Old Thu, Jun-01-2017, 09:20:15 PM   #21
natty99
Heeeeyyy
natty99's Avatar
Reputation: 0 natty99 is on a distinguished road
Default Re: DSC light on + Yellow 'Brake' light
So possible culprits are steering angle sensor, DSC pressure sensor, voodoo...
Anybody else have anything concrete to add? My DSC and brake light used to randomly come one/off, but it stays on now regardless of deive cycles. Haven't pulled codes as I do not have the tools. Just wondering if this is a phase or worth getting checked out. Car drives fine, which has me scratching my head. And the SES light is not on, and never was
2005 BMW M3 ZCP 6spd, black on black
ENGINE: DINAN TBs | VAC Motorsport pulleys
EXHAUST: SS Stepped V1 Headers | SS race cats | SS resonated X-pipe
SUSPENSION/CHASSIS: Moton Street Sport S/A coilovers | Hyperco 450 front TCK 500 rear | GC Street camber plates (-2.4*F) | GC RSMs | RE weight jacks | TMS RTAB limiters | TMS RCAs (-1.4*R) | Mason Engineering Race FSTB | OEM front strut tower reinforcement plates | TMS rear subframe reinforcement
BRAKES: Brembo GT 6/4 monoblocks, 355 front 345 rear
WHEELS/TIRES: Volk TE37s in gloss white, 18x9.5 +22 (F) 18x10.5 +22 (R) | Michelin PSS 245/40 and 275/35
DRIVETRAIN: 3.91 BMW Motorsport
SHIFTING: AS 30% SSK | Illuminated ZHP | RE tranny mounts | GSP clutch pedal with UUC bushings | UUC "big boy" clutch stop | CDV delete | TMS SS clutch line
LIGHTING: Lightwerkz TFX retrofit | Digital 55w 4300K HIDs
INTERIOR: Euro first aid storage boxes
Jump to top natty99 is offline   Reply With Quote
Old Fri, Feb-23-2018, 08:58:37 PM   #22
LemonOne
LemonOne's Avatar
Reputation: 0 LemonOne is on a distinguished road
Bringing this thread back to life, did anyone find a solution for this yet?
I scanned it with my schwaben code reader and said something about DSC pressure.
2006 Imola Red / Cinnamon SMG II ///Most Powerful Letter
Jump to top LemonOne is offline   Reply With Quote
Old Fri, Feb-23-2018, 11:33:36 PM   #23
t3ddftw
t3ddftw's Avatar
Reputation: 0 t3ddftw is on a distinguished road
Kinda Vague. INPA will give you a real error, but my guess based on the information given is a wheel speed sensor.
2006 M3 ZCP 6MT Interlagos Blue on Cinnamon interior
Mods
Engine: Full Beisan Systems VANOS rebuild
Transmission: CDV Delete
Exterior: Smoked Corners | Black Side & Kidney Grills | Painted Reflectors
My Build/OCD thread
Jump to top t3ddftw is offline   Reply With Quote
Old Sat, Feb-24-2018, 08:44:00 AM   #24
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Probably one of the two DSC pressure sensors attached to the master cylinder. I have the same codes pop up periodically. Iíve got two sensors that I was going to replace both of them with since i didnít know which one was bad. PM me if you want to buy them, I havenít had the code in a while.
Jump to top Chapelle is online now   Reply With Quote
Old Sat, Feb-24-2018, 11:41:10 AM   #25
jtt777
jtt777's Avatar
Reputation: 0 jtt777 is on a distinguished road
i had the issues and the DSC presure switch was the noted culprit. I did replace it and at first it did nothing and then it just went away for good (so far). the system seems to be a bit slow acting to respond to changes. i hear that the DSC unit itself can fail but thats expensive. changing out the pressure sensor isn't too bad to do. If its stuck in that position and the pressure sensor is noted as the cause I'd do that first just to save some cash
2004 PY BMW M3
Jump to top jtt777 is offline   Reply With Quote
Old Tue, Feb-27-2018, 09:44:45 PM   #26
LemonOne
LemonOne's Avatar
In case I have to replace the DSC pressure sensor, is it true that you have to bleed the entire brake system in order to break-in correctly? Any experience?
Old Tue, Feb-27-2018, 10:42:07 PM   #27
rovert604
rovert604's Avatar
Iíve had the issue and BMW scanner said pressure sensor. So while I had things partially apart I pulled all plugs off including the big DSC ECU connector down below. I just took them off and on a few times. Then moved to the pressure sensor which if I remember could only read one and it was the one that was coming up in scanner. I pulled the plug and put it back a few times. All the plugs in the ECU box I did the same. Then i put everything back together. Itís been a little less than a year and no lights have come up. So sometimes it might just be the result of a bad electrical connection.
--Trevor in 604--
Vancouver, BC, Canada
Old Wed, Feb-28-2018, 05:54:18 PM   #28
Kdubski
Kdubski's Avatar
I got the DSC + Brake light often throughout the summer, mainly in 2 situations.
Either when it was scorching hot, like the hottest days of summer sitting in traffic. It just beeped on and went away on its own a day or two later.
The other time was when I frequented dusty back roads. It usually went off a few hours after a wash or after it rained. Had this happen 3+ times.
brake, dsc, light, yellow
Discussing DSC light on + Yellow 'Brake' light in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
