View Poll Results: What is your 4.0L V8's oil consumption rate?
My E9x M3 V8 engine burns 1-liter of oil every 5,000+ miles 112 53.85%
My E9x M3 V8 engine burns 1-liter of oil every 4,000 miles 31 14.90%
My E9x M3 V8 engine burns 1-liter of oil every 3,000 miles 33 15.87%
My E9x M3 V8 engine burns 1-liter of oil every 2,000 miles 11 5.29%
My E9x M3 V8 engine burns 1-liter of oil every 1,000 miles 21 10.10%
Voters: 208. You may not vote on this poll
Old Sun, Nov-01-2009, 02:26:43 PM   #31
Mentosman43
Mentosman43's Avatar
Reputation: 0 Mentosman43 is on a distinguished road
Just got my M3 on Thursday but I'm already at 830 miles. No oil needed yet. I'll let you guys know soon when I need some. I hear it really only burns oil at higher RPMs so maybe that has something to do with it as well?
Current:
1994 Mazda Miata
2002 E39 M5
Past:
2009 AW E92 M3
2007 B7 RS4
2000 B5 S4
2011 Ford F-150 Raptor
Jump to top Mentosman43 is offline   Reply With Quote
Old Tue, Nov-03-2009, 04:27:41 AM   #32
ISPEEDM3
Got Boost?
ISPEEDM3's Avatar
Reputation: 0 ISPEEDM3 is on a distinguished road
i had a good habbit of changing my oil every 7k miles before the boost, then have decided to drop it down to every 5k miles due to the extra oil used for lubercation of turbo and extra lines from scavenge pump and so forth.
[CENTER]
Jump to top ISPEEDM3 is offline   Reply With Quote
Old Tue, Nov-03-2009, 09:28:01 PM   #33
jimmyeatsworld
jimmyeatsworld's Avatar
Reputation: 0 jimmyeatsworld is on a distinguished road
I've been burning more since driving the car really hard. I believe I lost a liter in around 3-4K miles. Since topping that off, I've lost half a liter in about 1-2K miles I believe.
This is driving the car hard... flooring it everyday to redline when I get a chance. I'll floor it to 4-5k rpm on a regular basis as well. I'll hit 120-130 mph at least once or twice a week.
2008 Jerez Black E92 M3 6Spd (Fully loaded except rear sunshade)
Mods: RPI Full GT Exhaust, RPI Scoops, BMC Filter, KW Clubsports, 19" BBS LM DBK, Vorsteiner CF Type I Diffuser, JL Motoring VRS CF Lip
Jump to top jimmyeatsworld is offline   Reply With Quote
Old Thu, Nov-26-2009, 12:01:40 AM   #34
Tim K
Reputation: 0 Tim K is on a distinguished road
Turned 12,500 miles today with a 2008 M3, no oil consumption to date.
Jump to top Tim K is offline   Reply With Quote
Old Thu, Nov-26-2009, 01:19:52 PM   #35
Cleveland
///M POWERED
Cleveland's Avatar
Reputation: 0 Cleveland PorshaCleveland PorshaCleveland PorshaCleveland PorshaCleveland PorshaCleveland PorshaCleveland PorshaCleveland PorshaCleveland Porsha
Wow, that's a lot of miles without having to add any oil to top off.
Was your 1200mi service done at approx. 1200 miles? Sooner? Later?
And just to clarify, you didn't do any in-between oil changes?
R E M E M B E R O U R T R O O P S
True leaders are not those who strive to be first, but those who are first to strive and give their all for the success of the team. They can be identified by the clarity of their vision, the strength of their actions, and the integrity of their intent. A true leader has the confidence to stand alone, and the courage to make tough decisions. A true leader has compassion, and is willing to listen to the needs of others. He does not set out to be a leader, but he becomes one by the confidence that he inspires in others. He commands the respect of his peers, and is humbled by the admiration of his followers. True leaders are first to see the need, envision the plan, and empower the team for action. By the strength of the leader's commitment, the power of the team is unleashed.
Jump to top Cleveland is offline   Reply With Quote
Old Fri, Nov-27-2009, 05:33:42 AM   #36
slo_guy
Reputation: 0 slo_guy is on a distinguished road
just crossed the 9000 mile mark and I've had to add 2 liters so far.
Jump to top slo_guy is offline   Reply With Quote
Old Fri, Nov-27-2009, 06:27:58 AM   #37
H Bomb
Reputation: 0 H Bomb is on a distinguished road
i couldn't agree more. we do the same thing with our race bikes which are in there case a high performance 450 4 stroke and 250 4 stroke motor. we then drain the oil after the first ride and repeat before putting in the full synthetic. it had led to very reliable performance and low oil consumption. i have seen bikes blow and/or burn oil alot even into the air filter when not broken in correctly
i fall under the liter every 5,000 miles category. my E39 M5 was even more as that went through oil more so then this car
Originally Posted by Cleveland View Post
I sincerely believe that following the proper break-in procedure for a high performance engine (like the S65) is tied to your overall oil consumption rate.
In my experience, adhering to this procedure will result in the proper "bedding in" of main bearings, connecting rod bearings & piston ring seals.
And don't forget that even after the initial break-in period, you should still allow the engine to get up to the proper operating temperature. (before you rev it out to 6000+ rpms or more)
Street- 08 E92 M3- Sparkling Graphite /Fox Red 6sp-Dinan/RE SSK/Volk
Race Bike-10 CRF 250-PR2 Race Motor 40hp/Ohlins TTX/Rekluse EXP
Hauler- 06 Ford F250- Powerstroke 4WD Crew Cab Black/Grey-Skyjacker/RBP/Air Raid/SCT
03 Dinan S2 M3 Carbon Black/Cinn 6sp- past
03 Dinan S2 M5 Carbon Black/Black 6sp- past
Jump to top H Bomb is offline   Reply With Quote
Old Fri, Nov-27-2009, 08:28:46 AM   #38
endofanera7
Click on Ninja Turtle
endofanera7's Avatar
Reputation: 0 endofanera7 is on a distinguished road
Viet Nam
1 quart every 3k miles.
Jump to top endofanera7 is offline   Reply With Quote
Old Fri, Nov-27-2009, 08:49:54 PM   #39
Niels E46 M3
Reputation: 0 Niels E46 M3 is on a distinguished road
just rolled over 10k miles - no oil needed yet. Still registering at full, as new
- no inbetween changes either
Service was done right at 1200 miles, (+- 10).
I followed the break in procedure 98% of the time.
I always bring the car/drivetrain up to temperature before pushing it...
2009 Space Gray M3 Coupe
  • DCT
  • Fox Red Extended
  • All Options except Sunroof
My Ultimate BMW ///M Blog
Jump to top Niels E46 M3 is offline   Reply With Quote
Old Sat, Nov-28-2009, 01:18:33 PM   #40
Cleveland
///M POWERED
Cleveland's Avatar
Good solid info.
At 8800 miles on the current oil, I assume you are doing a fresh oil change soon?
consumption, oil, post, rate
Discussing Post your ENGINE OIL CONSUMPTION RATE here... in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
