Old Thu, Dec-22-2016, 02:47:08 AM   #11
admranger
Registered troublemaker
Default Re: DIY: S65 M3 Rod Bearing
Another top shelf DIY by SYTShadow and his brother!
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Thu, Dec-22-2016, 09:03:20 AM   #12
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Originally Posted by PencilGeek View Post
Amazing DIY! This is such a great service to the community. Thanks for the time, effort, and helping others out as well.
The thank you is to you for starting this initiative with the special bearings!
Old Thu, Dec-22-2016, 09:03:59 AM   #13
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Thanks Kurt! Next time I'll try without the fan removal
Old Thu, Dec-22-2016, 02:59:56 PM   #14
Awesome write up, as usual!
What was the total time for the project, start to finish?
Old Thu, Dec-22-2016, 03:11:25 PM   #15
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Thanks! 12h from the start to finish. Next time it'll probably be 10h, and i'm sure it can be done faster but I've never been a fast worker.
Old Fri, Dec-23-2016, 04:04:56 AM   #16
admranger
2nd time I did them it took 8.5 hours, but I had a helper. Speeds up reinstallation of the oil pan and aligning the steering shaft and coupling while raising the subframe.
Old Fri, Dec-23-2016, 05:33:53 PM   #17
I think the shops that have done a bunch are doing it in 8 hours. Maybe even breaking 8 hours. And making good money at probably $1600 in labor on average. I don't have time to work on other people's cars, but did my own and helped a friend, and think I could get to 8 hours if I did a few more.
Old Fri, Dec-23-2016, 06:56:50 PM   #18
nholmes
Track Junky
nholmes's Avatar
Saw this on m3post, well done, dude!
Follow my build thread here:
Old Fri, Dec-30-2016, 05:46:29 AM   #19
admranger
Did my third car today. 7.5 hours this time. Had a helper lube the bolts and bearings for me and also help the oil pan and subframe get back into their places. One surprise was the torx headed (E14) front two subframe bolts. My car had 18mm standard bolts holding the subframe up. Otherwise is was as straightforward as it gets.
This time the car was a 2012 M3 w/20200 miles and about 20-30 track days (not quite sure on the number). I'll try to get pics up in the next day or so. Bearings did not look good but they weren't awful either. Some really odd wear patterns though.
Old Fri, Dec-30-2016, 08:48:26 AM   #20
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Please post the pics when you can!
7.5h is really good!
Discussing DIY: S65 M3 Rod Bearing in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
