Old Sun, Jan-09-2011, 05:56:31 PM   #11
wilmar13
wilmar13's Avatar
Reputation: 0 wilmar13 is on a distinguished road
Default Re: No More Airbags, so no more Air Bag Light
Originally Posted by wilmar13 View Post
After seeing your photo, I may try in the morning.
Well I verified you do need to remove the dash to get the side curtain out. Doh!
Jump to top wilmar13 is offline   Reply With Quote
Old Fri, Dec-18-2015, 12:32:54 AM   #12
e46IX
e46IX's Avatar
Reputation: 0 e46IX is on a distinguished road
6 year old thread bump. Bought my M3 with the airbag light on, previous owner mentioned it was the module that was faulty. No biggie, didn't bother with diagnostics since I plan on removing the airbags anyways.
I can concur with the OP that simply removing the airbag module located underneath the cupholder and electric taping the ground wire will take away the airbag dash light. Just in case anyone else has this problem and is only interested in getting rid of the light.
Jump to top e46IX is offline   Reply With Quote
Old Sun, Feb-07-2016, 11:14:22 AM   #13
marmarm3
marmarm3's Avatar
Reputation: 0 marmarm3 has disabled reputation
what do you mean by tape the ground wire. Can someone explain this process to me
Jump to top marmarm3 is offline   Reply With Quote
Old Sun, Feb-07-2016, 02:47:03 PM   #14
This was commented in the Track section as well.. still doesn't make sense to me. Ground is ground, unless it's actually a low-side trigger and not ground..
Old Sun, Feb-07-2016, 09:19:02 PM   #15
PSUEng
Reputation: 0 PSUEng is on a distinguished road
You probably lost your seatbelt pre-tensioners too, however, I haven't confirmed if this car is new enough to have them.
Jump to top PSUEng is offline   Reply With Quote
Old Mon, Feb-08-2016, 08:58:12 PM   #16
Dave B
M3 collector
Dave B's Avatar
Reputation: 0 Dave B is on a distinguished road
Italy
I actually just replaced a seatbelt pretensioner an hour ago. It's definitely tied in to the airbag sytem, and it fires an explosive charge to tighten the big cable wire down (retracting the receiving end) just like how airbags are fired.
If you're pulling airbags, of course, you're damn near certainly using harnesses instead, in which case this doesn't matter... but if for whatever reason you're pulling airbags without that, bear in mind that your seatbelt won't work as well as it should, which exposes you to even more risk than just removing the airbag does.
Jump to top Dave B is offline   Reply With Quote
air, airbags, bag, light
Discussing No More Airbags, so no more Air Bag Light in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
