Old Mon, Oct-12-2015, 05:12:41 AM   #41
Pierre i am
ranch me brotendo
Pierre i am's Avatar
Reputation: 0 Pierre i am has a spectacular aura about
Default Re: Oil Light Flicker (when hot)
Originally Posted by jacobbb View Post
Sorry to bump an old thread. Having this same issue. Any more info/solutions?
Just follow the steps that are above:
- if running cheap low weight oil switch it to a better quality/ heavier oil (depending on climate)
- change the oil pressure sensor
If you still are having issues change out the oil pump and while you're there locktight the OPN or safety wire it.
Would be helpful to get more info about it though. What year, how many miles, which climate, what type of oil etc.
If you're really worried just do all those steps. Two of them can be viewed as preventative maintenance to save your engine.
Sam 2/23/16
https://m.imgur.com/r/funny/vrjdqZ4
Jump to top Pierre i am is offline   Reply With Quote
Old Mon, Oct-12-2015, 07:03:52 AM   #42
jacobbb
Reputation: 0 jacobbb is on a distinguished road
Mobil 1 0w-40 full synthetic changed every 5k miles on a 1998 m3 with full rebuild on the s52 100k Miles ago. Burns no oil. Bay Area California.
Jump to top jacobbb is offline   Reply With Quote
Old Mon, Oct-12-2015, 11:52:29 AM   #43
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
I guess that's fine enough for an overpriced and barely acceptable oil
Jump to top das borgen is offline   Reply With Quote
Old Mon, Oct-12-2015, 03:06:49 PM   #44
Pierre i am
ranch me brotendo
I would change out the sensor and see if that helps. When does it start flickering?
You should also be running a heavier oil like 5-10w-40. It doesn't really get cold enough in the Bay Area to be needing a 0w.
What part of the bay are you from? I'm in the south.
Sam 2/23/16
Old Mon, Oct-12-2015, 03:56:45 PM   #45
frbz
5w-40 is the same weight as 0w-40 at operating temp of 100 C. It just flows better when cold.
Jump to top frbz is offline   Reply With Quote
Old Tue, Oct-13-2015, 08:07:15 AM   #46
jacobbb
People like you are my favorite. You genuinely have no idea what you are talking about. Mobil 1 0w-40 uses an entirely different base stock than any of the other Mobil 1s. Mobil 1 0w-40 is oem oil for Nissan GT-R and all Porsches. Mobil 0w-40 is hands down the best oil you can run in most cars that don't require special oil weights like s55/s65/s85 etc. Don't comment if you don't know what your talking about. You'll end up looking baboon.
Old Tue, Oct-13-2015, 10:17:07 AM   #47
das borgen
Off-Topic King
das borgen's Avatar
All of that may be true about the OEMs, but I don't care to check it. From my personal experience I can say that the Mobil 1 just doesn't hold up as well as the other oils I've used. It runs thinner, and degrades quicker than Brad Penn 10w40, Castrol 0w30, Shell, Pennzoil and Amsoil 5w40
Using a different base stock than others also does not a better oil make. I'll just refer back to my oil analysis results as my data for my conclusions as opposed to you who refers to oil viscosities as "weights"
Old Tue, Oct-13-2015, 01:38:19 PM   #48
MMMGP
retired
MMMGP's Avatar
Reputation: 0 MMMGP is on a distinguished road
Poland
Would a cracked oil pick up tube cause the light to flicker?
'11 335is vert Alpine/Schwarz (1 of 168)
'12 X5 35i Premium Alpine/Schwarz (1 of thousands)
Jump to top MMMGP is offline   Reply With Quote
Old Tue, Oct-13-2015, 01:45:58 PM   #49
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
I would take the time to know some of the members here before you make such comments. You wouldn't want to end up looking baboon.
I love oil threads. Can we start another manuel v smglol thread?
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Jump to top propchef is offline   Reply With Quote
Old Tue, Oct-13-2015, 02:55:05 PM   #50
das borgen
Off-Topic King
das borgen's Avatar
yes...
flicker, hot, light, oil
Flickering battery light, never stays on more than 2 secs, don't flicker for days ? gixxer E46 M3 (2001-2006) 40 Sat, Mar-28-2009 02:01:44 AM
help: battery flicker, now light dimmer doesn't work jacclark E46 M3 (2001-2006) 1 Wed, Jun-11-2008 08:20:33 PM
Oil Pressure Light at Hot Idle??? alpinesaloon E36 M3 (1992-1999) 4 Tue, Jun-10-2008 12:53:44 AM
parking light flicker mugenh22a4 Faults, Fixes and DIY 0 Mon, Aug-28-2006 12:14:08 AM
Oil light flicker bigneil E36 M3 (1992-1999) 5 Tue, Oct-04-2005 11:55:23 PM
Discussing Oil Light Flicker (when hot) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
