Old Tue, Jul-25-2017, 05:26:24 PM   #1
BMWGuy206
Reputation: 0 BMWGuy206 is on a distinguished road
Default 2010 M3 with Secondary Air System Fault
Hey guys!
I have a 2010 M3 with 132,000 miles and SES light is on with fault code 27B0 Secondary Air System Flow Rate, Bank 1, Insufficient Air Flow. The air pump is working and we found a lot of carbon build-up inside the non-return valve, but when we inspected the cylinder head, where the secondary air pipes go into, we found that the port is nearly clogged up.
This issue is similar to what happens to the S62 engines. We're preparing to tell the customer that the cylinder head has to come off and sent out for cleaning.
Has anyone had this issue before?
Jump to top BMWGuy206 is offline   Reply With Quote
Discussing 2010 M3 with Secondary Air System Fault in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
