Old Fri, Jan-19-2018, 04:37:57 PM   #1
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
Default Removing water spots on side mirrors glass?
The glass on my side mirrors has really bad water spots. Is there any way to remove this? Or is it time for new glass?
The water spot issue is pretty annoying, especially at night.
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Old Fri, Jan-19-2018, 04:39:20 PM   #2
lmtfi
lmtfi's Avatar
Default Re: Removing water spots on side mirrors glass?
Vinegar.
Old Fri, Jan-19-2018, 04:43:25 PM   #3
Laguna01///M3
PapaSmurf
Laguna01///M3's Avatar
Reputation: 0 Laguna01///M3 is on a distinguished road
Originally Posted by lmtfi View Post
Vinegar.
This, and super fine 000 Steel Wool
EURO.techniks
@WBUCCO
Jump to top Laguna01///M3 is offline   Reply With Quote
Old Fri, Jan-19-2018, 05:05:05 PM   #4
legacyej25
Vinegar.
Thanks, I'll give it a shot this weekend and post.
Old Fri, Jan-19-2018, 05:21:00 PM   #5
lmtfi
lmtfi's Avatar
Try newspaper before the extra fine steel wool.
Old Fri, Jan-19-2018, 06:48:42 PM   #6
LemonOne
LemonOne's Avatar
Reputation: 0 LemonOne is on a distinguished road
What water spot are you talking about so I know in the future? Pics?
2006 Imola Red / Cinnamon SMG II
Jump to top LemonOne is offline   Reply With Quote
Old Fri, Jan-19-2018, 07:08:50 PM   #7
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
baking soda and vinegar. also CLR works well.
Tischer aka GetBmwParts
Old Sat, Jan-20-2018, 02:44:00 AM   #8
kippers4brkfast
Reputation: 0 kippers4brkfast is on a distinguished road
It really depends on how bad the spots are. You can start with something like vinegar or a glass cleaner. If those don't work you can try 0000 steel wool but use some sort of soapy solution. Beyond that, you probably need glass polishing and a polishing pad.
2003.5 M3, 2010 VW GTI, 1998 Jeep Cherokee
Jump to top kippers4brkfast is offline   Reply With Quote
Old Sat, Jan-20-2018, 05:34:52 PM   #9
mrgizmo04
mrgizmo04's Avatar
http://www.reshareable.tv/25-practic...coca-cola.html
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-20-2018, 05:42:12 PM   #10
franklin
Reputation: 0 franklin is on a distinguished road
Thumbs up Re: Removing water spots on side mirrors glass?
Once the spots are removed, Rain-X applied goes a long way to curtail future spot development.
Jump to top franklin is offline   Reply With Quote
Discussing Removing water spots on side mirrors glass? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
