Old Mon, Sep-07-2009, 12:41:14 AM   #1
PKumarM3
Reputation: 0 PKumarM3 is on a distinguished road
Default No More Airbags, so no more Air Bag Light
After removing the steering wheel airbag, as well as the side airbags and the front passenger airbag, I have had a bright red air bag light staring at me every time I got into the car. I decided to change that today.
After spending nights with my new bible (The Bentley E46 Manual), I realized that all airbag sensors feed into the main air bag brain, which is located right under the center console. If there is no module, and it is not grounded, no airbag is technically missing. Obviously there will be a fault in the computer, but there won't be a light on my dash. I also considered adding resistors like others have, to trick the computer into thinking there was an airbag, but honestly, that is just foolish. If you are removing one airbag, you are compromising the rest of the airbags and you really should remove them all.
So I removed the module, and taped up the ground with electric tape, and voila. No Airbag light.
This is for cars that no longer have airbags and are tired of staring at that red light looking at you in the face. I would not suggest doing this if you have the steering wheel airbag and/or any of the other airbags in the car.
This is what the airbag module looks like:
It is important to electric tape the ground, or else it will short and the airbag light will go on and off constantly.
Oh yeah, it weighs less than 1 lb.
Jump to top PKumarM3 is offline   Reply With Quote
Old Sat, Jan-08-2011, 04:08:53 PM   #2
wilmar13
wilmar13's Avatar
Reputation: 0 wilmar13 is on a distinguished road
Default Re: No More Airbags, so no more Air Bag Light
This seems like a great idea... any problems since doing it? Anyone else see any downside?
Jump to top wilmar13 is offline   Reply With Quote
Old Sat, Jan-08-2011, 04:18:03 PM   #3
IHatePosers
Long Live M3
IHatePosers's Avatar
Reputation: 0 IHatePosers is on a distinguished road
Once you remove the module, u remove all airbag functionality in the car. So all your airbags are dead weight.
2018 Dodge Durango GT
Originally Posted by Official 2014 Formula 1 Game View Post
Ihateposers says,"ttylkthxbai"
Jump to top IHatePosers is offline   Reply With Quote
Old Sat, Jan-08-2011, 04:38:37 PM   #4
wilmar13
wilmar13's Avatar
Yep, and dead weight should be removed since it is useless.
Old Sat, Jan-08-2011, 10:06:19 PM   #5
PerkM3
PerkM3's Avatar
Reputation: 0 PerkM3 is on a distinguished road
Very nice idea, now I just need to remove the front A piller curtain airbags then do this.
Jump to top PerkM3 is offline   Reply With Quote
Old Sun, Jan-09-2011, 12:58:05 AM   #6
IHatePosers
Long Live M3
that requires removing the dash. ask me how i know (not my car)
locate the two metal gas canisters. those are the bottom of the curtain airbags. i am dreading removing my dash, but its the only way to remove those airbags w/out cutting them. i also am removing my audio wiring harness now that howard stern can be listened to on the sirius app on my iPhone!
Old Sun, Jan-09-2011, 02:36:48 AM   #7
Zapco
Zapco's Avatar
Reputation: 0 Zapco is on a distinguished road
Anybody know what all the air bags weigh? Great idea.
2004 BMW M3 Coupe. Silbergra Metalic. Ohlins/Vorshlag. GSP SMG Brake Pedal. Apex Arc-8. Carbon Fiber (sunroof delete).
Jump to top Zapco is offline   Reply With Quote
Old Sun, Jan-09-2011, 03:19:06 AM   #8
kuksul08
I have an airbag light that cannot be cleared (gave control unit fault). I ought to remove the module since it's worthless anyway and get rid of that pesky light!
Old Sun, Jan-09-2011, 03:29:51 AM   #9
wilmar13
wilmar13's Avatar
I just pulled the ones in the door, 1lb 9oz
Passenger: 5lb 7oz
control module: 10oz
Old Sun, Jan-09-2011, 03:33:43 AM   #10
wilmar13
wilmar13's Avatar
I just had the glove box out and the vent cover, and it looked like you could access both bolts for the passenger side curtain you have circled with just the glove box removed. I was surprised to find the side curtain that low, and thought about removing the base and pulling the sock out of the A pillar without removing it, but I am tired and quit. After seeing your photo, I may try in the morning.
Big weight savings in removing the audio.
air, airbags, bag, light
Discussing No More Airbags, so no more Air Bag Light in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
