Old Wed, Jun-06-2012, 11:50:24 AM   #11
lucky_doggg7
lucky_doggg7
Reputation: 11 lucky_doggg7 is on a distinguished road
Default Re: Reverse engineering the engine ECU PT-CAN data bus for the MSS60 (M3) ECU
Wow; and I thought ya only played cards... )
Jump to top lucky_doggg7 is offline   Reply With Quote
Old Tue, Jun-12-2012, 10:22:01 PM   #12
Not sure what this means. Can I get a hint?
Old Wed, Jun-13-2012, 12:00:25 AM   #13
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Reputation: 0 flipm3 is on a distinguished road
This is intense to say the least. Very cool!
Are there ways to log and record AFR and Ignition Timing while on the road? I apologize if that question is incredibly rudimentary.
2004 E46 M3 6MT | Silver Grey . Cloth | My E46 M3 Build Thread
2009 E90 M3 DCT | Melbourne Red . Speed Cloth | My E90 M3 Build Thread
2002 E46 M3 6MT | Jet Black . Black Nappa | My E46 M3 Build Thread
2016 981 Cayman 6MT | White . Black | Coming Soon
POST YOUR DYNO GRAPH HERE: The Official Dyno Thread
Jump to top flipm3 is offline   Reply With Quote
Old Wed, Jun-13-2012, 03:16:16 AM   #14
The ECU doesn't store the data. You would need a laptop to data log while on the road. But yes, with a laptop, you could data log AFR, Timing, IAT, and dozens of other values.
The VT1-535 heat soak test article posted on m3post, is an example of what can be collected with this method. The data collected for that article is a direct benefit of the work in this article.
Old Wed, Jun-13-2012, 04:39:16 AM   #15
Terrapin
Reputation: 0 Terrapin is on a distinguished road
Hey fellas, I'm not sure what protocol the PT-CAN is using but I built an I-Bus interface that connects to any android device over USB. I-Bus has been replaced by the MOST bus (fiber optic) but the board has two LIN-Bus compatible transceivers. If what you're trying to log/store is a single wire +12V signal, my board should be able to log it to an android phone.
Jump to top Terrapin is offline   Reply With Quote
Old Wed, Jun-13-2012, 04:47:05 PM   #16
It's a 500k/bit differential bus. I think it's LIN, but not totally sure. When logging to Android, what data format do you store the data? Data logging the PT-CAN bus consumes about 10MB/minute.
Do you have a link to your device?
Old Thu, Jun-14-2012, 01:15:45 AM   #17
Terrapin
Here is the thread I started: http://m3forum.net/m3forum/showthread.php?t=362365
I'd need to see more detailed specs on the bus. If its truly differential then I'd have to put a different chip on the board but I'm pretty sure it can handle 500kbps as is.
Edit: did a little digging. the PT-bus is completely different from the I-bus as you can imagine. I'd have to redesign the interface side...and acquire an e9x for testing . I'm not surprised though. Now that there is so much software running the car it makes sense that the sensors would have to talk much faster than good ol 9600 baud.
Old Thu, Jun-14-2012, 02:43:18 AM   #18
Yep, looks like they are indeed different. Sure would be nice to have a low cost CAN data logger that doesn't require a computer.
You wouldn't need to borrow any cars to test a new device. You would only need to get a CAN adaptor for your computer. This is the one I use when I need to simulate a car...but don't have the car at my disposal.
http://www.phytec.com/products/can/p...s/peakusb.html
Old Thu, Jun-14-2012, 02:52:14 AM   #19
flipm3
E46 M3 | E90 M3
flipm3's Avatar
I thoroughly enjoyed that thread and all the data! Those are the types of threads that forums need more of.
I'm going to PM you to ask about the best way of logging AFR, Timing, and IAT on my laptop
Old Thu, Jun-14-2012, 02:59:31 AM   #20
Terrapin
Borrow?
Edit w/actual contribution: In a future revision of my board I could swap a LIN transciever with something like the Microchip MCP2515 (http://ww1.microchip.com/downloads/e...Doc/21801F.pdf) and make a few tweaks to my app to get a data logger that would work with a phone. But this speculation isn't really helpful to you now so I'll be back when I build something useful...
Discussing Reverse engineering the engine ECU PT-CAN data bus for the MSS60 (M3) ECU in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
