Old Wed, May-10-2017, 05:36:46 PM   #1
Lventhedream
Reputation: 0 Lventhedream is on a distinguished road
Default fix Samsung Galaxy S7 Edge Bluetooth problems
Car: 2012 M3 E92
Phone: Samsung Galaxy S7 Edge
My phones bluetooth would not stay connected to the car. At first it started to happen once a month until it got so bad it would not stay connect. I found this web site that offered ways to solve the problem: https://www.technobezz.com/fix-samsu...ooth-problems/
The only one that worked for me is the:
Wipe cache partition
Here is how to do that:
First, turn off your Galaxy S7 Edge completely
Next press down the Power, Home and Volume Up button altogether for few seconds
After a while, the Android recovery screen will be appeared and leave all the three buttons
Now use Volume down button to navigate and Power button to choose. Select ‘wipe cache partition’ and then restart the device.
<<<<<<<<<<<<<<<------------------------- UPDATE ----------------------------------------------->>>>>>>>>>>>>>>>>>>>>>>>
The suggestions mentioned above only seemed to stall the inevitable. The car would eventually lose the phone pairing. Then I decided that I would also link the phone's blue tooth so I can listen to streaming music.
It has now been over 4 months and no problems what so ever. The phone works perfectly now. You can make calls and listen to streaming music. Suggestion register the phone with the car then turn on the blue tooth. Instructions for streaming music are:
Good Luck Hope the fix will make this annoying problem go away.
It has been over a year now and no failures in the phone connection. Has been perfect. The only thing I have noticed is the loading of the phone book is a little slow.
Register the phone with the car then turn on the blue tooth.
Last edited by Lventhedream; Fri, Sep-14-2018 at 06:24:21 PM. Reason: Update added more information
Jump to top Lventhedream is offline   Reply With Quote
Old Tue, May-16-2017, 02:29:16 PM   #2
Default Re: fix Samsung Galaxy S7 Edge Bluetooth problems
I was this close to assuming this thread was spam and deleting it by the thread title.
Old Tue, May-16-2017, 10:48:48 PM   #3
Rez
Rez's Avatar
Reputation: 637 Rez has a reputation beyond reputeRez has a reputation beyond reputeRez has a reputation beyond reputeRez has a reputation beyond reputeRez has a reputation beyond reputeRez has a reputation beyond repute
me too
Jump to top Rez is offline   Reply With Quote
Old Mon, Sep-18-2017, 09:19:03 PM   #4
Lventhedream
bump it up
Old Fri, Sep-14-2018, 06:24:41 PM   #5
Lventhedream
bump it up
bluetooth problems, galaxy s7 edge, samsung
Discussing fix Samsung Galaxy S7 Edge Bluetooth problems in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
