Old Wed, Jan-04-2017, 03:47:30 AM   #1
Dovedude1
Reputation: 0 Dovedude1 is on a distinguished road
Default Early 2008 Bmw M3 Convertible EKP location
I ve seen online that the coupes have the EKP in the passenger rear pillar. I've torn into my car being it's a convertible and it's not there. A few things that's happening to make me think it's the EKP. Throwing the low pressure sensor code for fuel. Long cranks after filling up. Under heavy acceleration in M mode the fuel pump malfunction comes on causing it to go into limp mode until I restart it.. any help would be appreciated. I've called two dealers and they aren't helping.. sorry if this is choppy.. using my mobile.
Jump to top Dovedude1 is offline   Reply With Quote
Old Sun, Jan-15-2017, 05:41:33 PM   #2
volkswackin
Reputation: 0 volkswackin is on a distinguished road
Default Re: Early 2008 Bmw M3 Convertible EKP location
while i don't know the location off the top of my head...low pressure fuel sensors are far more common. Ive done tons of them...
Jump to top volkswackin is offline   Reply With Quote
Old Sun, Jan-15-2017, 07:11:51 PM   #3
liam821
Reputation: 0 liam821 is on a distinguished road
My 08 m3 convertible was throwing the same code. The dealer said they replaced the fuel pressure sensor (maybe it was the low pressure sensor? I don't remember). It wasn't exactly cheap, was $500+.
Anyway, that fixed the problem. Runs perfect now.
Jump to top liam821 is offline   Reply With Quote
Old Fri, Jul-28-2017, 08:52:59 PM   #4
Dovedude1
Ive done the low pressure fuel sensor already as well both throttle actuators. I know the location of the EKP in coupes are behind the rear seat but thats not the case with the convertible. Ive pulled it apart and checked for myself.
2008 m3, convertible, ekp, fuel pump
Discussing Early 2008 Bmw M3 Convertible EKP location in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
