Old Mon, Mar-24-2008, 12:28:46 AM   #31
floorguy
Reputation: 0 floorguy is on a distinguished road
Default Fuel pump malfunction
It seems I am not the first to have a fuel pump issue. Mine went out on Friday after 521 miles on the car. To top it off, it took BMW Assist 2 hours and 30 minutes to send a tow truck. I am still waiting to understand what happened. The first guy tried to explain to me that it had something to do with the gas tank being split into two sections and the gas not moving freely between the two, which caused one of the fuel pumps to dry out and overheat. Apparently the gasoline helps keep the pump cool. I'm not enough of an automechanic to know if that explanation is meaningful. The part I do understand is that it sounds like I won't get my car back before at least Wednesday, since they need to have conversations with and order parts from the folks in Germany. I'll post an update as I learn more.
Jump to top floorguy is offline   Reply With Quote
Old Mon, Mar-24-2008, 11:26:31 PM   #32
IcemanG17
Reputation: 0 IcemanG17 is on a distinguished road
This is very interesting....assuming the fuel pump works like the Bosch pump on my Porsche...the fuel does "cool" the pump kinda odd, but seems to work well....
However a pump failing after only 521 miles is totally unacceptable....the dual zone tank causing one to ingest air and overheat does make sense...but still is unacceptable in my mind..... Sometimes when the fuel cooled pumps on older 911's run dry they actually EXPLODE!!
Brian
2008 E92 M3, Melborne Red, beige leather, loaded, with DCT!! (deliver 7-08 hopefully)
2006 Acura TL (wife)
1988 Porsche 928 S4 Guards red over champagne leather
Jump to top IcemanG17 is offline   Reply With Quote
Old Tue, Mar-25-2008, 12:15:46 AM   #33
floorguy
Good news. I got my car back today. Despite the initial explanations I received, the real problem was with a connector that had become disconnected due to a broken clasp. An easy fix. I'm back on the road!
Old Tue, Mar-25-2008, 04:38:23 AM   #34
IcemanG17
This is good news!!!
Brian
Old Tue, Mar-25-2008, 05:34:05 AM   #35
som3randomguy
Unregistered User
som3randomguy's Avatar
Reputation: 0 som3randomguy is on a distinguished road
No M3, but our 335 has had zero problems. No complaints here!
However, my E46 M3 gets a new rattle every other week???
Jump to top som3randomguy is offline   Reply With Quote
Old Sun, Mar-30-2008, 01:48:17 PM   #36
georgebmwm3
Reputation: 0 georgebmwm3 is on a distinguished road
I have a 2008 M3 on order but I am reconsidering based on these posts. I am very disappointed that after all the hype that this car could have been better tested. What does BMW have to say about all this? How is there customer service towards you should these isssues arise? Any information is appreciated. Regards...
Jump to top georgebmwm3 is offline   Reply With Quote
Old Thu, Apr-17-2008, 07:16:53 AM   #37
blaxxun
Reputation: 0 blaxxun is on a distinguished road
Default E92 M3 Sedan Engine "whistling"
I just purchased my 2008 BMW E92 M3 Sedan a week ago, and it's developed a noticeable "whistling" sound from the engine over the course of the past few days (it sounds like a turbocharger). It's definitely noticeable in any gear or at any speed (particularly at lower speeds, as higher RPMs and road noise tend to drown it out) -- and definitely tied to acceleration (more = higher whistle).
It became noticeable enough to be heard over the stereo and was definitely audible when standing outside the vehicle (it was fairly loud with the hood open). A fairly audible "clicking" sound also accompanied it (much louder than any normal 'clicking' one might expect to hear).
Having heard the engine (from inside and outside) prior to purchase, I can state that this is *definitely* something that's developed. I'm taking it into the local BMW dealer tomorrow to hopefully shed some light on the situation.
I've read a few posts that seem to describe a similar situation, and they seem to range from oil levels to fuel pumps. Has anyone else experienced a similar situation where the noise just went away?
Jump to top blaxxun is offline   Reply With Quote
Old Mon, Apr-28-2008, 03:34:31 PM   #38
tjbuz
tjbuz's Avatar
Reputation: 0 tjbuz is on a distinguished road
Originally Posted by blaxxun View Post
...I've read a few posts that seem to describe a similar situation, and they seem to range from oil levels to fuel pumps. Has anyone else experienced a similar situation where the noise just went away?
Dealer said the whine was normal, but I agree that it is pretty loud. In 200 miles I will have it in for the 1st service. I'll have them check it out again. Maybe they will remove the "temporary referee whistle" they put in the motor to scare you from driving over break-in speeds.
Actually, you get kind of used to it and it doesn't really bother me any more. I passed a guy at about 5500 RPM (still under break-in miles) in third gear and then he pulled up next to me at a light and said "Damn, I thought that was a satellite flying by me!"
2008 E92 M3 - Jerez Black Metallic - Loaded
Jump to top tjbuz is offline   Reply With Quote
Old Sat, May-03-2008, 05:28:25 AM   #39
Steveo58
Steveo58's Avatar
Reputation: 0 Steveo58 is on a distinguished road
had mine for 600 or so miles and all is great. love the car... hopefully it stays that way!
-Steveo-
2008 M3 - 6MT
Jump to top Steveo58 is offline   Reply With Quote
Old Sat, May-03-2008, 04:05:50 PM   #40
ArtM3
Reputation: 0 ArtM3 is on a distinguished road
we go from exploding engine theory to a loose connector, 5 minute fix
Jump to top ArtM3 is offline   Reply With Quote
e92, issues, mechanical
Mechanical Watches SteDevote Off Topic 10 Fri, Sep-19-2008 09:43:04 PM
Anyone concerned about major mechanical issues? jones205 E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) 13 Sun, Feb-17-2008 07:03:15 PM
Best mechanical pencil? ArtM3 Off Topic 42 Sat, Nov-04-2006 12:06:57 AM
NEED HELP with some mechanical know-how jddwyer E36 M3 (1992-1999) 2 Mon, Jan-10-2005 06:15:07 PM
OT: Mechanical Watches M3ForFun E46 M3 (2001-2006) 23 Sat, May-31-2003 04:03:19 PM
Discussing e92 M3 mechanical issues... in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
