Old Fri, Nov-03-2017, 08:57:38 PM   #41
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Default Re: DIY: S65 M3 Rod Bearing
Originally Posted by tdz123 View Post
Is this doable without a lift and the car on jack stands?
Yes. It'll take longer but it can be done just the same.
Several people have done it already.
Old Fri, Nov-03-2017, 10:24:09 PM   #42
tdz123
#1 M3F.net user.
Reputation: 0 tdz123 is on a distinguished road
Thanks. Nonetheless, I think Santa may be bringing me a lift this year.
Jump to top tdz123 is offline   Reply With Quote
Old Fri, Nov-03-2017, 10:25:28 PM   #43
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Definitely easier with a lift. I have a garage but it doesn't fit a regular lift so I got a quickjack instead
Old Fri, Nov-03-2017, 10:45:10 PM   #44
nholmes
Track Junky
nholmes's Avatar
Well done!
It's not too crazy of a job once you get into it. I had to do this on my E92M.
Follow my build thread here:
Old Sun, Nov-05-2017, 02:23:05 AM   #45
E92M3-8600RPM
Reputation: 0 E92M3-8600RPM is on a distinguished road
Impressive work and documentation....thanks for sharing.
A while back, I paid $2200 labor fee to have a shop did it for mine.
Jump to top E92M3-8600RPM is offline   Reply With Quote
Old Mon, Nov-20-2017, 01:38:53 PM   #46
kyrix1st
kyrix1st's Avatar
Japan
This is a totally unrelated question, but Did E90s ever get carbon fiber roof?
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Mon, Nov-20-2017, 01:40:38 PM   #47
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Unfortunately they did not. The best you can get is a slicktop, like the E46M
On the F80 you can get the CF roof. Finally!
Old Mon, Nov-20-2017, 03:31:48 PM   #48
kyrix1st
kyrix1st's Avatar
Japan
More the reason to go for E92. Just to add, instead of pulling fuse isn't it better to just disconnect the main battery? Gotta be careful while rotating that crank I guess!
How different were your bearing clearances between severely worn and relatively good ones? BE bearing seems to come in one size.
Am I looking for 0.0025 ideally for clearance? Or am I looking at 0.0027~0.0028 for maximum clearance?
WTB: Carbon airbox
'98 M3 evo (S50B32)
Recaro SPG, SR-2//
Hella headlights//
Old Mon, Nov-20-2017, 03:52:40 PM   #49
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
The additional ones I've done have all been without removing the fuse. I don't think it's beneficial to do that.
I haven't removed the BE bearings. I will after ~100 track days and post the results.
The bearing clearances are in the DIY, I don't recall them off the top of my head
Old Mon, Nov-20-2017, 04:05:17 PM   #50
You can buy a CF roof for the E90. A few here have installed them. Don’t know the details. Maybe Lang Racing.
Discussing DIY: S65 M3 Rod Bearing in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
