Old Wed, Nov-01-2017, 10:24:31 PM   #1
tdz123
#1 M3F.net user.
Reputation: 0 tdz123 is on a distinguished road
Default Is a 100,000 mile plus car a bad idea?
I'm considering a high miles (100k+) e92m. Is that a terrible idea, or is a well maintained but high-mileage car just fine?
Like most models, these cars appear to take a big hit at 100k miles in terms of their value. It looks like there are a variety of 100ish k mile cars for sale around $20,000, but the sale price for cars in the 50k-90k range is at or above $30,000.
$10,000 pays for a lot of repairs, especially given that I DIY pretty much everything and this would not be a DD.
I bought my e46m with 86,000 miles and ended up feeling like it was a mistake. Better options are to either spend more for low low miles (<50k) or pay far less for high miles (>100k).
Any opinions out there?
Jump to top tdz123 is offline   Reply With Quote
Old Thu, Nov-02-2017, 12:45:28 AM   #2
Rez
Rez's Avatar
Default Re: Is a 100,000 mile plus car a bad idea?
e92 seems to have a few common issues that are independent of miles, having said that 100k is a lot of miles and car probably worn out cosmetically if not mechanically unless very well maintained. I see fairly low miles ( around 40k), clean cars can be had for the mid 30's. I see that a better buy in the long term
Old Thu, Nov-02-2017, 05:30:01 PM   #3
RallyBird
RallyBird's Avatar
Reputation: 0 RallyBird is on a distinguished road
E92 is better built and more reliable than the E46 in my opinion. Just plan on spending $2k for throttle actuators if they haven't been done (they go bad around 70-80k miles) and $2,500 for rod bearings unless you're doing them yourself. Other than that its pretty typical stuff, bushings, clutch (depending on how the car has been driven), potentially a/c compressor. Nothing that's really out of the norm. Factory brake rotors are expensive so make sure to check those when looking at a car.
Jump to top RallyBird is offline   Reply With Quote
Old Thu, Nov-02-2017, 07:07:28 PM   #4
On any car with 100,000 miles, I'd replace every bushing/bearing/ball joint on day 1. They're shot. The shocks, too, if they haven't been replaced (really, they should be coming up on their second replacement).
On any BMW, I'd replace the cooling system at 100,000 mile intervals, rebuild the fuel injectors, and replace the pre cat 02s.
And at some point in the future it'll need a fuel pump and throttle actuators, if they haven't already failed. If rod bearings haven't been replaced yet, probably should do them.
Beyond that, how nice the car is depends on how it was cared for by the PO.
Old Thu, Nov-02-2017, 08:49:29 PM   #5
tincan
Reputation: 0 tincan is on a distinguished road
I am also shopping higher mile cars because I want a daily driver. Curious as to why you say this?
Jump to top tincan is offline   Reply With Quote
Old Fri, Nov-03-2017, 03:48:54 AM   #6
RallyBird
RallyBird's Avatar
Isnít 100k and every bushing being shot a little extreme? Sure some will need to be replaced and some you might benefit from replacing them but I donít see everything 100% needing to be replaced on a 100k car.
Old Fri, Nov-03-2017, 03:47:36 PM   #7
tdz123
#1 M3F.net user.
Because the cars seem to take a big hit in value at 100,000 miles, regardless of whether it is warranted based upon the actual condition of the vehicle.
Paying a premium to have a car that will remain as a sub-100k for a relatively short period of time didn't end up making sense to me. I think it's a better idea to either pay an even higher premium for an even lower mileage car (i.e. 50ish k miles) or save your money and buy a well-maintained car that is over 100k miles and has already taken the depreciation hit.
So, for an e9xM, you can pay in the low 30s for a car with 50ish k miles or pay around 20 for a car with 100k+. I'm having a tough time deciding.
Old Fri, Nov-03-2017, 03:48:30 PM   #8
tdz123
#1 M3F.net user.
Thanks obioban. you've always been a great contributor. it sounds like from your post that a 100k mile car isn't a terrible option.
Old Fri, Nov-03-2017, 04:33:50 PM   #9
Originally Posted by RallyBird View Post
Isn’t 100k and every bushing being shot a little extreme? Sure some will need to be replaced and some you might benefit from replacing them but I don’t see everything 100% needing to be replaced on a 100k car.
Eh, perhaps, but the alternative is...
-take things apart again and again and again to go after different parts as they fail. It's far easier to just drop a subframe and replace everything on it and be set, without effort/labor, for another 100,000 miles
-have some parts that aren't as new, that you don't realize because they still look good and function "well enough". Combine a couple parts functioning "well enough" and your car gets sloppy.
Everything 100,000 is pretty infrequent in the grand scheme of things. Doing everything all at once lowers effort (if you're DIYing) or cost (if you're paying someone to do the labor). It keeps the car driving like new and eliminates hunting for issues.
Old Fri, Nov-03-2017, 05:08:01 PM   #10
RallyBird
RallyBird's Avatar
Everything 100,000 is pretty infrequent in the grand scheme of things. Doing everything all at once lowers effort (if you're DIYing) or cost (if you're paying someone to do the labor). It keeps the car driving like new and eliminated hunting for issues.
Makes sense. I can see your point.
Discussing Is a 100,000 mile plus car a bad idea? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
