Old Tue, Sep-18-2018, 10:35:37 PM   #11
M spec
Rembrandt Audio
Reputation: 0 M spec is on a distinguished road
Austria
Default Re: Mk20 “ice mode” on track
Originally Posted by CrookedCommie View Post
Huh? Ice mode? You need to turn off DSC. Never had this happen with DSC off.
Actually, it happens with it off, too. Regrettably the work required to convert to MK60 is a PITA
Jump to top M spec is offline   Reply With Quote
Old Tue, Sep-18-2018, 10:39:20 PM   #12
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Originally Posted by bigjae1976 View Post
I guess my question is what’s the theory behind the car being the limitation? Is the ABS too sensitive?
Yea the mk20 is overly sensitive compared to the mk60 under threshold braking.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
Old Tue, Sep-18-2018, 10:39:37 PM   #13
Drewster
Drewster's Avatar
My understanding is that ice mode usually just feels like the OP described - where you would normally get ABS engagement (sort of a "grinding" pedal feel as the motors modulate brake pressure), you instead just get a hard pedal, not much actual braking, and you either pulse it, try and ride it out, or don't brake at the limit.
Usually this comes up when you're running something like slicks or going over transitions where (as I understand) the wheelspeed decreases so quickly that the ABS module thinks there's zero traction and changes the modulation pattern under the assumption you're on ice.. sounds like the Mk20 is fast to jump to that conclusion
Old Tue, Sep-18-2018, 11:14:52 PM   #14
bigjae1976
That makes sense...thanks!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Sep-19-2018, 12:33:34 AM   #15
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Weird, I was running Pirelli DH's this weekend at MO. I'm on DTC-60's and I could overwhelm the brakes very easily. If I kept about medium brake pressure through the whole brake zone, that worked. If I tried to do threshold braking, the car would get all squirly and then I would have a soft pedal at the end of the brake zone.
I think the answer is BBK. I'm SO done with trying not to die lap after lap with these stock calipers. I am NOT a pro coach and could very well be me f*cking up...
Old Wed, Sep-19-2018, 12:52:52 AM   #16
Apex_3472
Reputation: 0 Apex_3472 is on a distinguished road
In my opinion it doesn't matter what pads/fluid you're on, once you step up to slicks the stock calipers/rotors no longer cut it. So much extra heat is being built because of the extra braking power provided by the grip of the slicks.
Side note - the car getting squirly under braking sounds like a bias issue. Either that or the car is unloading the back too rapidly when the extra braking power is used.
oi64.tinycom/j9rkb4.jpgpic.
Jump to top Apex_3472 is online now   Reply With Quote
Old Wed, Sep-19-2018, 12:54:47 AM   #17
Apex_3472
That was my general thought, that no locking would actually occur without ABS. However the car thinks locking would occur because, lets be honest, the abs is designed for semi-spirited driving at best. It doesn't know how to compensate for a BBK and Pirelli slicks.
Old Wed, Sep-19-2018, 12:56:17 AM   #18
CrookedCommie
Captain Slow
Bulgaria
Are you on a BBK?
Old Wed, Sep-19-2018, 01:12:17 AM   #19
Apex_3472
Are you on a BBK?
Yes - Brembo 355 front 345 rear
Old Wed, Sep-19-2018, 01:20:44 AM   #20
CrookedCommie
Captain Slow
Bulgaria
Oh great, so my plan on dropping $$$$ for the AP kit still won't fix the brakes? I love this car
I'm running 700/800 spring rate... so is it a shock thing? Do I need to turn up compression or rebound?
Discussing Mk20 “ice mode” on track in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
