Old Fri, Mar-23-2018, 07:41:08 PM   #111
mrgizmo04
mrgizmo04's Avatar
Default Re: The cooling system thread - overhaul DIY
I got a metal gasket from thebmwminipartstore.com (others seem to sell paper??) and had no issues fitting it on straight, without any rtv. If the thermostat housing is off, you have some room and access. Make sure you replaced the pipe rubber orings, those can leak also.
On rtv, I would not use the regular black, it does not have the proper water resistance. If you really want to use some sort of sealant or gasket maker, get the one specific for water pumps, I believe permatex makes them (iirc they are in a green/blue tube).
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Mar-23-2018, 07:45:16 PM   #112
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
That was my understanding. Not sure why a sea lent needed to be used in the application. Looks like the OEM metal gasket sits firm on top
Jump to top Exclusivs is offline   Reply With Quote
Discussing The cooling system thread - overhaul DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
