Old Tue, Sep-05-2017, 10:42:24 PM   #1
pinkgodzila
M_GODZILLA
Reputation: 0 pinkgodzila is on a distinguished road
Default DCT Transmission Leak / Suggestion / SoCal Shop?
Hello E9X M3 owners,
I am searching for a solution and a shop to either swap (a lower mileage DCT transmission) or change the oil/oil filter, gasket etc in the 2009 M3 with DCT transmission.
looking for a shop (BMW certified mechanic) in SoCal, 626/909 area.
Year: 09 w/DCT
Mileage: 97xxx
Issue:
1) notice small leak on bottom pan and side of transmission
2) lag on switch from 2nd to 3rd gear when I turn on the M switch to manual mod (only 3rd gear)
Thought/suggestion:
1) change the oil, oil filter, new gasket etc... ?
2) swap in a lower mileage DCT transmission?
Jump to top pinkgodzila is offline   Reply With Quote
Old Mon, Oct-09-2017, 12:05:01 AM   #2
M3-peatv1.1
formerly M3-peat
Reputation: 0 M3-peatv1.1 is on a distinguished road
Default Re: DCT Transmission Leak / Suggestion / SoCal Shop?
I'm working with Malek at MRF engineering in OC. He has a following and seems to know his $hit when I talked to him and met with him. I'm having him do a ton of service including the DCT. He can either help or direct you to someone who can.
Jump to top M3-peatv1.1 is offline   Reply With Quote
Old Tue, Oct-10-2017, 02:42:37 PM   #3
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
https://www.avusautosport.com/
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is online now   Reply With Quote
Discussing DCT Transmission Leak / Suggestion / SoCal Shop? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
