Old Mon, Jul-31-2017, 02:33:18 AM   #1
TheDoogan
Forward Loaded
TheDoogan's Avatar
Reputation: 0 TheDoogan is on a distinguished road
Default Getting Gas with the Engine Running
Hey guys, quick dumb question.
Assume that I will need every second of car warm-up time in the morning to get that oil temp up, and that I have a gas station less than a mile away (oil temp still buried when I pull in).
Is it really a problem to leave the car running while popping the fuel cap off? And if the CEL does come on as a result, am I going to see decreased performance?
I never bother shutting my Rover LR4 down (always have family if I'm driving that, and it's either needing heat in the winter and A/C in the summer, or I don't want to change ambient noise and wake up my wolf pack). Sometimes there's a great deal of suction when I pop that cap off, but that feckin auld betch has never catched er arse, no she ain't.
What do you guys think?
2006 E46 M3, 6MT, Convertible, Black/Black - 72k miles
Active Autowerke Catless Headers, Section 1 High-flow cats & Section 3, Evolve CSL Intake w/Alpha-N tune. Schrick CSL Cam - 60k mile Service II.
Jump to top TheDoogan is offline   Reply With Quote
Old Mon, Jul-31-2017, 03:05:19 AM   #2
bostonbruck
bostonbruck's Avatar
Reputation: 0 bostonbruck is on a distinguished road
Default Re: Getting Gas with the Engine Running
I wouldn't.
2002 Jet black 6MT Coupe Beisan Vanos, Gloss black grills, F10 M5 knob, maintenance
Jump to top bostonbruck is offline   Reply With Quote
Old Mon, Jul-31-2017, 03:12:20 AM   #3
icecream
Registered Apples
icecream's Avatar
Probably okay. However, reason I hesitate to do it is usually you fill up with an empty tank. You then expose the tank to oxygen when you open the filler cap and combine that with a running electronic fuel pump and well. Chances are probably as likely as a 747 crashing into your home but still. The stoichiometry will probably never be right for an explosion inside the tank but I'm sure if you tried, you could make it happen.
As far the cel. No issue there. Light will go out. Car just sensed a leak but it won't effect anything and will go off after a few cycles.
Old Mon, Jul-31-2017, 03:13:17 AM   #4
qualicas
qualicas's Avatar
lots of places wont let you fill up while engine is running. Some places it is illegal.
Would be embarrassing if you were in the "big house" and fellow inmates were asking what you in for and all you had was filling up while engine running!
Anyway, make it a habit to fill up on way home. That way if you have to make a quick getaway you do not have to stop for gas on the way!
Old Mon, Jul-31-2017, 03:18:54 AM   #5
TheDoogan
Forward Loaded
TheDoogan's Avatar
Words of the wise.
Thanks guys,
TD
Old Mon, Jul-31-2017, 06:08:14 AM   #6
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
when it's 100 outside I make exceptions
Topo Chico
Old Mon, Jul-31-2017, 12:31:21 PM   #7
PSUEng
Well, as an aside, IMHO, it's bad to get out of the vehicle with it running anyway--just not good practice unless an emergency or something.
Old Mon, Jul-31-2017, 01:13:48 PM   #8
Moreover, you shouldn't warm the car up at idle, anyway-- it's worse for the engine.
Old Mon, Jul-31-2017, 01:33:50 PM   #9
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
agree!
I read somewhere that BMW recommended to drive the car for warm up and not let it idle.
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@E46m3_Owners_OTW
Jump to top OneFastSicilian is offline   Reply With Quote
Old Mon, Jul-31-2017, 02:08:33 PM   #10
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Originally Posted by OneFastSicilian View Post
agree!
That would be all cars. Start and pull away, do not idle it at all.
Andrew
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
911 Journal/Build Thread
No fun no care
Jump to top TheSt|G is online now   Reply With Quote
Discussing Getting Gas with the Engine Running in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
