16 AM   #6
ZuperJameZ
Thank you everyone.
Discussing 19” e46 wheels on e93? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
