Old Thu, Aug-22-2013, 06:42:12 PM   #1
EKaru
EKaru's Avatar
Reputation: 766 EKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru Porsha
Default If you have a BR-Z, don't race grandpa
Highs:
Big, smooth power; respectable fuel economy.
Lows:
Ho-hum XTS dynamics, prevalent torque steer, expensive.
Specifications >
VEHICLE TYPE: front-engine, 4-wheel-drive, 5-passenger, 4-door sedan
PRICE AS TESTED: $71,015 (base price: $63,020)
ENGINE TYPE: twin-turbocharged and intercooled DOHC 24-valve V-6, aluminum block and heads, direct fuel injection
Displacement: 217 cu in, 3564 cc
Power: 410 hp @ 6000 rpm
Torque: 369 lb-ft @ 1900 rpm
TRANSMISSION: 6-speed automatic with manual shifting mode
DIMENSIONS:
Wheelbase: 111.7 in
Length: 202.0 in
Width: 72.9 in Height: 59.4 in
Curb weight: 4437 lb
C/D TEST RESULTS:
Zero to 60 mph: 5.2 sec
Zero to 100 mph: 12.4 sec
Zero to 130 mph: 23.3 sec
Rolling start, 5–60 mph: 5.6 sec
Top gear, 30–50 mph: 2.9 sec
Top gear, 50–70 mph: 3.7 sec
Standing -mile: 13.6 sec @ 105 mph
Top speed (governor limited): 137 mph
Braking, 70–0 mph: 172 ft
Roadholding, 300-ft-dia skidpad: 0.79 g
FUEL ECONOMY:
EPA city/highway driving: 16/24 mpg
C/D observed: 17 mpg
The Cadillac XTS stands apart from the ATS and CTS sports sedans that are redefining America’s luxury automaker. The big soft Caddy is designed for the brand’s old-school customers and those who might set a priority of roominess and ride quality over rortiness. Cadillac XTS buyers need 410 horsepower like they need a motion-sensing touch screen and capacitive-touch climate controls. But where Cadillac’s CUE infotainment system was maddening, we’re down with the addition of a potent turbocharged V-6 between the front wheels. And come to think of it, 1950s and ’60s Caddys had way more power than control, so there’s a bit of legacy here.
This 2014 Cadillac XTS is our first exposure to the Vsport series that slots between Cadillac’s mainstream lineup and the tire-slaying V performance models. Vsport here means the force-fed V-6, the twin turbochargers of which are bolted to a 3.6-liter engine that is a dimensional clone of the naturally aspirated V-6 widely used by GM vehicles (including the standard XTS). However, Cadillac claims the Vsport engine uses a new block, internals, and direct-injection system to contend with the 12 psi of intercooled boost.
Sneaky Fast
The new engine generates smooth, effortless power befitting a large Cadillac. It doesn’t pack the soul-stirring rumble of an eight-cylinder, but the V-6 surpasses the old DTS’s Northstar V-8 in nearly every other regard. With 369 lb-ft of torque from 1900 rpm, the turbocharged XTS makes overtaking other cars a breeze and possesses the sometimes-scary ability to hit triple-digit speeds unintentionally. The six-speed automatic uses the same gear ratios as in the naturally aspirated XTS but with a shorter final-drive ratio. Shifts are quick and logically sound, although the manual shift mode is slow to respond. Most of all, we wish the transmission and the engine could collaborate to speed up throttle response off the line.
In the run to 60 mph, the turbochargers are good for two whole seconds compared with the performance of the naturally aspirated, all-wheel-drive XTS, with the Vsport stopping the clock at 5.2 seconds. The quarter-mile is cleared in 13.6 seconds, 2.1 seconds sooner, at which point the XTS’s digital speedo reads 105 mph. The Vsport is rated by the EPA at 16 mpg city and 24 highway, and we deemed our observed fuel economy of 17 mpg to be quite reasonable. If there’s a weakness with the Vsport, it’s not the new engine.
Challenged Chassis
Unfortunately, the XTS’s chassis hasn’t been rehabilitated for its new job. As in lesser XTS models, the Vsport experience is tainted by a shaky-feeling structure, limp steering, and a suspension that’s on the soft side. Braking and skidpad numbers were no better than what we’ve recorded for naturally aspirated XTS models, and despite GM’s HiPer strut front suspension and all-wheel drive, torque steer still manages to boss around the driver’s palms.
The Vsport badge carries a hefty premium—$5835, to be exact—that should cause shoppers to consider the German alternatives. The V-8 models of the BMW 5-series and Mercedes-Benz E-class are priced between the Vsport’s base price and our test car’s $71,015 sticker and offer much more engaging chassis characteristics.
Cadillac’s media materials suggest that the company flirted with the name XTS Turbo before settling on the Vsport badge. Although not nearly as sexy, “turbo” might have been a more fitting moniker. The Vsport is a far better car than the DTS that used to occupy the XTS’s slot in Caddy’s lineup, but it’s hardly sporty. The Vsport’s ability to raise our pulses is limited to one fact: We can’t wait to drive the powerful 3.6-liter twin-turbo V-6 in a proper sports sedan—namely, the 2014 Cadillac CTS Vsport.
http://www.caranddriver.com/reviews/...rt-test-review
Jump to top EKaru is offline   Reply With Quote
Old Thu, Aug-22-2013, 06:44:07 PM   #2
m3 hal
Default Re: If you have a BR-Z, don't race grandpa
I thought it was widely known that if you have a BR-Z you shouldn't be racing anything made in the last 5-10 years
Jump to top m3 hal is online now   Reply With Quote
Old Thu, Aug-22-2013, 06:44:43 PM   #3
trebm3
Gaming Elder
trebm3's Avatar
Reputation: 0 trebm3 is a jewel in the rough
Bolivia
BRZ/FRS owners have a lot of other cars to worry about aside from grandpa
Jump to top trebm3 is offline   Reply With Quote
Old Thu, Aug-22-2013, 06:45:36 PM   #4
Ben Z.
Registered Abuser
Ben Z.'s Avatar
Reputation: 0 Ben Z. is on a distinguished road
$71k.. Thanks but no thanks
Jump to top Ben Z. is offline   Reply With Quote
Old Thu, Aug-22-2013, 06:45:42 PM   #5
beebo100
2014 F1 fantasy league and 2008 F1 game champion
beebo100's Avatar
Reputation: 0 beebo100 is on a distinguished road
if you have a BRZ, race grandpa in the twisties only.
Jump to top beebo100 is offline   Reply With Quote
Old Thu, Aug-22-2013, 06:47:34 PM   #6
EKaru
EKaru's Avatar
Old Thu, Aug-22-2013, 06:52:39 PM   #7
EKaru
EKaru's Avatar
That's unless grandpa has a MKZ 2.0H Hybrid
2013 Lincoln MKZ 2.0H Hybrid
Specifications >
VEHICLE TYPE: front-engine, front-wheel-drive, 5-passenger, 4-door sedan
PRICE AS TESTED: $42,415 (base price: $36,820)
ENGINE TYPE: DOHC 16-valve Atkinson-cycle 2.0-liter inline-4, 141 hp, 129 lb-ft; AC permanent-magnet synchronous electric motor, 118 hp, 117 lb-ft; combined system, 188 hp
TRANSMISSION: continuously variable automatic
DIMENSIONS:
Wheelbase: 112.2 in
Length: 194.1 in
Width: 73.4 in Height: 58.1 in
Curb weight: 3843 lb
C/D TEST RESULTS:
Zero to 60 mph: 9.4 sec
Zero to 100 mph: 25.3 sec
Rolling start, 5–60 mph: 9.1 sec
Standing -mile: 17.2 sec @ 83 mph
Top speed (governor limited): 109 mph
Braking, 70–0 mph: 170 ft
Roadholding, 300-ft-dia skidpad: 0.83 g
FUEL ECONOMY:
EPA city/highway driving: 45/45 mpg
C/D observed: 32 mpg
http://www.caranddriver.com/reviews/...id-test-review
Old Thu, Aug-22-2013, 07:01:39 PM   #8
AutoUnion
AutoUnion's Avatar
Reputation: 0 AutoUnion is on a distinguished road
Germany
lol, 71k for that.
Jump to top AutoUnion is offline   Reply With Quote
Old Thu, Aug-22-2013, 07:01:49 PM   #9
jph28
Back in 'Merica
Reputation: 0 jph28 is on a distinguished road
Lincoln
Btw, title could have also been "if you're not a good driver and own an E46 M3, watch out for grandpa"... That thing is no slouch.
Current - 2018 M2, 2018 Tahoe
2004 SilverGrey 6MT Sold
Past - '15 F31d / '02 M5 / '04 M3 / '12 VW JSW TDI / '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T
Jump to top jph28 is offline   Reply With Quote
Old Thu, Aug-22-2013, 07:07:01 PM   #10
MrBooby
MrBooby's Avatar
Reputation: 0 MrBooby is on a distinguished road
Russian Federation
Is that the same twin turbo V6 that's going in the new CTS? Or was it a TTV8?
Originally Posted by TrueDownforce View Post
downforce is a lifestyle with compromises...u have to be willing to sacrifice... gas mileage... top speed... but when things get curvy u become the champion and thats what life is about
Jump to top MrBooby is offline   Reply With Quote
Discussing If you have a BR-Z, don't race grandpa in the Off Topic Forum - Place to discuss this and that. Note: We also have "request to join" forums: Guns and Fitness.
