Old Tue, Jan-02-2018, 11:29:25 PM   #11
Default Re: Comprehensive MSS60 DME Information
Originally Posted by MartynT View Post
Full reads/writes work perfectly with my Kess V2.
I haven't tried a partial either though but the writing occurs much quicker than the read.
I just wish it was quicker!
Is this all done through the OBDII port? If so it's probably the CAN gateway slowing things down. Same issue on the MSx8x. It deliberately slows down read requests, but writes can work at full speed.
In the case of the MSx8x, connecting to the DME directly speeds up reads considerably, but it's fast enough that the DME's buffer fills up and communications subsequently crash.
Old Tue, Jan-02-2018, 11:55:05 PM   #12
dpaul
Reputation: 0 dpaul is on a distinguished road
Hi Terra
Yes, OBDII. Just to be clear, by connecting directly to the DME do you mean hooking an DCAN cable directly? I can't read via BDM because "left" processor is locked. Unless you have discovered some way of unlocking it?
Curious part is that my clone KessV2 corrects the checksum for "full" writes but does not do so for "partial" writes. Too bad because "partial" writes (256Kb) take not more than 2 minutes, plenty fast for any application.
David
Jump to top dpaul is offline   Reply With Quote
Old Wed, Jan-03-2018, 08:30:04 AM   #13
MartynT
MartynT's Avatar
United Kingdom
I'm not sure the CAN gateway is slowing the transfer down, the iFlash cable / software that Evolve/etc use can do a full read/write in about 40 mins and still goes via OBD.
Jump to top MartynT is offline   Reply With Quote
Old Thu, Jan-04-2018, 01:20:19 AM   #14
dpaul
I wanted to correct an error I made in a previous post:
My KessV2 DOES correct the checksums for both full and partial writes. As it turned out, my first attempt at a partial write failed for other reasons (a somewhat troubling overwriting of 64 bytes at offset 0x80 with FF - this has not repeated on subsequent writes).
Partial writes are quite fast, around 2 minutes. So it is indeed a useful tool for tuning, if only one had an A2L or XDF to make sense of the map data or the patience and skills to make their own definition files.
Old Tue, Jan-09-2018, 04:24:44 AM   #15
jcolley
Reputation: 0 jcolley is on a distinguished road
I'll tag along here and provide some input. Sorry I haven't gotten back to your email @dpaul, I will, just buried in too many things right now.
To clarify, when you BDM read the mss60, the port is *not* blocked. Most tools will read it out properly, just the internal flash portion of the one processor will be empty. I have spent a month or so starting at disassembly on both mss60 and mss65 and this is one area I've focused on. I will say I'm 99% certain how the data is filtered out, but haven't decided yet if I intend to make any commercial use of it.
Yes, I am on the commercial end of this, but got started on mss65 in the m5board effort that never went much of anywhere. At the time I was still active duty, but now find myself eking out a living playing with these cars and I haven't made up my mind yet how much I want to give away. I read every post about mss6x on pretty much every forum there is and it's only a matter of time, it will all be public. I just can't financially throw it all out there right now.
Most of my work at the moment is dedicated to R/E the mss6x for the purposes of reconstructing portions of the code in MoTeC's M1 Build to run and S65 and S85 on a MoTeC M1 series ECU. The torque manager, idle actuator CAN, throttle actuator CAN, IBS, SMG/DCT structures...these are all of the things I have in focus as my primary goal is to bring a standalone ECU option to the E6x Ms and E9x Ms that provides full functionality of all systems.
I have been staring at mss65 almost daily for about 4 years now and tuning the S85 for about 2 years now.
My interest in the BDM lock is not to remove it, but actually implement it on both processors for both mss60 and mss65. I'm probably 50% of the way there on that, just trying to get comfortable with the idea of altering assembly to insert code in the program area.
For reading and writing, I will say, for 99% of what you guys want to achieve, unless you plan on leading a project into IDA and going at some PPC disassembly, a full read is pretty much useless.
mss65 has had very minimal changes to the program and calibration structure over any iteration with exception of 520E which was never for use in the US. I've not had time to get into what the nuts and bolts differences are, but have full reads of every mss65 version from 60E up to 520E.
mss60 had some pretty significant reconstruction at some point, to include incorporating the BDM internal flash masking. I initially thought that these changes were in the boot area and would require access to some file not publicly available in ISTA/PROGMAN/etc, but that is not the case.
It stands to reason that if the lock was incorporated at some point down the line with an iLevel upgrade, it would be in a program version change for mss60. I mistakenly believed that this would be in the boot area and would require an elusive/rumored .0ba file and not in the .0pa or .0da files. I will save you all the time. The lock is not in the boot area.
As I said, I'm still undecided how much I am willing to give away, not that I know what I *want* to give away. I just need to get my revenue stream shifted away from reflash tuning and get a few motec projects running.
Jump to top jcolley is offline   Reply With Quote
Old Tue, Jan-09-2018, 05:42:55 AM   #16
dpaul
Thanks jcolley for the info - yes, "locked" for me is shorthand for can't read the processor internal 512K. I was guessing the "lock" invokes hardware censorship described in the Fresscale MPC563 data sheet. The only documented method of clearing the censor bits also erases the flash module. But maybe I'm completely wrong - I'm neither a hardware nor software engineer. In the end, it doesn't really matter for most kinds of tuning
In any case, you are entitled to be compensated for the work you do and it appears that you've done plenty to further the efforts of others without compensation. I would not ask you to give more.
I have much less experience than most of the contributors here but I am enjoying the process of learning about the MSS60. I can make the following very simple contributions, which likely are already well known to many:
1) The latest available clone KessV2 v 5.017 is a perfectly fine tool for tuning. However, it is necessary to make a "full" read then a "full" write one time before partial writes are successful. After that, changes made to parameter area values are written quickly (~2 minutes) by "partial" writes without checksum errors or other issues. Precisely what is changed by the full read/write is not yet clear to me but there are only a few changes in the (readable) program code.
Offsets in the Kess full read are quite different than those reported by others using BDM or unspecified ODB tools. However, by comparison with 0da/0pa files converted to bin format, it looks to me that all the code/data is there. I believe Kess can read but not write to boot sector/AIF and possibly other areas.
2) There are a slew of 13 x 1 word diagnostic trouble code tables starting at 0xAC2 in the Kess partial read, and another set 64k later on (presumably referencing the other processor). Of particular interest to me are the tables headed by 2789 and 278A, codes for catalytic converter conversion banks 1 and 2. Zeroing out those tables eliminates the CEL if cats are absent and the ODBII readiness flag for that function is never set.
I will spend the remainder of the winter making guesses about ignition, vanos and fueling tables. For obvious reasons, this was all way easier in my E90 335.
Old Sat, Jan-27-2018, 01:50:47 AM   #17
jcolley
After a week of flashing every possible daten version all the way back to v32 then v28, I can confirm that the BDM "lock" is not removed by flashing back.
Old Mon, Jan-29-2018, 03:54:04 PM   #18
dpaul
I tried the same experiment with the same result (although the earliest daten I could find was associated with ProgmanV32 - 110E).
Old Mon, May-28-2018, 11:19:08 PM   #19
amuse
Reputation: 0 amuse is on a distinguished road
With the KESS/KTAG clones its best you rework your current PCB to make it more stable.
Apparently, in China the best KTAG PCB is the green one at the moment with Murata filters.
It still needs a PCB rework by replacing transistors from DigiKey.
Jump to top amuse is offline   Reply With Quote
Old Mon, May-28-2018, 11:28:41 PM   #20
cossie1
Reputation: 0 cossie1 is on a distinguished road
United Kingdom
Just wondering, if an FGTech V54 any good for reading / writing MSS60 ?
Jump to top cossie1 is offline   Reply With Quote
Discussing Comprehensive MSS60 DME Information in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
