Old Wed, Sep-19-2018, 01:29:57 AM   #21
bigjae1976
Default Re: Mk20 “ice mode” on track
Originally Posted by CrookedCommie View Post
Oh great, so my plan on dropping $$$$ for the AP kit still won't fix the brakes? I love this car
I'm running 700/800 spring rate... so is it a shock thing? Do I need to turn up compression or rebound?
I have an MK60 system and I get the hard pedal thing but I know it’s saving me $$$ in tires. Never really had an issue. Maybe just do an MK60 swap?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Sep-19-2018, 01:40:26 AM   #22
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
I can spend another $1000+ on a MK60 swap and who knows how much labor, but that just doesn't seem right... I knew I should have just gotten a 996GT3 to begin with
Old Wed, Sep-19-2018, 02:11:51 AM   #23
Apex_3472
Reputation: 0 Apex_3472 is on a distinguished road
Once again the biggest point of emphasis is that this hard pedal sensation is the ABS working incorrectly and is absolutely an unsafe thing to have happen. Essentially the braking system is working at 10% of its normal capacity, where normally when ABS is engaged it still functions somewhere 70-80% of capacity.
I'm not convinced that with slicks the car would be capable of just locking the wheels at will, I believe it would take some very rough inputs.
oi64.tinycom/j9rkb4.jpgpic.
Jump to top Apex_3472 is online now   Reply With Quote
Old Wed, Sep-19-2018, 02:13:08 AM   #24
CrookedCommie
Captain Slow
Bulgaria
So do you think we can run no ABS on the Pirellis? Is it possible to just pull the fuse?
Old Wed, Sep-19-2018, 02:17:08 AM   #25
Apex_3472
Yes, the transfer feeling would be a shock thing. Its hard to say without driving the car but if you feel the weight of the car being transferred rapidly, or the nose dives quickly and there is no smooth transition a shock setting could be your issue. Not sure of your damper package but in racing we would either increase front low speed compression stiffness or increase rear low speed rebound stiffness. Either of these changes will make that transition longer - the goal being to keep the rear planted longer during the initial heavy brake phase.
Old Wed, Sep-19-2018, 02:19:16 AM   #26
Apex_3472
That's my thought - I wish I had a track day soon to give it a shot. It absolutely will be what I do next track day. "Ice mode" scared the sh** out of me and I'd rather lock all 4 wheels in a smoky slide of glory than get a hard pedal and run into the poor soul in front of me or worse.
Old Wed, Sep-19-2018, 02:28:24 AM   #27
CrookedCommie
Captain Slow
Bulgaria
Thanks Scott, I am going to test out DTC-70 pads on stock calipers next, but I might try to disable the abs and see what changes. I'm running a TC Kline D/A setup, and I haven't changed the compression or rebound since I set them up for Nitto NT-01's, so I might need to crank both up.
At Mid-Ohio, if I applied any medium brake pressure into T2, the car would just get super squirmy into turn in. I could hear the driver front locking and releasing, but with barely any brake pressure applied. The back straight brake zone was a "pray it stops" every time.
Old Wed, Sep-19-2018, 02:44:14 AM   #28
Apex_3472
MORPCA Mid Ohio Sept 18 on Pirellis - YouTube
Nice driving! Always exciting to break into the next second bracket. Seeing the lap time cracked me up because the last time I was there in anything besides a pro car was this vintage corvette. Same config I was at about a 1:38. We're on treaded bias ply tires and the brakes aren't anything to write home about, but something about the 550+ hp probably makes up a lot of difference!!
Back on topic - crank up both of those settings and play around with it. Try increasing front bump more than rebound and rear rebound more than bump - but up on every setting. Also it's worth the disclaimer of work back up to it when you turn abs off. I think it'll be better but I don't want you finding out (in a big way) that I was wrong!
Old Wed, Sep-19-2018, 04:50:01 AM   #29
bigjae1976
I think all you need to do I disconnect one wheel speed sensor.
I forgot to plug one in and had no ABS. That was an interesting experience. Lol
Old Wed, Sep-19-2018, 11:47:49 AM   #30
I don't have a MK20 car, so no first hand experience with this, but has anyone tried fiddling with the ABS values in NCS Expert to see if it helps?
Or, I forget who, but someone sells a MK20 tune that supposedly makes it more MK60 like in its intervention thresholds.
Discussing Mk20 “ice mode” on track in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
