Old Fri, Dec-30-2016, 03:44:39 PM   #21
Performance Eurowerks
Reputation: 0 Performance Eurowerks is on a distinguished road
Default Re: DIY: S65 M3 Rod Bearing
As always, such a great thread and awesome contribution to the BMW community.
We have been doing A LOT of bearings recently and it still amazes me on what condition some of these low mileage cars are.
We absolutely love the BE Bearings and BE/ARP bolts. We try to encourage all of our clients to go this route. Can't wait to start doing their S54 bearings as well.
If I may add a quick note. If you want to the front subframe to lower a bit more without being bound up by the suspension arms, I recommend loosing the inner 18mm bolts for the front thrust arms. Tension will be released from those bushings, so the front subframe can swing down lower for more working room. When torquing them down during reassembly, just assure to torque them to spec with the suspension loaded to normal position.
Awesome work! Keep up the great service to the community.
EMAIL . FACEBOOK . INSTAGRAM . YOUTUBE . WEBSITE
Jump to top Performance Eurowerks is offline   Reply With Quote
Old Fri, Dec-30-2016, 03:52:41 PM   #22
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Thanks for the advice, that is a good pointer!
Old Fri, Dec-30-2016, 03:56:58 PM   #23
No problem!
We'll try to put together a couple threads for the forum showing the condition of the few that we've done in the last month.
One was 30,000mi with some ugly bearings.
The other was around 45,000mi with even uglier bearings.
Old Fri, Dec-30-2016, 04:02:32 PM   #24
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Originally Posted by Performance Eurowerks View Post
No problem!
Definitely post the pics! I consider it a must have in the E9X generation, but to be honest only a small percentage of cars has failed
Old Fri, Dec-30-2016, 04:05:49 PM   #25
It boggles my mind with the E9X.
My E90 M3, which I've owned since brand new has 105,000mi. About to do the bearings once the shop has more free time. Oil analysis has been perfect every 5000mi. Might not truly indicate the real condition, but at least, nothing too frightening.
But then, a client with 16,000mi, never tracked, cruising down the highway, his motor fails due to spun bearing. Dealer replaced it under warranty.
Old Sun, Feb-05-2017, 03:07:12 AM   #26
ty20404
Reputation: 0 ty20404 is on a distinguished road
Solid DIY. I tackled this today with this thread as a guide.
I did not remove the fan and was able to access everything. Getting the belt off is very tight but it is doable. I noticed you had mentioned that you removed 6 bolts on the subframe... it could be different for the coupes but my sedan had 8 bolts holding the subframe on. Also it was fairly necessary to use a transmission jack to support the subframe when removing the bolts as I had about another 4 inches to go once the bolts were at the end of their threads. I also removed the 10mm nut on the drivers side of the steering rack that hold the power steering line as it was a bit tight with the subframe lowered.
I've gotten as far as installing the new bearings and no reassembly in about 5.5 hours. Will finish up tomorrow and post up if I have any more insights.
Jump to top ty20404 is offline   Reply With Quote
Old Sun, Feb-05-2017, 03:27:04 AM   #27
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Yes, it can be done without removing the fan and in fact that's a better way to do it. The second car I did was like that based on admranger's recommendation.
When I do my second M3 I'll take pics and change the DIY
You're right on the 8 bolts instead of 6.
You do need to fully release the subframe bolts so the subframe hangs.
Good luck finishing up tomorrow!
Old Sun, Feb-05-2017, 07:35:59 AM   #28
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Excellent DIY. Thanks for posting this.
Old Mon, Feb-06-2017, 03:24:41 PM   #29
ty20404
Got it back together and after an oil-overfill escapade she's running great!
Some more lessons learned:
1. Wait to relieve tension in the belt and remove the tensioner bracket and bracket on the drivers front side of the engine until after you've dropped the subframe down completely. Way more room to work.
2. The Torx bolt on he passenger side of the transmission going into the oil pan is a bit restricted by the transmission oil cooler lines. If you remove the 10mm bolt holding the lines in place you can wiggle them just enough to break it loose with the E-torx socket and wrench. After that, a 10mm 12pt wrench should have enough bit to back it out all the way.
Some more pictures. 94k miles. Never tracked and daily driven. 2008 Sedan, 6MT.
Old Mon, Feb-06-2017, 03:28:06 PM   #30
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
HA those rod bearings do not look happy! Glad you took care of this and potentially saved your car!
Discussing DIY: S65 M3 Rod Bearing in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
