Old Thu, Aug-10-2017, 05:07:02 AM   #1
burts
Reputation: 0 burts is on a distinguished road
Default Is this a good deal or a great one?
Im getting really close to buying this car...After the throttle actuator change he said the shop said he needs to change the iac... The battery too..
Is this just a ok deal or what?
https://honolulu.craigslist.org/mau/...248979216.html
Jump to top burts is offline   Reply With Quote
Old Fri, Aug-11-2017, 03:57:45 PM   #2
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
Default Re: Is this a good deal or a great one?
Alright, before you buy this thing, do the following to see if you can swallow the bitter pill that is maintaining it - that is, if you take it to a shop to get it maintained and/or fixed.
Find out the cost of the usual suspects for maintenance, which would be:
1) Fuel Pump
2) Water Pump, Radiator, Expansion Tank, T-Stat, Etc (Entire Cooling Sys)
3) Alternator
4) Brakes
My guess is that if you take it to a Dealer, that seems to me about $7+ Large worth of cost, but of course, call and find out for yourself. If this in your opinion, is not bad, then proceed with getting the car checked out as in a pre-purchase inspection. As for the short answer of buying the car, there used to be a well known Porsche magazine writer who would always say, "Buy the newest Porsche you can afford." Re-echoing this advice, buy the newest E9X M3 you can afford. Happy buying...
Jump to top Speed Monkey is offline   Reply With Quote
Old Fri, Aug-11-2017, 09:57:42 PM   #3
burts
I found a lawsuit going on
https://www.law360.com/cases/5644da5...00001/articles
Does the 2012 and 2013 models also have failures..?
Old Sat, Aug-12-2017, 02:22:16 AM   #4
chatcher
Reputation: 0 chatcher is on a distinguished road
I think it's a good deal. Cars break, can you afford to fix it? Is it to be your only car? I think M cars are best suited to toy status with a dedicated DD so if it does break it can be fixed at your financial pace. I do all my own repairs and maintenance which helps a lot. I just did brakes and tires on my E93 I DIYed the brakes and the tires we high end extreme performance yokohamas on my 18 oem wheel set and it was over 2 grand. Tires are even more expensive for my 19 inch wheels these cars do require deeper pockets than most others. This in my opinion is also a car you should by with cash, if you have to finance it pick something else.
current rides:
2009 Zr1
2012 Navigator
2008 4.8i E70 X5
2008 F450 Dually
2013 135i
2005 E83 X3 3.0
2003 rc51
1999 F350 Dually
Running out Garage space!!
Jump to top chatcher is online now   Reply With Quote
Old Sat, Aug-12-2017, 03:24:49 PM   #5
LeopardM3
E46 Forever
LeopardM3's Avatar
Reputation: 0 LeopardM3 is a jewel in the rough
Romania
Yes, 2012 and 13 models affected. From another class action website I follow:
Originally Posted by Top Class Actions
The BMW class action lawsuit states that the S65 engine in 2008 to 2013 model BMW M3 vehicles has a defective rotating assembly. Allegedly, the defect creates an “insufficient supply of engine oil to coat the bearing surfaces” of the connecting rod bearings, which causes “accelerated wear on the Bearings surfaces in all [BMW M3s], ultimately causing them to disintegrate and fracture.” The class action lawsuit alleges this defect creates a “rattling” or “clacking” noise when the engine is idling.
The bearing defect can lead to “catastrophic engine failure,” according to the BMW M3 class action lawsuit. As the metal bearings wear down, pieces of bearing metal get distributed throughout the engine in the engine oil. The complaint alleges that this can lead to many different serious issues, such as a loss of power steering, or power assistance to the braking system.
The class action lawsuit alleges that BMW has been, or should have been, aware of the M3 defect since July of 2013. The engine defect lawsuit alleges that BMW knew about the bearing defect from numerous complaints to its dealerships, its website, and the National Highway Traffic Safety Administration, as well as replacement part orders.
Rogue Engineering shifter /// Stainless steel trans lines /// BMW Performance CF Front Sway Bar /// Stainless Steel Brake Lines /// OEM ZCP Wheels /// Bimmian Fogs /// Painted reflectors /// 7000K 264-SMD LED Halos /// Machined Aluminum Pedals /// Dension Bluetooth with Microphone /// Max Vincent Aluminum Oil Filter Housing Cap /// Aluminum M Oil Filler Cap /// Status Gruppe M CF Engine Cover
Jump to top LeopardM3 is offline   Reply With Quote
Old Sat, Aug-12-2017, 04:29:59 PM   #6
m3e46freak
M3 Freq
m3e46freak's Avatar
Reputation: 0 m3e46freak is on a distinguished road
Germany
Too late bud...
Alright put a down payment on this..
Rock Hard Abs Racing
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
RESONATORS AND SUPERSPRINT!
DINAN!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
Jump to top m3e46freak is offline   Reply With Quote
Discussing Is this a good deal or a great one? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
