Old Fri, May-18-2018, 01:39:19 AM   #1
hansonchris
Reputation: 0 hansonchris is on a distinguished road
Default Bad Idea?
Been in the hunt for a m3 for sometime now... have a max spending of 15k. Just been looking for that clean car in my range and havent had much luck.
I do want SMG and a vert... for my own reasons. Open to colors exterior and interiors. Of course cinnamon is ideal... But I cam across this below. So, bad idea?
https://www.ebay.com/itm/2006-BMW-M3...53.m1438.l2649
Jump to top hansonchris is offline   Reply With Quote
Old Fri, May-18-2018, 01:52:03 AM   #2
Kwakjoe
Kwakjoe's Avatar
Reputation: 0 Kwakjoe is on a distinguished road
Default Re: Bad Idea?
Can’t be that hard to find a vert with smg for under 15k.
Jump to top Kwakjoe is online now   Reply With Quote
Old Fri, May-18-2018, 01:58:00 AM   #3
hansonchris
Its not... these are the other two I have my eyes on.
http://www.bemer.com/vehicle-details...tx-id-23768828
https://www.cars.com/vehicledetail/d...t&CMP=atempest
Old Fri, May-18-2018, 03:19:04 AM   #4
erickrayos
Reputation: 0 erickrayos is on a distinguished road
smg and vert is the cheapest one you can get. not hard to find a good mileage good condition one.
Jump to top erickrayos is online now   Reply With Quote
Old Fri, May-18-2018, 06:45:36 AM   #5
Why do you ask "bad idea?" on the ebay one? Check the carfax (read: run your own on the vin, I've seen them photoshopped, I know it's like $40, but good insurance), get a ppi, etc and negotiate. Not 100% sure why there is a comment about the diff loudness...referring to (potential) lack of clunk?
I don't like the description comments about rod bearings or subframe, because BMW didn't really "fix" anything on the 06 model...no mention on vanos work or valve adjustment. Positive is smg pump recently done.
Do your research, ask the right/tough questions and you can easily find an smg vert with your budget.
Old Fri, May-18-2018, 03:50:33 PM   #6
m3nt0s
Reputation: 0 m3nt0s is on a distinguished road
Don't settle, wait for the right car to come along.
Jump to top m3nt0s is offline   Reply With Quote
Old Fri, May-18-2018, 05:07:31 PM   #7
That said, if he finds a really great car at a really great price that is not cinnamon, he can "settle" and then do an interior swap.
Old Fri, May-18-2018, 05:20:39 PM   #8
hansonchris
Thanks for the comments everyone, Im taking some advice noted and going to hold off for the right car... I want my cinnamon. Thanks all!
Discussing Bad Idea? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
