Old Mon, Jul-31-2017, 03:14:49 PM   #11
ThunderMoose
Default Re: Getting Gas with the Engine Running
It's not something I would do.
#67 2017 NASA TX TT3 Champion
Old Mon, Jul-31-2017, 03:42:45 PM   #12
TheDoogan
Forward Loaded
TheDoogan's Avatar
Reputation: 0 TheDoogan is on a distinguished road
That's interesting about 'never idle'. Logic tells me that the lower [Fewer] the RPMs when cold, the less friction will take place. But I'm assuming you guys are referring to something in the top half of the engine? (carbon buildup from a colder ignition, or slower flow and siphon from the exhaust? I'd read the 'just start driving' advice in the manual, but assumed they were just being ----s catering to the 'your car will get stolen and you'll 'have too much fun' police.)
So strong is my aversion to unnecessary lower-half friction, that I've even fantasized about having a system like a very slow starter that would allow me to roll the engine very slowly for 10 or 12 cranks at, say, 1 revolution per 2 seconds.
Just like an old airplane; turning the prop without electricity on to work oil up into the engine.
ANYWAY, I forget that it's all a moot point. If my water / block temp is up to 180 when I pull into the gas station, but oil is sub 120, if I shut the engine down, that oil is going to have warmed up 50+ degrees in the 4 minutes is takes me to get gas.
That's very convenient, and was especially this morning at 5am, when I made an incredible run 68 miles away and back. Never before have I been able to cruise at as high speeds as I did this morning, for such a sustained amount of time. There was simply nobody for a long time.
My God: what a car.
2006 E46 M3, 6MT, Convertible, Black/Black - 72k miles
60k mile Service II, Evolve CSL Intake w/Alpha-N tune, Schrick CSL Cam, Active Autowerke Catless Headers, Section 1 High-flow cats & Section 3.
Jump to top TheDoogan is offline   Reply With Quote
Old Mon, Jul-31-2017, 03:51:28 PM   #13
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Whats the issue with turning the car off and turning it back on when cold?
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
Old Mon, Jul-31-2017, 03:53:53 PM   #14
stack
The STIG
stack's Avatar
Reputation: 0 stack is on a distinguished road
Poland
I do it sometimes, ground your self first.
I do not do it on an empty tank.
04 E46 M3/ 95 E36 M3
Jump to top stack is online now   Reply With Quote
Old Mon, Jul-31-2017, 03:56:39 PM   #15
My God: what a car.
Different parts expand as they warm up at different rates. The parts are designed to be correctly sized, and fluids are speced to be at the correct viscosity, when at operating temperature. Warming up at idle makes it take longer to warm up. The longer it's running cold, the more wear is occurring.
The owners manual for the car even specifies that you should not let it warm up at idle.
Old Mon, Jul-31-2017, 03:57:03 PM   #16
stack
The STIG
stack's Avatar
Poland
Originally Posted by Sandeep1212 View Post
Whats the issue with tuening the car off and turning it back on when cold?
start up is when there is the least amount of oil in bearings and moving parts.
When cold... oil is not flowing as smoother then warmer oil because it is thicker
Over a long period of time, parts will start to wear down.
Old Mon, Jul-31-2017, 03:57:57 PM   #17
Dave B
M3 collector
Dave B's Avatar
Italy
What is this "warm up" period you all speak of?
Do your cars not just turn on and hit operating temp in the blink of an eye up there in the great white north?
Old Mon, Jul-31-2017, 04:00:17 PM   #18
Sandeep1212
I know, I mean per OPs question of leaving the car running.
So whats worse about turning a car on then off then on vs left running. Both situation you have cold oil amd lubed bearing at that point.
Unless you're saying that they loose the oil that quickly?
Old Mon, Jul-31-2017, 04:01:51 PM   #19
TheDoogan
Forward Loaded
TheDoogan's Avatar
That makes sense - okay, logic absorbed. Here again the board of knowledge here has helped to absolve me from guilt that was probably incorrectly ingrained in my redneck childhood, much like the incorrect adage that centerfire pistols and rifles shouldn't be dry-fired.
Haha - no sir, not like Miami. This morning, it was 52 degrees when I woke up
Old Mon, Jul-31-2017, 04:38:48 PM   #20
albino09
A Yankee South of the Mason-Dixon
I'm not sure of 01-06 OBD regulations, but any car built today would throw a DTC for "Gross Evap Leak" on second ignition cycle. I suppose if it's during warmup and you never shut the car off, this probably won't store. This DTC would not cause any change in performance.
It's not a smart move as far as safety is concerned. Static electricity, heat from the exhaust and source of fuel isn't a great combo.
Discussing Getting Gas with the Engine Running in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
