Old Sun, Apr-08-2018, 08:24:59 PM   #131
Default Re: DIY: E46 M3 (S54) detailed valve adjustment
Originally Posted by Exclusivs View Post
Directly in reference to this topic :
YES- Am sure more accurate readings on a compression test are given once valves are in spec. That said, how OFF can test results be prior to doing adjustment.
Also does valve cover gasket need to replace each time? Thanks guys!
Hard to give absolute psi value that might show up on the compression test. Way too many variables, so it could vary from none/0psi if shims are proper sized or undersized, no carbon buildup, valve seats and faces with no/low wear to many psi if valve faces don't properly meet the seats (which might not always be corrected by simply using a proper shim/adjustment).
For valve cover gasket, if you have proper viton gasket, it can be reused, other should probably be replaced as they are more "single use" and might leak if reused.
Old Sun, Apr-08-2018, 08:40:51 PM   #132
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
That definitely didn't complicate things
Sounds as though : compression test IN CURRENT STATE
Jump to top Exclusivs is online now   Reply With Quote
Old Tue, May-15-2018, 05:12:52 AM   #133
applebook
applebook's Avatar
Reputation: 0 applebook is on a distinguished road
Thanks a lot for this guide. I was quoted $1000 CDN from a very good shop for an adjustment with all parts included. At this rate, it's worth it for me to attempt this myself since it can be done in one day, and I can save $900 after taxes. Plus I want to learn more about my car.
Please confirm if this ECS kit has all of the parts AND TOOLS that I need to follow this guide thoroughly:
https://www.ecstuning.com/b-assemble...300493743~kt2/
Jump to top applebook is offline   Reply With Quote
Old Tue, May-15-2018, 05:34:22 AM   #134
Wow, that is an expensive quote...
I want to be clear with my answer to your question about ECS kit...it has the parts and tools needed to perform the actual valve adjustment (sans micrometer to measure shims), however, these are not ALL the tools needed. It obviously does not come with any of the tools in the "Tools needed" section of the first post, to for example, remove the valve cover or rotate the engine, or even measure the shims (no micrometer in the kit), since it doesn't have the ratchets, box/open end wrenches, etc. Might be obvious, but I wanted to be clear, since you bolded "AND TOOLS" after using "all" in your question...
Old Wed, Jun-20-2018, 02:41:15 PM   #135
S-W0rks
Reputation: 0 S-W0rks is on a distinguished road
Great write up! I am picking up my new (to me) E46 M3 tomorrow. This is probably going to be the first thing I do to it. The car has 107k miles on it, after pulling everything to do the valve adjustment I am wondering if there is anything I should just go ahead and replace since I am in there?
Obviously, I will replace anything that is obviously worn (i.e. belts, hoses, etc...)
Worth it to change water pump, thermostat, xxx? Go ahead and do Vanos check/update as well?
Jump to top S-W0rks is offline   Reply With Quote
Old Wed, Jun-20-2018, 03:02:41 PM   #136
Everything you mentioned if you dont have records of them being done. Flush and replace all fluids. If you are doing belts, might be a good time to do tensioner/idler pulleys.
And congrats!
Old Wed, Jun-20-2018, 04:23:22 PM   #137
S-W0rks
And congrats!
Awesome, thanks!
Discussing DIY: E46 M3 (S54) detailed valve adjustment in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
