Old Fri, May-18-2018, 05:19:48 PM   #11
matty088
Reputation: 0 matty088 is on a distinguished road
Default Re: Stock rime question
I think I got my answer and preference
How much are the oem 19s used on this forum?
Thanks for the help.
Jump to top matty088 is offline   Reply With Quote
Old Fri, May-18-2018, 05:23:51 PM   #12
You can prob find non-zcp 19s for around/under 1k with tires.
Where are you located? I'm actually going to be taking my 19s off and putting 18s on (already have these).
PM me if norcal.
Old Fri, May-18-2018, 05:51:45 PM   #13
matty088
PM me if norcal.
i am on the other coast. ty anyways,.
Discussing Stock rime question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
