Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Garage > Forced Induction (F/I)
Forced Induction (F/I) Discuss the ever growing F/I options here!
Old Sat, May-12-2018, 07:21:18 PM   #1
Invasion1
///M User
Invasion1's Avatar
Reputation: 0 Invasion1 is on a distinguished road
Default VF570 kit bypass/diverter valve question.
Hey guys
The bypass/diverter valve I have which came with this kit has two ports on it....one on the body of the valve and one that goes into the cap on top.
I am not sure which one to hook the vacuum line up to and is the second one needed also?
Reason being I took off my Tial BOV cause the constant whooshing noise was getting a bit to much and I hope the recirculating nature of the Bypass valve will stabilize my idle issues Iíve had ever since I installed this kit.
Thanks and input is welcome.
DK
Jump to top Invasion1 is offline   Reply With Quote
Old Sat, May-12-2018, 07:45:46 PM   #2
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
Reputation: 0 dtmpowerjc is on a distinguished road
You can turn your tial into recirc.
Jump to top dtmpowerjc is offline   Reply With Quote
Old Sun, May-13-2018, 04:54:54 PM   #3
Invasion1
///M User
Invasion1's Avatar
Default Re: VF570 kit bypass/diverter valve question.
I just researched that, $70 for a QR bottom half so thatís what Iím gonna do, thank you
Old Sun, May-13-2018, 05:52:50 PM   #4
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
When I had the Ess kit the hard part was getting a hose from them that fit the tial bov outlet back to the manifold. For my kit had to be silicone hose with a 38mm opening on both ends.
Old Sun, May-13-2018, 08:10:57 PM   #5
Invasion1
///M User
Invasion1's Avatar
Roughly how long of a silicone hose from Tial port to SC port?
I appreciate the info!
Old Sun, May-13-2018, 08:39:47 PM   #6
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
No clue
Old Fri, Jun-08-2018, 07:49:28 PM   #7
Invasion1
///M User
Invasion1's Avatar
Bit of an update on this, I ordered the lower half to turn the Tial Q into the QR (recirculating) I got a section of 38mm silicone hose and a couple clamps.
When I went to reassemble the two ports that need to be connected by the hose are so close together they touch!
So I’m not sure how I’m gonna get this assembled and function.
Old Fri, Jun-08-2018, 07:52:05 PM   #8
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
So Iím not sure how Iím gonna get this assembled and function.
The top half is a Vband route it opposite or to the side and route the hose.
Old Sat, Jun-09-2018, 10:56:20 PM   #9
Invasion1
///M User
Invasion1's Avatar
I will give that a try
Thank you
Discussing VF570 kit bypass/diverter valve question. in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
